upTOP Overland Racks and Accessories - NOW WITH FREE SHIPPING (CONUS ONLY)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by upTOPOverland_Drew, Mar 15, 2019.
  1. Nov 23, 2020 at 8:46 PM
    #3621
    sparcus
    sparcus Member
    Mark
    On the bravo rack, is there enough space between the load bars and roof to slide yakima ski box jaws underneath?
  2. Nov 24, 2020 at 7:03 PM
    #3622
    Adk46er
    Adk46er Well-Known Member
    Upstate NY
    2021 DCLB MGM
    OEM bed mat Redarc Liberty brake controller Softopper US Truck Cap Rack Predator steps Tailgate inserts Bumpershellz Rear SumoSprings
    Why hasn’t anyone made an adjustable height bed rack? (Excluding Thule & Yakima) :notsure:
  3. Nov 25, 2020 at 5:37 AM
    #3623
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    I mean, theoretically the TRUSS Softopper one is adjustable.
    Piretti16 likes this.
  4. Nov 26, 2020 at 6:07 AM
    #3624
    TravisMD
    TravisMD Well-Known Member
    2020 DCSB TRD OR Black
    upTOP Bravo Rack BAKflip G2 Tonneau Cover
    I'm debating between the upTOP Bravo, and a Prinsu rack. How is the road noise with the upTOP? Any information or differences/preferences between the two?
  5. Nov 26, 2020 at 7:02 AM
    #3625
    DevTom
    DevTom Well-Known Member
    Tommy
    Chesapeake Virginia
    2018 Cement DCSB TRD OR
    From reading this thread and watching the Bravo install video, the road noise seems to be good. The front fairing is shaped like a V to cut the wind and doesn’t touch the roof of the truck.
  6. Nov 26, 2020 at 7:04 AM
    #3626
    SubaruTheTacoma
    SubaruTheTacoma SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    HELLA Horns BP-51 ARB Summit SCS Ray 10 And many many others
    Road noise is almost nothing I love this rack I highly suggest going this route. You can find plenty of forums about problems / issues with the other brand.
    here you can go through this post and find nothing but awesome stuff
    pros:
    Customer service is unreal these guys are so on top of it
    Quality top notch
    Easy install
    Handles ( you think this would be over kill but I use them so much definitely one of the better features)
    Lighting options out the ying yang
    Compatibility (I put Thule snowboard rack on it 0 mod needed)
    Easy to remove (yes sometimes this might need to happen)
    I’m sure there are many more but that’s enough for now
    cons:
    people stop you and ask about the rack all the time
  7. Nov 26, 2020 at 7:22 AM
    #3627
    EricL
    EricL Tomahawk Chopper
    Greenwood, SC
    2015 Slowmobile
    SOS Offroad Concepts Armor
    I have zero road noise, but I have an Alpha, not a Bravo.
  8. Nov 26, 2020 at 7:29 AM
    #3628
    Landpirate
    Landpirate Strong like horse, smart like tractor
    North Texas
    2018 Tacoma BBP SR5 4x4 DCSB
    OME HD leafs, 5100s, CaliRaised skids, UpTop Overland Bravo, KB Voodoo rack, Overlander RTT/awning, DECKED
    I don't have a Prinsu, but I can say with the Bravo there is NO noise. Even with stuff mounted I have not had any noise at any speed.
    NonTraditional likes this.
  9. Nov 26, 2020 at 7:32 AM
    #3629
    Landpirate
    North Texas
    Agree with the above. And I'll add that when I bought mine I got two handles at first because I wasn't sure how useful they would be. I ended up buying another pair, and I'll probably get a third pair for the bed rack.
    Lighting is a plus, waiting on my order of scene pods to get here, hopefully soon.
    Compatibility is great, I've got Rago and KB Voodoo stuff on mine with no need to mod anything.
  10. Nov 26, 2020 at 7:36 AM
    #3630
    TravisMD
    Awesome bros, thanks. Sounds like you sold me on the Bravo for $525 all in. So you'd recommend the handles and the scene pods? Where do you wire the lighting to? I see they state a 12v storage system, but I didn't see any other information.
  11. Nov 26, 2020 at 7:42 AM
    #3631
    Landpirate
    North Texas
    If you have sliders the handles are great to be able to get into your roof rack. Even if you have the OEM Predator steps I think they would be helpful. I really wasn't sold on the handle idea until I actually installed the first pair. If you have or plan on running an RTT they are great to have for more stability in setting up your tent fly (depending on model).
    I'm waiting on my scene pods, but one thing that sold me on these is the angling of the mounts. Much better to have the throw down at the ground rather than straight out for what I want them for.
    On wiring, I routed mine from an aux fuse panel up the windshield channel on the driver's side and then into the rack. Even with the Bravo there are plenty of places to run some zip ties to secure the wiring. Another option is the KC Hilites wire holder. You could run this up the side of the windshield if you're worried about them coming loose, and you can also use it inside the rack if you wanted.
    https://www.kchilites.com/universal-wire-hider-kc-6300.html
    Taco_Traplord likes this.
  12. Nov 26, 2020 at 8:01 AM
    #3632
    Landpirate
    North Texas
    @TravisMD this might help.
    I tucked the wiring under the soft rubber corner at the bottom of the windshield, and routed around the hinge and through a box channel in the upper fender piece to keep it clear of the moving parts and help secure the bottom. Then you just push the wire into the channel going up. I routed it straight up to the front corner of the rack and zip tied it.
    Once at the rack, I secured the driver side using the cuts at the front edge of the side plate, and then secured the branch around the traction mat mounts in two places, routing the wire across the front bar in the central channel.
    The passenger side is zip tied down as well. Once the scene pods get here, there will be a little more to secure the wiring to.
    BOMBS likes this.
  13. Nov 26, 2020 at 11:02 AM
    #3633
    TravisMD
    Awesome, thanks for the picture. That looks great and it tucked nicely.
    So you added a fuse box to your battery?
    Landpirate likes this.
  14. Nov 26, 2020 at 12:24 PM
    #3634
    Landpirate
    North Texas
    Thanks.
    Yes, I added a cutoff breaker and an aux fuse panel.
    All my lights will run through that with relays on the relay holder, and only the switch wires going inside the cab.
  15. Nov 26, 2020 at 2:43 PM
    #3635
    Crsrey4
    Crsrey4 Member
    2020 TRD OR Tacoma
    Where did you get it at for $525? Even with the 10% discount i still don't see the price that low?
    itzyoboipaul likes this.
  16. Nov 26, 2020 at 7:43 PM
    #3636
    TravisMD
    Got ya. I'm freaked out about messing with the electrical at all. But I assume that's the only way to power the rock lights. Was it easy enough to install?
    Landpirate[QUOTED] likes this.
  17. Nov 26, 2020 at 7:44 PM
    #3637
    TravisMD
    Talk to @Truck Brigade. They were very responsive and informative.
  18. Nov 26, 2020 at 7:56 PM
    #3638
    kerner
    kerner Well-Known Member
    2020 Magnetic Gray TRD Offroad
    Most likely going to be ordering an Alpha tomorrow and wondering about the fairing cutouts for lights. I don't have any immediate plans for lights up high but who knows what the future holds. How difficult is it to remove and get cutouts done if I change my mind next year
  19. Nov 26, 2020 at 8:43 PM
    #3639
    Landpirate
    North Texas
    This is the MOAT on fuse blocks. Some really advanced, some relatively simple. Dive in, figure out what you want to do, and find somebody with a setup that does that. Use theirs as a plan.
    https://www.tacomaworld.com/threads/show-off-your-aux-fuse-panels.308677/
    Here's one on roof LEDs and how to wire them, link in thread to Youtube video.
    https://www.tacomaworld.com/threads/light-bars-on-roof-rack.642617/#post-22226164
    This thread has lots of good info on building a more advanced panel.
    https://www.tacomaworld.com/threads/diy-build-and-install-a-bussmann-rtmr-fuse-relay-block.399454/
    Here's a thread on wiring.
    https://www.tacomaworld.com/threads/diy-wiring-after-market-lights.6525/
    Just take your time, be patient, do your research. There is somebody on here that has done what you want most likely. You can learn from what people have tried and sometimes messed up. Lots of good info and starting points here.
    Speaks05 and GASH like this.
  20. Nov 27, 2020 at 5:00 PM
    #3640
    TAF_Taco
    TAF_Taco Well-Known Member
    Patrick
    Lacey, Wa.
    17 TRD Sport Access Cab
    17" Method NV w/BFG KO2 CVT Rainier RCI bed rack Empyre Off Road grille Cali Raised bumper light bar/fogs
    I need to finish setting everything up, but got the maxtrax on.
    BOMBS, BigGuy, TinyTech626 and 3 others like this.
