Upper Console compass/temp and 2nd grade directions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BiologistsTacoma, Jun 3, 2009.
  1. Jun 3, 2009 at 7:59 AM
    BiologistsTacoma
    BiologistsTacoma [OP] Homer: Me fail english? That's unimpossible!
    Charleston, South Carolina
    06 TRD 4x4 Raceway Blue Tacoma
    brush guard, 18 in 4x4 Chrome rims, new in-dash receiver
    Ok...I loved how everyone helped me out with the tire pressure light so I'm going to try this. My upper console light went out that displays the temp/compass/direction. I know you can go through the sunglass holder and take that screw out. I'm a girl and have no idea how to do sophisticated electrical work. I can solder wires so that isn't a problem but I'm not sure how to check wires or what to do after I unscrew the screw from the sunglasses holder. 2nd grade directions would be lovely if anyone wouldn't mind and has had this problem:) Or...could it just be a bad bulb? Much obliged!:eek:
  2. Jun 3, 2009 at 8:02 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    be careful removing the console. There are two clips that hold the front of the console up after you remove that screw. If you pull straight down, you don't have to worry about breaking them. When I pulled mine down, I broke off the clips and now my console has some self tapping screws holding it up.
  3. Jun 3, 2009 at 10:17 AM
    98tacoma27
    Ben
    Not Beech Creek
    Here are very well detailed pics and explanations for this fix (kudos to SS)
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/18497-overhead-console-fix.html
  4. Jun 3, 2009 at 10:26 AM
    BiologistsTacoma
    Thanks! That should help...will let you know this weekend if its a disaster or a miracle;)
  5. Jun 3, 2009 at 10:32 AM
    98tacoma27
    Ben
    Not Beech Creek
    I am voting miracle. I save disasters for Mondays.
  6. Jun 3, 2009 at 5:30 PM
    EXPI
    EXPI Member
    Phoenix
    Tocoma PreRunner
    :cool: Yes take the one screw out and check for the two silver clips
    that help hold the console in place. If in doubt go to a body shop
    and have a tech show you. Good luck.
