Turn Signals on with Parking Lights
Discussion in 'Lighting' started by cleanTRDmachine, Feb 11, 2011.
  1. Feb 11, 2011 at 3:44 PM
    cleanTRDmachine
    cleanTRDmachine [OP] watch the meat
    Kyle
    Q-Town, PA
    06 DC TRD
    tint gray camo seat covers debadged color matched grille surround off of 06 TRD sport grillecraft black mesh grille Hella 500's demudflapped Toyota rear leaf TSB (first edition) 265/75/16 BFG AT TA KO's Flowmaster Super 40 #952445 Maglite Mod AntennaX 13in antenna Painted Lower Valance Vision X H4 Xenon headlights Halo Solaris H10 foglights Velocity Offroad 2.5 leveling kit (removed) Spidertrax 1.25" wheel spacers Rocky Mounts Clutch SD bike mount 4ft combo lock cable for bed extender Stage I interior LED's Toytec 1.5" AALs Extang Trifold Signature Series Bed Cover Reese front mounted tow hook Icon Stage 1 Suspension
    I've searched and cannot find a thread on how to wire the turn signal lights to turn on with parking/corner lights.
    Any help?
    Thanks
  2. Feb 11, 2011 at 6:07 PM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    If you follow the wires going into your turn signals you will notice that there is one hole with a rubber stopper in it next to the other two wires. Now if you seperate the connector and the bulb holder there are 3 prongs for the connection. Remove the rubber stopper in the blank hole and run a piece of 16 guage wire through it then bend it over the prong and snap the connector back together. Run the other end of the wire and splice it into green wire going to the parking lamps. This takes about 10 minutes and works like a charm. There was a thread on here with pictures but I can't find it now.
  3. Feb 11, 2011 at 6:26 PM
    Bama_TACO
    Winfield, AL
  4. Feb 11, 2011 at 6:31 PM
    cleanTRDmachine
    Kyle
    Q-Town, PA
    06 DC TRD
  5. Feb 11, 2011 at 6:37 PM
    cleanTRDmachine
    Kyle
    Q-Town, PA
    06 DC TRD
    So if you do this, when you turn your parking lights on, the turn signals will come on as well?
  6. Feb 11, 2011 at 8:38 PM
    Bama_TACO
    Winfield, AL
    That is correct. Actually what is happening is that you have a dual element bulb. When the park lamps are on, only one element is burning. When the turn indicators are on both elements burn at the same time.
  7. Feb 12, 2011 at 5:22 AM
    cleanTRDmachine
    Kyle
    Q-Town, PA
    06 DC TRD
    Sweet, thanks
