Turning off the traction Control?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bj462taco, Feb 9, 2009.
  1. Feb 9, 2009 at 10:03 PM
    bj462taco
    bj462taco [OP] Well-Known Member
    Mark
    Alberta canada
    Custom tube bumper and sliders, ultimate 3' lift,
    Is there a way to turn off the traction control while in 4 wheel drive.. The button does not seem to do anything unless you are in 2wd... can anyone help. I got stuck in snow and would have loved to have more wheel spin to get me out of the powder to power me out of a bad place without the traction control cutting in and out.
  2. Feb 9, 2009 at 10:34 PM
    bj462taco
    Mark
    Alberta canada
    anyone?
  3. Feb 9, 2009 at 11:12 PM
    HILOTOY
    HILOTOY HILOTOY
    From Big Island
    05 trd 4wd off road,tow pack
    I tried doing the locker mod switch on a friends 09 with vsc to disable the abs and it disabled the vsc. He tried scrambling a bit and it got loose but abs kept it from drifting. Learned that you can disable the abs if you remove the 30 amp ABS fuse under the hood...............hope this helps.........look for the locker mod under the mod section
  4. Mar 1, 2010 at 10:24 AM
    Deerehunter44
    Deerehunter44 New Member
    2009 Tacoma TRD 4x4
    I had the same problem over the weekend - very frustrating. Had all kinds of momentum and speed and a tire started to spin and the power to the wheels was stopped. Instantly got stuck. Toyota dealer says traction contol comes off in low lock but not true. I dont want a truck that gets stuck in 12 inches of snow because the tires won't spin themselves out of the situation. Did you try the fuse trick and if so, did you lose your anti lock breaks? Thanks!!
  5. Mar 1, 2010 at 10:27 AM
    Ccwahoo
    Ccwahoo "Get comfortable being uncomfortable" Goggins
    Central Virginia
    '10 TRD Sport 4x4
    Be interested in finding out
  6. Mar 1, 2010 at 10:31 AM
    madcatter
    madcatter Well-Known Member
    western pa
    2010 tacoma
    jl audio stealthbox jl audio slash g2-500/1v2 good year dura-tracs jl audio g-class 50wattX2amp mb quart 5 1/4" rear matted mb quart 6.5 comp.set lotsa dynamat 4ga amp kit 16 gauge wire kit control knob on dash pioneer avic-x910bt in dash navigation dvd playback sirus tuner/bus interface built in blue tooth toyota environmental package leaf tsb weather tech floor liners yellow wire mod gray wire mod compartment bed lights added tie down d rings
    this weekend i was off road in 14"snow for 300 miles.i finally read the owners manual.
    hold in the button for 5 seconds and the icon in the dash will come on.
    i had no problems with all the safty bullshit after that.when ya shut the truck off it will be back on or use the same button.just hold it in until the light turns on
  7. Mar 1, 2010 at 4:52 PM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    Interesting, I haven't had my Tacoma anywhere where I needed 4 wheel drive yet but this post got me thinking, so I reviewed the owners manual, if I read it correct it says to turn off the traction control simply push the TRAC button (doesn't indicate moving or not so I assume either is OK)
    The manual reads to turn off both the TRAC and VSC one should push and hold the button for 3 seconds while the vehicle is stopped, So if I am anticipating some trouble with mud or snow, I should stop and disengage both the TRAC/VSC, or if I happen upon mud or snow unexpectedly just quickly push the TRAC button, am I correct? The old truck I just locked in the hubs and pulled it into 4 wheel, (but the new is much nicer!) Doc
  8. Mar 1, 2010 at 4:55 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    For those with an allergy to reading your owners manual you can disable VSC by pressing the VSC OFF Switch for 3-5 seconds with the vehicle at a standstill.
  9. Mar 1, 2010 at 5:02 PM
    Crom
    Nick
    San Diego, CA
    Millions
    DocD, Yes. I highly recommend disabling VSC while off-roading. The traction systems can interfere when you don't want them to.
    Remember this: TRAC attempts to detect and control wheel spin. VSC detects and attempts to control lateral vehicle slides.
    The owners manual says it all but it can be a bit confusing at first.
    1st.trax likes this.
  10. Mar 1, 2010 at 5:15 PM
    akyota
    akyota Well-Known Member
    Fairbanks, Alaska
    10' DC trd-offroad mag gray
    none yet
    ^ what he said
  11. Mar 1, 2010 at 5:22 PM
    DocD
    Mn./SoCal
    09 access cab
    Crom, Thanks, your right the manual can be a little confusing, I am quite sure my truck will never see any "Off Road" use it will see country roads that become snow packed at times and farm roads (private) where the snow can get deep, when I encounter these roads would turning off the VSC be advisable? In the old truck I would lock the hubs in around Oct. and leave them locked in until May, and if need be I just shifted into 4wheel, this newer technology is great, but I have a lot to learn, Thanks Doc
    The old
    The New
  12. Mar 1, 2010 at 5:36 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Nice trucks DocD! VSC on those roads will never interfere with your driving unless your driving out of control and your vehicle begins to drift sideways (front or rear slides). I have done this on dirt roads while traveling 40+ mph and VSC will brake (hard) whatever wheel lost traction with the road.
    In your case, TRAC might be an issue with wheel spin and going up hill. So pushing the VSC OFF switch once will enable Auto-LSD mode which disables TRAC. That would suite your needs best. (Auto-LSD/TRAC Off only works in 2WD).
    It's worth mentioning too that ABS will probably affect you in the snow and ice. Our vehicles only disable ABS while in for 4LO. If you're in 4WD-HI, you will have to endure whatever ABS system decides to do--and it can range from annoying you to putting your life in danger by not allowing you to stop short distances on wash-boarded, snowy or ice roads.
  13. Mar 1, 2010 at 5:56 PM
    DocD
    Mn./SoCal
    09 access cab
    Crom (and others) Thank you so much, clears a lot of things up, I am glad I found this thread, Thanks bj46taco for starting it!! Doc
    ps
    Crom, I have to give a "thumbs up" to your city, SD, our GRANDdaughter go's to school out there and we get out there a couple of times a year, (mostly winter) wonderful place!!!
  14. Mar 3, 2010 at 8:27 AM
    Deerehunter44
    2009 Tacoma TRD 4x4
    Thanks for the info - I may have a different problem then - I do not have a TRAC button - it is the VSC that only turns off in 2 wd. If I am in 4wd and in park, pushing and holding the button shuts it off. When I put it in drive, VSC comes back on. I have an appt with the service department this afternoon - mine might be a unique problem
  15. Mar 3, 2010 at 9:34 AM
    Crom
    Nick
    San Diego, CA
    Millions
  16. Mar 3, 2010 at 2:08 PM
    Deerehunter44
    2009 Tacoma TRD 4x4
    Crom - thanks for all of your help. I hope this is all operator error on my part. Somehow everything is working as described by you and owners manual now. More snow to drive through this weekend so only time will tell!! Thanks
  17. Mar 3, 2010 at 2:13 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Awesome! Glad to hear it! :thumbsup: Welcome to TW :)
  18. Mar 3, 2010 at 2:16 PM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '18 Tundra Platnium
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    You have to be in park or nuetral
    never mind, just re-read ur post
  19. Feb 21, 2011 at 7:28 AM
    mike day
    mike day New Member
    mike
    Park County, CO
    2010 Tacoma TRD
    The Truck has to be in park before you can hold the button down to disable the traction feature, as far as I can tell? I've tried doing it in drive with my foot on the brake, and it doesn't seem to work.
  20. Feb 21, 2011 at 10:53 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    :) for later
