UCON available for 09-15!!!
Discussion in 'Performance and Tuning' started by gersus, Jun 7, 2017.
  1. Aug 25, 2017 at 1:36 AM
    #81
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    No dyno numbers all I have to go off of is MAF flow. It's really hot and humid lately so things may change a little in the fall when ambient conditions are more favorable. A little birdie told me g/s*1.18=bhp. I personally feel that calculation may be a little ambitious, but if that is true, then I'm around 371 at the crank.
  2. Aug 25, 2017 at 1:59 AM
    #82
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    That's where I hope to be, are you lifted?
  3. Aug 25, 2017 at 2:14 AM
    #83
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Basically a 2" F/R lift. Tires 275/70/17
    5100 in front @ 1.75 w/ TRD sport coils
    5125 & HS AAL rear
    Oreo Cat[QUOTED] likes this.
  4. Aug 25, 2017 at 4:24 AM
    #84
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Because California hates you for even thinking about it.
    Oreo Cat[QUOTED] and Lord Helmet like this.
  5. Aug 25, 2017 at 4:26 AM
    #85
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Take it to KP Racing, by the horse track, and get that sucker dyno'd. They have a DynoJet.
    So you have the 2.55, Spec-U headers, 4x4 Y-pipe, 3"(?) Catback, CAI(?), and the Ucon.
    I imagine that your truck is around 350-370whp
    Biscuits and loginfailed[QUOTED] like this.
  6. Aug 25, 2017 at 4:57 AM
    #86
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Thanks for the reccomendation. I'll definitely hit them up.
    Correct
    3" (?) = URD MK3
    CAI (?) = AFe Stage 2 Si
    I would be surprised if it's that high at the wheels. Maybe at the crank. Only flowing 315 g/s MAF.
    I'll eventually get it on a dyno. Still need to fix an exhaust leak where the y-pipe slips together on the passenger side and also install that resonator (hopefully tomorrow if I have electricity!)
    Biscuits likes this.
  7. Aug 25, 2017 at 6:19 AM
    #87
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Going down to the 3rd post, you'll notice that you both have similar mods.
    https://www.tacomaworld.com/threads/1gr-fe-f-i-mods-and-dynos.465243/
    You are however with higher boost pressure. Both being here in Houston (sea level), and you with a better set of headers, you are easily closer to the 370 whp mark. Your truck is likely heavier though.
    loginfailed[QUOTED] likes this.
  8. Aug 25, 2017 at 6:41 AM
    #88
    oni06
    oni06 Well-Known Member
  9. Aug 25, 2017 at 9:37 AM
    #89
    Oreo Cat
    2006
  10. Sep 3, 2017 at 12:42 AM
    #90
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    CARB is a certified test. MFG has to pay to get the test and verify that it doesn't impact smog. I keep my stock intake and switch it out for testing. You will also have to remove your 7th injector not sure hot the truck will run w/o it if your tune is set up that way. Probably need an extra map just for smog.
    I've never had the techs look at my ECU. Anyone know if leaving the UCON plugged in will raise any alarms with the OBDII test?
    loginfailed likes this.
  11. Sep 3, 2017 at 4:23 AM
    #91
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I just realized my truck is due for an emissions inspection. I'll do it Tuesday (time permitting) and let you know.
    zerotimeouts[QUOTED] likes this.
  12. Sep 3, 2017 at 4:31 AM
    #92
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
  13. Sep 3, 2017 at 4:44 AM
    #93
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  14. Sep 3, 2017 at 7:58 AM
    #94
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It will pass.
    loginfailed and zerotimeouts like this.
  15. Sep 18, 2017 at 10:10 AM
    #95
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    So, went through this thread, but wasn't totally clear to me. Assuming NA, what kind of benefits might be gained? Mostly performance-wise (surprise, surprise), but if there are others I would be curious. Trying to understand if $1600 is worth it without positive intake pressure..... Sounds like not, but looking for thoughts, opinions, facts.
  16. Sep 18, 2017 at 11:41 AM
    #96
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  17. Sep 18, 2017 at 12:58 PM
    #97
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    :popcorn::popcorn:
  18. Sep 18, 2017 at 1:27 PM
    #98
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  19. Sep 18, 2017 at 7:42 PM
    #99
    gersus
    gersus [OP] Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
  20. Sep 18, 2017 at 7:46 PM
    #100
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine isn't NA but I would think UCON would be helpful if you had I/H/Y/E, due to the self tuning aspect of it. Not sure if it would be $1,600 worth of help, though.
