vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 27, 2020 at 10:28 AM
    #7261
    DownhillDragon
    DownhillDragon Well-Known Member
    Brody
    Austin, TX
    2017 Tacoma TRD Pro AT Cement - POWERTHIRST v2.4 Tuned
    POWERTHIRST Tuned - My Custom OVTune SSO Slimline Bumper with Stage 2 Kit + BajaDesigns 20" Light bar with Amber Backlight + Smittybilt Winch x2o 10,000lb Synthetic CaliRaisedLED Step Edition Rock Sliders SUSPENSION FRONT A.D.S. - 2.5 Adjustable Dampening Remote Resi Fronts Dirt King Upper Control Arms SUSPENSION REAR A.D.S - 2.5 Smoothie Piggy Back "Rear" Shock With Compression Adjuster Deaver Leaf Pack Cab Mount Relocate by Triple-C Chop Shop, Lago Vista, TX Nitro Gear 5.29 BFG KM3 35x12.5x17 Fuel Rebel6 17" Wheels + Full-size Spare + Rhino-Rack Spare Wheel Strap 4x Rigid Cube Ditch Lights + Cali Raised Ditch Light Hood Mount Brackets + Cali Raised Ditch Light Extension Brackets + 3x Cali Raised Switches + Light Switch Mount Bracket Snugtop Camper Shell with Carpeted Ceiling and Mounting Tracks Prinsu Top Rack and Cab Rack Hi-lift Jack + Hi-lift Jack Mount on roof DEFEND INDUST Recovery Traction Tracks (knockoff Maxtrax) Trimax ST30 Trimaflex Spare Tire Cable Lock (Round Key) 36" x 12mm K&N Intake Canvas 270 RV Awning Rooftop Sun Shelter + Prinsu Awning Brackets Fire Extinguisher w/mount Campbell Hausfeld FP209499AV - 3 Gallon Air Compressor
    Thanks, yall are awesome. Got some nice light reading ahead!
  2. Oct 27, 2020 at 10:29 AM
    #7262
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    This stuff is both fun and empowering!
  3. Oct 27, 2020 at 11:41 AM
    #7263
    mos
    mos Active Member
    North Carolina
    '20 DCSB TRD OR (Barcelona Red)
    So... I'm expecting some lag between this upcoming tuner release and availability of the tune pack for 04B91. I'd really like to play around with tweaking the 04B91 stock tune ahead of then. Looking for detailed guidance on how to eliminate the Atkinson cycle, how to tune for premium fuel, how to tune for better throttle response, etc.
    What's the viability of taking select tweaks from the Prem SFOB tune (which currently breaks my truck when flashed) and porting them into the stock tune?
    Like... how do you compare two vft files in the tool to highlight the differences? Sorry to ask, but its not in the documentation anywhere.
    Thoughts? Specific tune recommendations?
    mos
  4. Oct 27, 2020 at 11:43 AM
    #7264
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I believe @OVTune said that for at least the current vF version, we do not have enough map access to create FOB tunes from the Base or Stock files?
    You could follow along with @Mooseditty17 's tweaks, as folks seem to believe his tunes get performance hits.
    Mooseditty17 likes this.
  5. Oct 27, 2020 at 11:50 AM
    #7265
    DownhillDragon
    Brody
    Austin, TX
    hey guys, i'm trying to find that link that has the 2.0 VFT files. I had the link, can't find it, and i'm going crazy trying to find it. Going to flash the stock 2.0 to a buddy's 04C20, but I can't find the file repository for the life of me!
  6. Oct 27, 2020 at 11:50 AM
    #7266
    mos
    mos Active Member
    North Carolina
    Okay. Does anyone have a tune file out there for 6MTs which has tuned throttle response and other good tweaks?
    Also... is it possible to do a comparison in the tool between two open files? Using 1.2.5.1 currently.
    mos
  7. Oct 27, 2020 at 11:51 AM
    #7267
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Manitoba
    3G, Tuned
    I’m a believer ! :bananadance:
  8. Oct 27, 2020 at 11:54 AM
    #7268
    mos
    mos Active Member
    North Carolina
    Aren't most of his tweaks for ATs?
    mos
  9. Oct 27, 2020 at 12:05 PM
    #7269
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    There are bits and pieces of how to tune throttle in this thread, but for the most part these are the same details everyone is waiting for.
  10. Oct 27, 2020 at 12:17 PM
    #7270
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The top blog post here is AT 2.0 Base Full, not final:
    https://www.ovtuned.com/blogs/news?page=2
    They are not editable. You have to ping @OVTune for a editable VFT Tune Pack after Unlocking the ECU.
    I have been trying to keep the current MT stuff here as this thread is really crowded with AT tuning mumbo jumbo:
    https://www.tacomaworld.com/threads/vf-tuning-for-manual-transmission-3rd-gens.687939/
    The Compare function works, but it is a bit too sensitive at the moment.
    Hell no! The MT is transformed with the 2.0 goodness and a couple edits!
    :burnrubber:
  11. Oct 27, 2020 at 12:25 PM
    #7271
    mos
    mos Active Member
    North Carolina
    Thanks, Tony. I'll check out the thread and see if I can't pull some tweaks out of MDs work.
    Not sure what you mean by the 2.0 comment. I flashed what I think is the 2.0 "stock" tune for 04B91 (89663-04B91 STOCK.vft), which Rafael sent when I unlocked my install for my ECU. Is that different than the factory tune? Meaning, is it the 2.0 tune? I also bought the tune pack but none of those tunes work with 04B91 yet.
    Confused...
    mos
    tonered[QUOTED] likes this.
  12. Oct 27, 2020 at 12:29 PM
    #7272
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    You asked if most of the tweaks were for ATs. There were a large number for the engine, which makes it perform and drive a lot better as well as improving MT shift smoothness, and the MT tunes have specific features. See the second blog post on this page:
    That is 2.0 Stock tune is 04B91 Stock, if you ever want to go back to stock. It seems that you do not have any OV Tunes yet. Of course, you can edit what we have found. It should improve things as some of the maps were not changed in the 2.0 tunes either.
    @OVTune is continuing to support us with new things that he discovers in the jungle of the Toyota base tune data.
  13. Oct 27, 2020 at 1:10 PM
    #7273
    mos
    mos Active Member
    North Carolina
    Got it. Waiting patiently on 04B91 for the 2.0 tunes and will try my hand at porting the MT tweaks you documented / curated in the other thread you linked to before. Really appreciate the responses. Fingers crossed on both my hacks and 2.0 support for the 04B91 6MT!
    mos
  14. Oct 27, 2020 at 1:12 PM
    #7274
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Enjoy!
    You'll be ready for 04B91 when it drops.
  15. Oct 27, 2020 at 2:33 PM
    #7275
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Has anyone tried advancing TC lockup instead of raising the values? Still chasing the magical settings for lock up. Currently running no lock or skip lock in 3rd. 4th gear has bottom two values raised to 38 and middle two values brought up to mid 50s ( don't remember exactly) shifts are smooth as f*** but I'm not sure if it's the newly added lead soles in my driving shoes, or the TC that's making MPGs suffer.... I'd ultimately like to find a balance. Wondering what all you other slush box drivers are doing...
  16. Oct 27, 2020 at 2:36 PM
    #7276
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    How much are you down? The tunes seem to be a bit more sensitive to colder temps with the longer enrichment cycle and winter fuel blends. If only a couple MPG, that would be about normal.
    If you take the same trip on a warm motor, those MPGs come back.
  17. Oct 27, 2020 at 2:41 PM
    #7277
    Shellshock
    Iowa
    Also if its not cold with winter blend fuel..
    tonered[QUOTED] and Mooseditty17 like this.
  18. Oct 27, 2020 at 2:41 PM
    #7278
    Mooseditty17
    AJ
    WI
    VERY interesting!
    Yes the couple of short trips I've taken without driving like a complete sausage, I've only been down a couple MPGs. Thanks Tony.
  19. Oct 27, 2020 at 2:44 PM
    #7279
    Mooseditty17
    AJ
    WI
    I still have summer air in my tires too. It's been in the high 20s to low 30s lately. Plus now that I think about it I'm also letting my truck warm up for about 5 or 10 minutes. Perhaps I'm just overthinking the whole torque converter thing causing a degraded fuel economy.
    tonered likes this.
  20. Oct 27, 2020 at 2:44 PM
    #7280
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    From my tracking, I would agree.
    :hattip:
    Keep an eye on it though.
    Mooseditty17[QUOTED] likes this.
Thread Status:
