Unknown Issues... Anyone got an idea?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rocky808, Feb 7, 2020.
  1. Feb 7, 2020 at 11:48 AM
    rocky808
    rocky808 [OP] Member
    Lei
    2016 MGM TRD Sport Tacoma 4x4 - short bed
    New to Toyota. Always been a Ford gal.
    My '16 TRD Sport Tacoma runs great, but I noticed that when I drive up steep hills and get in higher elevation, my truck begins to smoke a little. It comes from the passenger side and out by my wheel well. When I check under my hood, I'll place my hand over the left side of the engine bay and it's a little heated. Anyone got an idea on what it may be?
    Also, my truck's LSD will randomly go on randomly. Anyone got any idea how this shit works and how to fix it?
  2. Feb 7, 2020 at 11:51 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Check the oil level first and keep an eye on it .
  3. Feb 7, 2020 at 11:53 AM
    hellfire0480
    hellfire0480 Well-Known Member
    Long Island
    2019 TRD OR Quicksand
    Eibach Pro lift, MR701, 285/70R17 AT3W, SOS Sliders, Sherpa RR
    Do you notice any smell that accompanies the heat?
  4. Feb 7, 2020 at 11:54 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Could possibly be your timing cover chain leaking. Do a quick search here in the forums to see what I'm talking about.
    With regard to the LSD coming on, not sure what that could be. The forum search is your friend (obviously), but it could be a few things. Might just need a calibration at the stealership or could need new sensors.
    Good place to start might be to see if you have any trouble codes pending in the ECU
    Mikeincal likes this.
  5. Feb 7, 2020 at 12:02 PM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    uphill could possibly be oil in your intake from one of the PCV valves... or an oil drip landing on the exhaust. I asuggest hosing down your trucks engine bat with soapy water, or even better a degreaser.. and I mean get everywhere... rinse it off, let it dry. look underneath, adn on top for anything that could be a leak, take a picture if you see anything suspicious.. then go for a spirited drive up as many hills as you can.. park it.. let it cool (hot exhaust burns suck!), then get underneath, and check for leaks, burn spots on the exhaust, forming drips etc.. with a clean engine it will be fairly noticeable, but you will need a flashlight, and probably pull the engine cover..
    rocky808[OP] likes this.
  6. Feb 7, 2020 at 12:05 PM
    Hal_XIII
    Hal_XIII Well-Known Member
    Chicagoland
    19 Tacoma Trd O/R 4x4 S/B 6spd auto cav-blue
    Bilstein shocks & springs. Method 16in wheels Rigid led fogs 265/75 16 BFG KO2s
    Left side on hills seems like the oil filler tube might be leaking. Check the base of the oil cap, the bottom where the plastic tube connects is leaking. Remove it and put your oil cap directly on the hole. It fits without the extension. Good luck
    rocky808[OP], mgmdclb and Mikeincal like this.
  7. Feb 7, 2020 at 12:37 PM
    rocky808
    Lei
    It kind of smells like between rubber or plastic
  8. Feb 7, 2020 at 12:38 PM
    rocky808
    Lei
    The next day I changed my engine oil and filter and cleaned my entire engine bay. How do I check my transmission oil levels?
  9. Feb 7, 2020 at 12:40 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    How steep are we taking? These trucks, like Jeeps, smoke on inclines.
    shakerhood and Chew like this.
  10. Feb 7, 2020 at 12:40 PM
    Stocklocker
    17TRDORDCSBAT
  11. Feb 7, 2020 at 12:42 PM
    eurowner
    eurowner Duke Sky
    Scoty
  12. Feb 7, 2020 at 12:42 PM
    Mikeincal
    Mikeincal Well-Known Member
    Central Massachusetts
    2017 Sport 4x4 AC
    Nothing special
    rocky808[QUOTED][OP] likes this.
  13. Feb 7, 2020 at 12:43 PM
    rocky808
    Lei
    6,200 ft. above sea level
  14. Feb 7, 2020 at 12:43 PM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    How hot is your front passenger wheel. Could be red herring but LSD is brake related and you could have a messed up passenger caliper that is sticking. That'll get hot, smell, and smoke.
  15. Feb 7, 2020 at 12:44 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    There is no dip stick to check transmission fluid. You need to get the engine up to a certain temperature and then remove a specific bolt/plug under the truck (transmission fluid reservoir) to check the proper level. You can search TW for the exact procedures.
  16. Feb 7, 2020 at 12:44 PM
    rocky808
    Lei
    Stocklocker[QUOTED] likes this.
  17. Feb 7, 2020 at 12:45 PM
    Stocklocker
    17TRDORDCSBAT
    OK I didn’t understand. I thought you were talking about the truck being on a steep hill.
  18. Feb 7, 2020 at 12:46 PM
    pnw.river.junkie
    pnw.river.junkie Well-Known Member
    PNW
    3rd gen Tacomas don't go uphill very well.
  19. Feb 7, 2020 at 12:46 PM
    Stocklocker
    17TRDORDCSBAT
    Could be totally unrelated. Just good to be aware of the incline issue if that’s helpful.
    Are you sure your auto-LSD isnt being triggered by actual wheel spin, or is it happening randomly when you have lots of traction?
  20. Feb 7, 2020 at 12:49 PM
    rocky808
    Lei
    Yeah it's very weird. I'll be at a stop light and once it turns green and its raining, my truck will spin out a little bit and the LSD light will flash and then once the truck jerks the light turns off and the ride is smooth. Is this shit normal? haha. Its kind of irritating smh
