upgrade clutch and flywheel
Discussion in '4 Cylinder' started by TacomaTSP4, Dec 17, 2009.
  1. Dec 17, 2009 at 9:38 AM
    TacomaTSP4
    TacomaTSP4 [OP] Go Big or Go Home!!
    Travis
    Rohnert Park, CA
    i have a 2007 tacoma 4cl 2.7L manual 4x4 and i want to upgrade the clutch and flywheel cause im getting a brand new throughout bearing for free under warranty by the dealership. I was wondering if anyone knew of a good lightweight flywheel and clutch for this model. thanks alot
    Toronto Tacoma likes this.
  2. Dec 17, 2009 at 11:07 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    clutchmasters makes a clutch kit, stage 1, 2 and 3 kits available
  3. Dec 17, 2009 at 3:25 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    yea what about a flywheel...
    i found the clutch for a 2.7L but not a flywheel and clutch masters said it would be $550 for them to make me billet aluminum light weight flywheel
  4. Dec 17, 2009 at 3:38 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    thats not a flywheel just the clutch, i already talked to clutch masters on the phone and they dont mass produce flywheels for 2.7L so they would have to custom make it...
    trying to see if any other companies make a light weight flywheel for a 2007 tacoma 2.7L
  5. Dec 17, 2009 at 3:58 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    what are you trying to say by posting this?
  6. Dec 17, 2009 at 4:03 PM
    AFButters
    AFButters Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
  7. Dec 17, 2009 at 4:03 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    THEY DONT MAKE A FLYWHEEL FOR IT UNLESS I HAVE THEM CUSTOM MAKE IT FOR $550 FOR THE 2.7L.
    I talked to them on the phone. they type that little info of, lf Combined with our aluminum flywheel, this an excellent performance upgrade., into their description because they reuse it for most of their vehicles with the stage 3 clutch kit to let you know that you can MAYBE get an aftermarket flywheel for it
  8. Dec 17, 2009 at 5:43 PM
    Huntr Pat
    Huntr Pat Well-Known Member
    Gilroy,Ca
    99 2.7 xtra cab
    K&N,Warn winch,3"Revtek bilsteins,Marlin Crawler
  9. Dec 17, 2009 at 7:00 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    i would just see if a reputable machine shop in your area could lighten the stock flywheel for you.
  10. Dec 17, 2009 at 7:16 PM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    I run a Clutchmasters clutch on my DD/autocross toy and like it quite a bit. The pressure plate is on the heavy side, however, engagement is very firm and predictable, which makes it great for consistent launching. I would expect their Tacoma application to be a solid choice.
  11. Jun 4, 2011 at 9:51 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I found a centerforce performance clutch kit DF505120, now im looking for a lightweight flywheel...anyone have any luck?
  12. Jun 4, 2011 at 2:25 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
  13. Jun 4, 2011 at 2:30 PM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Haha...not doing it...can't make me!
    I just installed the URD Clutch/Lightened flywheel combo. I love it...no issues or problems...drives great!
    oops 4 cylinder section...doesn't apply
  14. Jun 4, 2011 at 2:31 PM
    VermonterLost
    VermonterLost Well-Known Member
    Devin
    Castleton, VT
    2014 F150
    That's swell, but you have a V6. This is for a 4 cylinder.
  15. Jun 4, 2011 at 2:32 PM
    08pretaco
    az
    Wish there was a flywheel for the 2tr-Fe
  16. Dec 9, 2011 at 3:38 PM
    renn foot
    renn foot New Member
    manual 04
    4 cylender anythings lose revs very quickly, i want to get a lighter flywheel, but im afraid it'll stall out mid shift because it cant hold an idle. im on the streets, not on the track where you are consistently at the top of the power band all the time.
  17. Dec 10, 2011 at 6:11 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    biggest mistake I ever made was putting a lightweight flywheel in my 350Z. IMO lightweight flywheels are great for high speed racing applications although for DD's they make alot of noise and are not the smoothest especially neutral to 1st gear. I would say that they would be a detriment to off roading and rock crawling where you would want the mass and enertia from a weighted flywheel.
  18. Dec 10, 2011 at 5:04 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    TORQUE! would want all I can get with 4-cyl. think you should stay with heavier flywheel.
  19. Jun 4, 2017 at 3:14 PM
    Toronto Tacoma
    Toronto Tacoma Well-Known Member
    Blair
    Toronto Canada
    2017 Tacoma SR+ 4X4 5 speed
    I have a 2017 4-cyl 4x4 with a noisy release bearing, clutch issue and yesterday there was smoke coming from the clutch under a light load backing up an incline at the farm, This thumping noise is only happens when the truck is in neutral and the clutch is not depressed, as soon as i push the clutch pedal in the noise goes away.
    Anyone else have this problemÉ
