TW Live
  1. Nov 1, 2015 at 7:44 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    The force is strong with this one.
    Warputer and scocar like this.
  2. Nov 1, 2015 at 8:20 AM
    Joe D
    Joe D .
    I'm pretty sure you're getting the death stare from your cat...
  3. Nov 1, 2015 at 8:24 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Oh hell yeah.
    DEEVON911 likes this.
  4. Nov 1, 2015 at 8:29 AM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
  5. Nov 1, 2015 at 8:49 AM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
  6. Nov 1, 2015 at 8:53 AM
    scocar
    scocar hypotenoper
    No, I wish I had the prob, sort of, LOL.
    Experimenting with ideas to get my XQ's rear door to close and seal better after the Relentless tailgate plate install.
  7. Nov 1, 2015 at 8:54 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Necessary to switch back to stock grill but this is the first time I've had a stock 2012 style mounted up. I had mixed feelings, but now that it's on it ain't too bad. :oops:
    Beerrun, ERMB and Warputer like this.
  8. Nov 1, 2015 at 8:57 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    remove the rear door
  9. Nov 1, 2015 at 9:10 AM
    scocar
    scocar hypotenoper
    The struggle is real. Is mine almost done yet?
    This post belongs in 3rd gen.
  10. Nov 1, 2015 at 9:38 AM
    Old School
    Old School You are ignoring covfefe by this member.
    You'll need to slide the shell back just a little, door strikers can be adjusted, but in this case, move the shell backwards...
  11. Nov 1, 2015 at 9:42 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Another bon fire.
  12. Nov 1, 2015 at 10:04 AM
    scocar
    scocar hypotenoper
    Nope. I've adjusted the strikes perfectly to get it to close correctly. The limiting factor is the seal. The shell is correctly positioned on the bed. If I move it back, it will be misaligned, look stupid, and be prone to leaks elsewhere.
    I have some other ideas up my sleeve too, in the War Room...:spy:
  13. Nov 1, 2015 at 10:04 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  14. Nov 1, 2015 at 10:10 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    You just ruined Lusetaco's day! :)
  15. Nov 1, 2015 at 10:15 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Samhain
  16. Nov 1, 2015 at 10:19 AM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    What were you for Halloween the injury police?
  17. Nov 1, 2015 at 10:24 AM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    What if you put a washer or two behind the tailgate cover to pull the edge back
  18. Nov 1, 2015 at 10:30 AM
    OZ-T
    Peter North
    British Columbia
    Move the canopy back , I had to do that with the KB Voodoo tailgate cap
  19. Nov 1, 2015 at 11:32 AM
    scocar
    scocar hypotenoper
    The curve in the middle of the tailgate won't allow enough room to do this and close up the 1/4 inch difference and still be able to reinstall the TGP.
    No. With a cherry on top.
    This flattish strip I picked up on the cheap yesterday is just to experiment. I think the real solution will be one of these, which I'll need to buy online.
    Both would require removing the stock piece of trim/flap in place now.
    This, which I would adhere to the inside bottom edge of the frameless door:
    The War Room: Scocar's, um, "build"
    Or this, which may slot onto the bottom of the glass with the aid of some adhesive in the trough of the slot. I may need to trim of the shorter of the two bottom edges, which would be the inside, if you can picture that.
  20. Nov 1, 2015 at 11:33 AM
    OZ-T
    Peter North
    British Columbia
    Why can't you just move the cap back 1/4" ?
