vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 12, 2020 at 2:56 PM
    #6521
    Idahotaco88
    Idahotaco88 Well-Known Member
    Steven
    2017 black AC OR
    Kings 2.5 with adjusters, icon rxt stage 2. SCS stealth blue on 35s
    Ok I gotcha now ha sorry! Yes it worked with just going to 5k
    Mooseditty17[QUOTED] and AODRN like this.
  2. Oct 12, 2020 at 3:00 PM
    #6522
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    @Mooseditty17 is the latest tune you're working on 87 or a higher octane. Just loaded your Perf_9.29 this morning on my pretty much stock OR auto. If your Beta tune for 1st gear fixes is based off that tune, I'll give it a shot, but can't give feedback till tomorrow, got a local debate to watch shortly
  3. Oct 12, 2020 at 3:04 PM
    #6523
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    That's interesting... @GPatriot, didn't you say you had to do both, or did you not try it with just raising the 4k to 5k? I know that the throttle to request tables do certainly enhance pedal feel. That is what @OVTune adjusted to make the THX files (enhanced throttle). I was just curious if the adjustments I had in my latest files was going to be enough that I would only have to do the 4K-5K mod. I had my pedal TOO TOUCHY before, and it made shifts feel shitty (to me) and in some situations made the truck jerky because I would move back and forth when the gas was hit, which in turn moved the throttle enough to exacerbate the issue! Kinda funny that it was that sensitive, but honestly no fun to drive.
    SO... bottom line, I should get tire shredding first gear POWER, from just raising my 4K values to 5K and not have to mess with WHAT I LIKE for a throttle to Airload request table. THAT'S AWESOME!!! Now only if I could flash it... :frusty:
  4. Oct 12, 2020 at 3:09 PM
    #6524
    Mooseditty17
    AJ
    WI
    Well I posted the last two variations a couple days ago. One is a Premium and one is Regular. Otherwise they are the same thing. I'm going to go back and add this 1st gear mod once I can validate it works right in my truck. Unless people just want to try it out anyways.
    Edit: I generally don't just add newly discovered things to my already posted tunes. I make updated tunes. Just because I'm not sure how they are going to affect the old tune. Might make it shift different, or the throttle may become wonky.
    DakoTaco[QUOTED] and wahoobie like this.
  5. Oct 12, 2020 at 3:16 PM
    #6525
    DakoTaco
    North Coast
    2016 MGM OR Tacoma
    I'm running the regular because I just filled up with that. I can wait, no pressure, pretty impressed with what you've done already, put about a 100 miles on it, various areas & speeds. Can tell difference from the stock 87 2.0
  6. Oct 12, 2020 at 3:17 PM
    #6526
    Idahotaco88
    Steven
    2017 black AC OR
    Might give it a shot but it’s way less sensitive at 1/4 throttle then if you up your air load/request table. The 5k gets you a little more low end.
    Also my exhaust sounds a little to crackly for me after the air load adjusted that’s what made me want to look at the afr. Does anyone know how to get the crackle to go away ? Sounds to much like a wound up Honda
  7. Oct 12, 2020 at 3:21 PM
    #6527
    Mooseditty17
    AJ
    WI
    The 9.29 tune is more or less the same as the latest tunes I most recently posted. I just spent more time tweaking the shifts and throttle to my likings. I also added Gear Lock. I absolutely fell in love with Gear Lock. (Thanks again for that @ForceOfG) It's not a night and day difference, but a difference none the less. The Premium option was a big deal for some, so I added that as well. This first gear mod is going to be huge is it's half as good as some of the boys are saying. To be able to actually utilize first to it's full potential will wake these little monsters up. I hate the neutered feel of these trucks off the line. Otherwise I think they hold their own rather well.
    MDFM31 likes this.
  8. Oct 12, 2020 at 3:24 PM
    #6528
    DakoTaco
    North Coast
    2016 MGM OR Tacoma
    I agree, we all know we are driving a V6, but it has more to offer that Toyota saw fit to allow it to have.
    Mooseditty17 likes this.
  9. Oct 12, 2020 at 3:28 PM
    #6529
    DakoTaco
    North Coast
    2016 MGM OR Tacoma
    So far on your tune I was driving thru 20mph residential zones up to 70mph roads, the shift points worked good on mine, plus you smoothed out that YZ like surge at 3500rpm. Very nice
  10. Oct 12, 2020 at 3:37 PM
    #6530
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    Have you had a chance to log anything? I haven't figured all that out yet but I assume it will show a running tab of A/F. If I can ever get a day to play with my truck I might be able to contribute
  11. Oct 12, 2020 at 3:37 PM
    #6531
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    so the stock 2018 04A61 Phase Duty 2 Base Voltage 13.6 value is 67.203, which is obviously significantly lower than the 2016-17 models. What have people put for this value when editing for AGM? Did you jump all the way up to 102.296 to match the change from the 97.xxx value in the Phase Duty Base Voltage 13.6 table? or go with a smaller number?
  12. Oct 12, 2020 at 4:00 PM
    #6532
    Shellshock
    Iowa
    I added 20 (87.203)
    WHTLTNG and mZiggy[QUOTED] like this.
  13. Oct 12, 2020 at 4:04 PM
    #6533
    mZiggy
    mZiggy Honey badger
    Marc
    I suspected as much
    WHTLTNG likes this.
  14. Oct 12, 2020 at 4:20 PM
    #6534
    mZiggy
    mZiggy Honey badger
    Marc
    I'm assuming you also left PD1 alone/stock like with our own alternator settings? The 2018 one is like 14.xxx lol
  15. Oct 12, 2020 at 4:37 PM
    #6535
    Shellshock
    Iowa
    Correct
    mZiggy[QUOTED] likes this.
  16. Oct 12, 2020 at 5:03 PM
    #6536
    WHTLTNG
    WHTLTNG White Lightning
    Here are both for comparison. Many are identical, some are close, a couple are far off.
    Look at Phase Duty 2 Base 13.6 and Phase Duty 1.
    04A61
    04B14
  17. Oct 12, 2020 at 5:09 PM
    #6537
    su.b.rat
    su.b.rat broken truck
  18. Oct 12, 2020 at 5:12 PM
    #6538
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    You rock!!!
    I'll try the premium version next week once I get back home from this trip....
    How is Gear Lock initiated - via the standard OVTune sequence?
    Technique likes this.
  19. Oct 12, 2020 at 5:29 PM
    #6539
    Mooseditty17
    AJ
    WI
    Yes. Flip it to SMode the press ETC Pwr
  20. Oct 12, 2020 at 6:02 PM
    #6540
    banjoist13
    banjoist13 Well-Known Member
    Ian
    Humboldt County, CA
    2016 Off-Road 4x4 Manual Transmission
    BAMF Alumisteel front bumper, BAMF dual swing high clearance rear bumper, RCI full skids, C4 Fab Rock Sliders, Rago Fab LCA skids & rear shock mount skids, Method Trail 701 Wheels, ARB dual onboard air system under hood, Taco Tunes speaker system, Rago fabs center consol MOLLE, Weboost Drive Sleek OTR, SDHQ Billet Battery Terminals, Gofast Camper, Morimoto XD headlights and taillights, Accutune custom tuned Fox 2.5 adjustable front w/650lb Eibach springs and rear shocks, Deavers stage 3 leaf springs, Martin off-road camper rack, Cammo & Covers Tactical Seat covers,
    Interesting, wondering why that is.
Thread Status:
