URD MAF calibrator help.
Discussion in 'New Members' started by nvtaco09, Mar 4, 2012.
  1. Mar 4, 2012 at 12:44 PM
    nvtaco09
    nvtaco09 [OP] New Member
    Matthew
    Spring creek, Nv
    09 tacoma access cab
    3" lift 265/70/r17 K&n 63 series intake URD MAF calibrator
    I know when installing the maf calibrator it says to solder it, but has anyone used butt connectors instead??? And if so had any problems?
  2. Mar 4, 2012 at 12:47 PM
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
  3. Mar 4, 2012 at 12:54 PM
    GregLee98
    Greg
    08 Tacoma TRD Sport
  4. Mar 4, 2012 at 12:56 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Might be a good idea to solder it. .02 ohms difference in resistance might actually effect the MAF
  5. Mar 4, 2012 at 2:25 PM
    nvtaco09
    Matthew
    Spring creek, Nv
    Thanks guys
  6. Mar 27, 2012 at 6:27 AM
    harmfuljays
    harmfuljays Member
    J
    Colorado
    07 Tacoma Double Cab S
    aFE Stage 2, Borla Cat Back Exhaust
    I initially used butt end connectors. They came loose and threw a short. My advice would be to take the time and solder.
  7. Mar 27, 2012 at 6:38 AM
    GregLee98
    Greg
    08 Tacoma TRD Sport
    I soldered mine. I did not cut the wires, just peeled back the sheath and soldered onto it. Cut the one wire you have to splice in between the ECU and the MAF sensor. Works great, no warning lights or issues with soldering.
