type of tune for turbo tacoma
Discussion in '4 Cylinder' started by mac1, Oct 25, 2011.
  1. Oct 25, 2011 at 7:17 PM
    mac1
    mac1 [OP] New Member
    california
    99 tacoma 2rz
    intake
    i have a 1999 tacoma and i want to tubro it but dont know what kind of tune or chip i will need. also some say the 2rz can handle 15lbs of boost what do i need to support 15lbs?
  2. Oct 25, 2011 at 10:02 PM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    Dude, far too open ended. Custom tune using a stand alone engine management system. I doubt I can handle 15 pounds of boost, more like 6-7. 15 lbs of boost would require a full engine rebuild with forged internals minimum. A drop in compression would serve you well. Are you buying a kit or piecing one together yourself?
  3. Oct 26, 2011 at 9:03 PM
    mac1
    california
    99 tacoma 2rz
    intake
    pieceing one together what would be a good standalone all i heard of is megasquirt pnp
  4. Oct 26, 2011 at 9:50 PM
    Hayes
    Brandon
    Denver, CO
    AEM is the best in the tuning world. I don't know about megasquirt in power applications. I know that it does well in stock applications but in a completely custom setup, I think you'd be better getting an AEM and having a professional tune it. Customer kits take a lot of time and effort to get right and tuning them is really not for a first timer.
  5. Oct 26, 2011 at 9:57 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Speed Freek would probably know, shoot him a pm
  6. Oct 29, 2011 at 11:43 PM
    mac1
    california
    99 tacoma 2rz
    intake
    oo what kind of aem ecu. i cant seem to fined any..
    thank for the help doc.ss
  7. Oct 29, 2011 at 11:47 PM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    Psi means nothing without getting into specifics.
  8. Oct 30, 2011 at 12:04 AM
    mr2r6
    mr2r6 Well-Known Member
    Charleston, SC
    16 TRDOR 4X4
    This is the wrong forum to find the info you want. You need to go contact a shop that builds custom turbo cars.
  9. Oct 30, 2011 at 12:15 AM
    mac1
    california
    99 tacoma 2rz
    intake
    where is that shp located
  10. Oct 30, 2011 at 12:17 AM
    mr2r6
    Charleston, SC
    16 TRDOR 4X4
    Couldnt tell you. Im on the east coast. There just are not that many turbo Tacomas around and theres A LOT to building a turbo motor.
  11. Oct 30, 2011 at 12:26 AM
    Hayes
    Brandon
    Denver, CO
    There isn't one specific shop. You can try lcengineering.com. I'm not usually one to squash dreams but you need to do a lot of reading and research before you start to build a setup like you are talking about. I'm not talking about asking questions on forums but reading books and professional sources about parts, designs, and basic info. Ahem is a standalone engine management system which means that it replaces the stock harness for anything and everything engine/trains related. They make a piggyback version but if you are building a custom kit, you might as well get the best engine management unit.
    This is just scratching the surface. You need to figure out what kind of turbo will work best for you. Researching and considering compressor maps, what kind of boost you want, what kind of power curve you want. Are you going for a ridiculous peak horsepower that isn't really usable or are you looking for a low peak power with a useable power curve? Decent boost that gives a consistent curve will be significantly nicer to drive, not to mention nicer on all your components...
    There are a lot of questions you need to figure out before you can design the right kit for you. There is a reason that most kits aren't custom built. It's expensive and the time you spend will be incredible. There also might be a reason there isn't a kit readily available. It could be because there is not a lot of interest, or because the engine can't handle the power, I couldn't tell you which...
    This is not to discourage you completely, or me saying that you can't build this kit, but there is a ton of planning and testing that goes into a good turbo kit.
  12. Apr 1, 2018 at 4:13 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    What’s a TUBRO?
    I know this is a old thread but interested if anything came of it.
  13. Apr 3, 2018 at 9:21 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I've used a Megaquirt on my turbo 3rz. Once you get the set up all good, tuning is fairly easy. I'd say that for the cost, it's the best stand alone you can use. There are other with more features that you will pay more for such as Haltech. It would be helpful, though, to have a better idea of what your goals are.
    Some other guys on here that can help you out as well:
    @arcenik @Torspd @MadTaco461 @MrCrowntown
    robssol likes this.
  14. Apr 3, 2018 at 10:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    TU-Bro bro.
    1) You-bro (Spanish translation)
    2) Too-Bro (expanded English common tongue)
    Ex.: I need a beer. You TuBro?
    robssol[QUOTED] likes this.
  15. Apr 3, 2018 at 11:08 AM
    boostedka
    James
    NM
    LOL. I just saw this is a thread from '11
    robssol and MadTaco461 like this.
  16. Apr 3, 2018 at 11:13 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I'm tu bro. Usually monster and flat billed hats are good to 15 psi.
    robssol and Torspd like this.
  17. Apr 3, 2018 at 11:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Metal militia also falls in that category.
    MadTaco461[QUOTED] likes this.
  18. Apr 3, 2018 at 8:35 PM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
  19. Apr 4, 2018 at 4:02 AM
    robssol
    Rob
    S. Wisconsin
    :rofl::rofl::rofl:
  20. Apr 4, 2018 at 4:03 AM
    robssol
    Rob
    S. Wisconsin
    MrCrowntown[QUOTED] likes this.
