Ubolts under torqued
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WD, Jun 1, 2012.
Are your U bolts tight ??
Poll closed Jul 1, 2012.
  1. Tight as they should be
    67.9%
  2. Loose as hell
    32.1%
  1. Jan 1, 2013 at 11:57 AM
    #141
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Now Im picturing him going up to random tacomas, in parking lots, and loosening the springs.....
  2. Jan 1, 2013 at 12:05 PM
    #142
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Get it right, I'm tightening them & not random Tacomas, just 2nd gens...:cool:
  3. Jan 1, 2013 at 12:10 PM
    #143
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!!
  4. Jan 1, 2013 at 2:23 PM
    #144
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    ^lol hahaha
  5. Jan 1, 2013 at 3:33 PM
    #145
    4WD
    Doug
    2004 DC TRD 4x
    :D:thumbsup::thumbsup:
  6. Jan 1, 2013 at 3:51 PM
    #146
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I was always told the anti sieze was bad to use on U bolts. :confused:
  7. Jan 1, 2013 at 6:53 PM
    #147
    SeniorSpan
    SeniorSpan Well-Known Member
    Bob
    Colorado Springs
    23 TRD DCSB OR
    Check my 2011 DC TRD with 31,000 miles. Yup they needed attention; they were torqued at approx 35ft. lbs., so increased them to 60 ft.lbs.
    Thanks for the heads up.
    Cheers
    Bob
  8. Jan 1, 2013 at 10:23 PM
    #148
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    You can always double-nut the ubolts if you're worried about them loosening up.
  9. Jan 2, 2013 at 12:41 PM
    #149
    darkgohan
    darkgohan Well-Known Member
    Can I just crawl under my truck and torque the nuts or do I have to have the axle free of the ground,that is jacked up? Also is there a torqeing sequence ? Info appreciated!! Thanks
  10. Jan 2, 2013 at 12:50 PM
    #150
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Just crawl under and torque. Keep the threads as even as possible...
  11. Jan 2, 2013 at 1:13 PM
    #151
    darkgohan
    Thank you
  12. Jan 2, 2013 at 3:05 PM
    #152
    4WD
    Doug
    2004 DC TRD 4x
    yeah you can crawl underneath but leave truck on ground so it has the "real world" weight on it & tighten away, don't think theres a sequence seeing how theres only 2 U bolts that are seperated from each other but snug them down evenly...
    Hey !! Get your own thread dude, then you can answer questions....:p j/k:D thanks Chris...
  13. Jan 2, 2013 at 3:33 PM
    #153
    nfs257
    DFW
    She gone
    Quit forgetting due to your advanced age that you have 2 threads with great info that I keep posting in! :p:p:p:p:p:p:p:D:eek:
  14. Jan 2, 2013 at 3:34 PM
    #154
    4WD
    Doug
    2004 DC TRD 4x
    Post away brother... post away !!!:D
  15. Jan 2, 2013 at 3:52 PM
    #155
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    When I installed my AP U-bolt flip kit, loosening the stock U-bolts took similar effort as loosening lugnuts. I used a 16" breaker bar. There wasn't any rust in the engaged portion of the U-bolt thread. Mine was NUMMI-built in 2010.
  16. Jan 2, 2013 at 5:27 PM
    #156
    4WD
    Doug
    2004 DC TRD 4x
    Good guess that yours were up to snuff then, like I stated earlier in thread, it may not be all Tacomas, its just been every 2nd gen I've done in my region....
  17. Jan 2, 2013 at 8:30 PM
    #157
    4WD
    Doug
    2004 DC TRD 4x
    Good deal, I can totally see where U bolts that aren't really as tight as they should be could cause vibs,shudders & exasperate axle wrap
  18. Jan 2, 2013 at 9:37 PM
    #158
    4WD
    Doug
    2004 DC TRD 4x
    Out of probably close to 50 Tacomas here that have done my rear spring MOD (resulting in 2.5"-3.5" lift) The only Tacoma that has had any vib issues was mine....:D:eek::) No one else has reported any....(knock on wood) & its been over a year for most..
  19. Jan 3, 2013 at 2:45 PM
    #159
    4WD
    Doug
    2004 DC TRD 4x
  20. Mar 10, 2013 at 7:03 AM
    #160
    NiceTaco
    NiceTaco Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    So is there any kind of definitive answer on this? Any negatives to this that went up to 73ft lbs?
    I am adding a 1" block next week so I want to torque to the proper spec
