Update: Completed my Memorial Day Grillcraft Install..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ChaseUA, May 31, 2010.
  1. May 31, 2010 at 7:04 PM
    ChaseUA
    ChaseUA [OP] Well-Known Member
    Chase
    Bama
    Present: 2016 White TRD Sport DC Past: 2010 MGM TRD Sport AC 4x4
    Well first things first, I must preface this by saying that this install was not a "smooth" one, as evidenced by my mid-install thread here:
    http://www.tacomaworld.com/forum/2n...tempting-memorial-day-grillcraft-install.html
    Before:
    I proceeded to take out the grill which was relatively easy once I figured out that nothing was holding it in place at the bottom. There are two pushpins and two bolts holding it in place from the top of the grill.
    The bottom bumper was a pain to remove though, there was approximately 6 screws, two fender flares, 4 pushpins and 10 blue "clips" that had to be removed in order to get out. The re-installation was much easier than the removal.
    Middle - everything removed pre-spray painting:
    I then proceeded to tape up and cover everything that did not need to be spray painted and once that was done I used Rustoleum High Heat Black Matte spray paint to paint the radiator and other odds and ends black. I allowed time to dry and then added a second coat.
    Middle 2 - post spray painting:
    I then proceed to install the lower grillcraft, I decided to leave the existing factory "grill" in place for the lower as I thought it looked great with it in place. It was hard to get the holes drilled and then screws inserted without the removal though. If I had to do it over again I would probably cut out the bottom "grill" prior to installing the grillcraft.
    Once this was complete I started working on the upper grill. The install on it was much easier, after the original grill was cut out I was able to hold the grillcraft in place and drill holes exactly where they were needed and the install took minutes to do.
    Finished product:
    I am waiting on a TOYOTA badge and a TRD badge to be delivered that will be installed along with some T-Rex eyelids - this will all hopefully be in place within the next two weeks.
    What do ya'll think?
  2. May 31, 2010 at 7:07 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Sexy. Can i has?
  3. May 31, 2010 at 7:07 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    looks great bro!!!!
  4. May 31, 2010 at 7:09 PM
    ChaseUA
    Chase
    Bama
    Thanks guys. Haven't decided yet if I want to do the horn relocation mod.. I don't think they are noticeable where they are, and kind of afraid that relocating them may make them less effective?
  5. May 31, 2010 at 7:11 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Not that noticeable from the picture you took. Maybe take one outside in the sun with no flash.
  6. May 31, 2010 at 7:12 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    Looks good.
  7. May 31, 2010 at 7:12 PM
    ChaseUA
    Chase
    Bama
    Ill try that tomorrow Krazie SJ.
    The flash wasn't on in any of the photos I took, the glares are from the son reflecting off the paint etc..
  8. May 31, 2010 at 10:37 PM
    teambcw
    teambcw Well-Known Member
    So Cal
    Man that looks so good! I want to do mine so bad.
  9. Jun 1, 2010 at 5:55 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    My opinion is the horn relocation is required only if it really bothers you. Heard many opinions that "you should do it". But left mine alone after doing the install and haven't gone back to move 'em. If I ever do move them, it will be down behind the bumper, and not into the engine compartment though.
    Only time that I notice the horns to any significant degree is when the sun, or a light of some sort, is shining right through the grill.
    I tend to take additional steps only when I decide they should be done. I didn't originally paint the radiator section, but that ended up being quite noticable, so that ended up getting done.
  10. Jun 1, 2010 at 9:18 AM
    ChaseUA
    Chase
    Bama
    Yeah, I am currently leaning toward not relocating them as even today they are not noticable "to me". I'll see how it looks once the emblem/badges are added, maybe they will be a little more of a nuisance at that time?
    At either rate, I am happy with the install, just waiting on badges/eyelids and N-Fab steps to be delivered and I'll be finished modding.........
    for at least a month, haha.
  11. Jun 1, 2010 at 9:47 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Looks great same as mine
  12. Jun 1, 2010 at 10:06 AM
    juiced taco
    juiced taco Well-Known Member
    jordan
    socal
    09 tacoma double cab sport debadged
    debadged, blacked out rear lights, 3 inch lift in front, 2 inch lift in back, bmf novakane 6 20x9, nitto terra grappler, sony xav-60 dvd reciever, jbl audio system, 10 inch image dynamics sub, rear view camera, tint
    great job. i want a new grill sooooo bad!
  13. Jun 1, 2010 at 10:14 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I wouldnt worry about relocating your horns. I think its just mostly for guys that have grill lights either behind their grillcraft grill or behind their satoshi. I had to relocate mine cause I have a satoshi with grill lights behind it. I relocated it behind that battery and it sucks right there!!:mad: I will be relocating it here pretty soon somewhere behind the front bumper. There is a thread on relocating it there and I heard the horns work pretty good from that spot.:cool:
  14. Jun 1, 2010 at 5:17 PM
    ChaseUA
    Chase
    Bama
    Thanks for the info, I was curious how they sounded after being relocated.
    Well I got my TRD badge in this evening, but it is not going to work. I got the kind with the screw on back and the brackets will not fit/align through the grillcraft without cutting and I dont want to cut the new grill. Anyone want to buy it? haha, Now time to order the sticker kind.
  15. Jun 2, 2010 at 5:38 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Can't you just cut off any protrusions and 3M tape it on?
  16. Jun 19, 2010 at 6:31 PM
    ChaseUA
    Chase
    Bama
    Yeah, I could have, but my sawzall bit the dust during the install and I thought the protrusions were cheaply welded on (could see the markings around the bracket) and I thought holding a soldering iron up to it would allow it to "release" (Yes, I was an idiot), to make a long story short, it did help release the brackets, but it also warped the emblem. I've since received the tape mounted emblem in and have it in place - I will try to get update pics soon, but waiting to install eyelids first.
  17. Aug 25, 2010 at 3:05 PM
    usernametaken
    usernametaken Member
    Jeff
    Seattle
    My 'coma
    TRD CAI TRD Exhaust Leather, baby!
    I have a black billet set on its way and, while looking on their install instructions, it looks like they saw off the stanchions for the main grill but leave about a 1/4". Does this help with positioning the new grille?
    Jeffo
    P.S. I was going for the mesh, but since I couldn't find a hoodscoop companion....
