V6 Timing belt, what else?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Grund72, Aug 5, 2018.
  1. Aug 16, 2018 at 10:57 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    There needs to be a timing belt sticky. LOTS of questions about it and what else to do. Maybe just a list of links from older threads on the subject will suffice. Not bagging on OP as I just went through it a year ago.
    zach141b and burntkat like this.
  2. Aug 17, 2018 at 5:17 AM
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
  3. Aug 17, 2018 at 8:08 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Lots of great info here, folks. I am picking up a 97 today with 217K on the clock, timing belt will be coming up again soon. I believe it's 10K over at present, how much can go wrong if I baby this for a month or two til I can get to it? I have heard that this is not an interference engine, so of course losing a timing belt would leave me on the side of the road, but being a non-interference engine I wouldn't expect any major catastrophe.
  4. Aug 17, 2018 at 11:51 AM
    zach141b
    Zach
    Louisiana
    Obviously no guarantees in life, but lots of people have gone past the recommended change interval...
    burntkat[QUOTED] likes this.
  5. Aug 17, 2018 at 11:53 AM
    1997tacomav6
    Denver
    10k over is ok
  6. Aug 17, 2018 at 12:00 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    I just did valve cover gaskets on a 1st gen Tundra with the 4.7 thats has 300k on the original TB and water pump. And I am doing a 2002 Taco next week that has 175k and never had the belt changed. Both are original owners. Some toyota owners think they can just drive them forever on just oil changes, and it sure seems that some of them are right, LOL.
    Should mention the only reason the tundra owner wanted the covers resealed was that the smell of burning oil on the exhaust manifolds gave them headaches, LOL. They werent interested in the TB job.
  7. Aug 17, 2018 at 12:37 PM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Interesting thread... a lot things to change while you're there !
    wow... a lot of quite of expensive tools to do this job smoothly....
    A lot still running with the original WP TB.... ( I'm one of them ) ...
    If the budget allow me ( not right now ) , then the plan is to tackle this either by
    09-2020 ( 93,000 miles mark) and \ or
    02-2022 ( 115,000 miles aprox) on the 20th anniversary of the truck plus shocks , leafs , etc , etc
    ! :spending:
  8. Aug 17, 2018 at 1:08 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    2002Tacoma4x4 likes this.
  9. Aug 17, 2018 at 7:42 PM
    04tacoma trd
    04tacoma trd Well-Known Member
    End of day 2. Here is my list of things to buy outside of what comes in the ebay kit: 1) fan bracket, Aisin p/n FBT004, 2) AC compressor idler pulley, p/n 88440-04040, 3) radiator drain plug o-ring 90069-08019, 4) I also replaced the two hoses that go to the oil cooler. 5) I also replaced the radiator cap. 6) dipstick tube o-ring. Don't forget to buy a new crank pulley bolt.
  10. Aug 17, 2018 at 11:51 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I did mine for the first time last month, at 214K mi. Mine didn't look like it was going to snap anytime soon but it also depends on the climate the truck lives in.
  11. Aug 18, 2018 at 6:54 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    What is the actual service interval on them? I have found varying info.
  12. Aug 18, 2018 at 7:37 AM
    Grund72
    Grund72 [OP] Active Member
    Northern VA
    '03 V6 4x4 AC TRD
    90 is what my FSM says.
  13. Aug 18, 2018 at 11:19 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Awesome, thank you sir!
  14. Aug 18, 2018 at 12:59 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Early on Toyota said 60k then soon upped it to 90k. That's still pretty conservative as you might be noticing. The change might coincide with the early upgrade of the crank pulley bolt and it's torque being upped from 184 to 217 lbs, another source of confusion.
  15. Aug 19, 2018 at 3:57 AM
    #35
    zach141b
    Zach
    Louisiana
    I don't know if those kits come with that bolt? It's intended for one-time use.
    1997tacomav6 likes this.
  16. Aug 19, 2018 at 8:21 AM
    #36
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    No, not a one time bolt as far as I know. Just use the original. I did my TB at 160K and there were no alarming issues. I did all the standard stuff while in there too.
    EDIT: I was wrong (read below). Replace the bolt. :eek:
  17. Aug 19, 2018 at 8:28 AM
    #37
    04tacoma trd
    Toyota says to replace the crank bolt. Yesterday was day 3 of my project. We got the new belt on, the crank pulley installed and the bolt torqued. Now, just waiting on Rockauto to deliver my new Aisin pulley bracket. Hope to finish the project on day 4.
  18. Aug 19, 2018 at 8:36 AM
    #38
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Well I stand corrected! Thanks for that! Edit to my last post, I had TOYOTA do the TB replacement at 160K, so I'm sure they replaced my bolt and I didn't know.
  19. Aug 19, 2018 at 9:05 AM
    #39
    Dirty Pool
    99 XCAB V6 MT TRD
    Toyota does say that, they "say" lots of stuff. I would say it's more of a "better safe than sorry thing", it is a critical fastener after all. There is a fair number of cases of the bolt loosening (for numerous reasons) so Toyota could be just trying to cover all the bases.
    I have done a bazillion 1st gen t-belts over the decades. Half a bazillion I reused the bolt the other half were replaced, never a problem. Several of the trucks are now on their 3rd belt with the original bolt including mine and I use thread locker every time. These are not "torque to yield" fasteners. I have inspected, measured and compared new to old 6 ways from Sunday.
  20. Aug 19, 2018 at 3:33 PM
    #40
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Good info on the bolt. I was going to suggest if there is any concern, why not just get a bolt from ARP and be done with it? It's basically an aerospace-grade fastener grade 12 or something equally overrated to our purpose
