V4 to v6 swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LUISFER, Aug 18, 2010.
  1. Aug 19, 2010 at 1:55 PM
    #41
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Yeah, since the engine and trans are probably several thousand alone, I'm sure the answer is "not cheap." Would totally rule though.
  2. Aug 19, 2010 at 1:58 PM
    #42
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Just trade your truck, you will need more than a new engine. You will also need a new tranny, the lines in your engine bay will be replaced with longer ones. You will have to cut the old motor mounts and replace them with new ones ETC.
  3. Aug 19, 2010 at 2:01 PM
    #43
    mjp2
    mjp2 Living vicariously though myself Moderator
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    If you're paying someone, expect it to be in the $10,000 - $20,000 range depending on attention to detail and where you get the engine and transmission from. The rear axle will also need to be swapped to handle the power. Custom driveshaft, mounts for everything, wiring, etc., etc.
    It's a big job.
  4. Aug 19, 2010 at 2:10 PM
    #44
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    I am a big fan of engine swapping... Back in the 70's and 80's model anything. Today there is just wayyyyyyy too much BS to go swapping a 4 to a 6 in a Taco when they come off the line like that everyday.
    If you're gonna do a swap put a Jet engine in that bitch. Now thats original...
  5. Aug 19, 2010 at 2:12 PM
    #45
    GEARAHOLIC
    GEARAHOLIC Well-Known Member
    KELLEN
    PASO ROBLES, CA
    07 Black on Black BEAST
    Dear OP AKA:anonymous:I know that this is just :deadhorse: but this kind of ignorance makes me feel:puke: :annoyed::frusty::sick:...Im pretty sure if you use the :pccoffee: and read threads on TW, eventually you will break the :ballchain: of ignorance and we can all :rockband::cheers: in the meantime, PLEASE refrain from further :rasta:I know you enjoy watching :cookiemonster: but I think school might be a better use of your time...lets start with this lesson... your tacoma does not have a v4...
  6. Aug 19, 2010 at 2:15 PM
    #46
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    And probably cheaper than the V8 also!
  7. Aug 19, 2010 at 2:22 PM
    #47
    GEARAHOLIC
    KELLEN
    PASO ROBLES, CA
    guys get real...a V7 swap is way to much $ for him. He can just pick up two pistons at NAPA and duct tape them on...FTW!!
  8. Aug 19, 2010 at 2:29 PM
    #48
    Pugga
    Massachusetts
    F-150 Mod
    Cheap and real easy install... Performance results may vary...
  9. Aug 19, 2010 at 2:32 PM
    #49
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Now that'd be something to see! Just gut the damn thing and "start over"...with a jet!
  10. Aug 19, 2010 at 2:42 PM
    #50
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    Op how many miles on your i4. My truc really woke up after the first 5k miles. ( after break in and a few small mods like drop in filter, exhaust, removing secondary filter and synthetic oil all around.)
    edit: still not a v6 nor power of a v6 but it runs good. Plenty of power for normal driving.
    My last cars were a 6.0 2500hd and a 05 6.0 GTO. So I like power but the Tacoma is plenty for what it is
  11. Aug 19, 2010 at 2:51 PM
    #51
    LUISFER
    LUISFER [OP] Member
    TX
    2010 TACOMA 4X4
    Yeah that is sweet!! Unfortunately business is slow at the moment. When it picks up it might be an option.
  12. Aug 19, 2010 at 2:53 PM
    #52
    LUISFER
    LUISFER [OP] Member
    TX
    2010 TACOMA 4X4
    As soon as I pay it off, I plan to get a car. Then the Tacoma will just be my toy. That was the plan all along.
  13. Aug 19, 2010 at 2:54 PM
    #53
    Yoytoda
    Roland
    completely stock
    what kind of toy? Offroad? Then the 4 will suite you fine.
  14. Aug 19, 2010 at 3:00 PM
    #54
    LUISFER
    LUISFER [OP] Member
    TX
    2010 TACOMA 4X4
    Mine is still new. Its got around a thousand miles on it. I was just disapointed with my first drive around the sand dunes.
  15. Aug 19, 2010 at 6:37 PM
    #55
    joes06tacoma
    Joe
    Central Coast, CA
    Yup, do the supercharger. I break into a sweat thinking about all the little details involved in a v6 swap. Plus, that way it's unique. You swap a 4.0 into the truck you have, you have nothing to show off. Noone's gonna be impressed cuz it's just a stock setup. All that work and nothing to brag about!:eek:
  16. Aug 19, 2010 at 7:29 PM
    #56
    Boring
    Boring This space intentionally left blank.
    Arizona
    5-lug regular cab
    More than a few.
    A really impressive build would be to somehow get dual VVT-i and then add a turbo. Maybe build things up a little first, if you're going through that much trouble.
    The technicalities are way over my head, but I'm guessing you'd exceed the V6 baseline power without replacing the transmission, engine mounts, etc... The price might be under $6000 if some of the labor was discounted. Just a thought.
    Edit: I thought the Venza had the same engine, since the displacement was the same. Ass-u-me-d.
  17. Aug 19, 2010 at 7:45 PM
    #57
    Barnone
    Barnone Guest
    Keep the V4 and add the V6 and then you will have the V10.
  18. Mar 11, 2013 at 1:45 PM
    #58
    nik.moretto
    nik.moretto Member
    nathan
    fort mcmurray
    09 taco sr5 2TR
    URD
    This made my day hahaha
  19. Mar 11, 2013 at 4:13 PM
    #59
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Never start vast projects with half vast ideals. It's not worth it make the little engine stronger there is too much to swap to fit a V6.
  20. Mar 11, 2013 at 4:21 PM
    #60
    Pugga
    Massachusetts
    F-150 Mod
    Wholly thread revival Batman :D
