Vibration, looking for a diagnosis.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cgutierr, Nov 30, 2009.
  1. Nov 30, 2009 at 12:53 PM
    cgutierr
    cgutierr [OP] Active Member
    I have a 2006 prerunner four door long bed. The truck has 99,000 miles. The past 3000 miles the truck has developed a gradually increasing vibration at all speeds. The only time the vibration goes away is when i turn right or banking through a right curve. I had the tires rotated and balanced but no fix. Any ideas?
  2. Nov 30, 2009 at 12:57 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  3. Nov 30, 2009 at 12:59 PM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    it could be a wheel bearing or cv wearing out?
    or you have something coming loose in the steering shaft, but i doubt that
    i'm not an expert on either of those, but for the vibe to be all the time it would make sense for it to be something between the steering wheel and the front wheels. so just start looken there
  4. Nov 30, 2009 at 1:00 PM
    CAMZTRD
    CAMZTRD Well-Known Member
    steve
    hampton, va
    2006 DC TRD Off-Road 4x4
    billy 5100's @ 2.5 w/ 1/4 spacers, toytec aal, LR UCA's, revotec headlights,revotec taillights, lamin-x fogs, color matched grille and rear bumper, undercover, bed-extender, black nerf bars, scan gaugeII , afe drop in, 50 series flowmaster, 6000k bi-xenon hids, more to come.......
    where do you feel the vibrations..? in the steering wheel, seat, floor...?
  5. Nov 30, 2009 at 1:07 PM
    cgutierr
    I feel it in the floor, it sounds like the hum of super swamper tires. It is definetly coming from the front of the truck.
  6. Nov 30, 2009 at 1:14 PM
    CAMZTRD
    steve
    hampton, va
    definitely the wheel bearings
  7. Nov 30, 2009 at 1:17 PM
    cgutierr
    Is this a diy job and if so how much do the parts cost?
  8. Nov 30, 2009 at 1:21 PM
    CAMZTRD
    steve
    hampton, va
    not sure if you need a new complete hub assembly or just the bearing...call a local autoparts store, this will determine if its a DIY job...
  9. Nov 30, 2009 at 1:22 PM
    cgutierr
    I definitely think its coming from the front. Since my truck is a two wheel drive does it have a hub in the front?
  10. Nov 30, 2009 at 1:24 PM
    CAMZTRD
    steve
    hampton, va
    yes it has a hub, just no cv axle.
  11. Nov 30, 2009 at 1:31 PM
    McMantus
    McMantus Member
    I have a 2006 4 Door 4x4 TRD Sport and have this problem as well; since 37,000 miles. I feel it from 35-45 mph. The vibration comes in waves. I've had it at Toyota 3 times now - nothing has changed.
    Edit: I feel it mainly through the gas pedal, driver side floor board and some in the steering wheel.
  12. Nov 30, 2009 at 2:42 PM
    mreimann
    Denver, CO
  13. Dec 1, 2009 at 11:30 PM
    McMantus
    McMantus Member
  14. Dec 2, 2009 at 4:15 PM
    mreimann
    Denver, CO
    okay, well the best advice i can give is you is to just start trouble shooting.
    type in vibes or some other symptom the truck has into the search bar.
    since ur truck is still stock you can probly ignore all the threads about lifted trucks
  15. Dec 10, 2009 at 8:02 AM
    Sack17
    Sack17 Well-Known Member
    Andrew
    Sanibel, FL
    05 Tacoma DBL Cab TRD Sport 4x4
    Bed lights Blacked out sport wheels blacked out emblems BHLM Spidertraxx 1.5" wheel spacers factory roof rack custom yakima wind fairing w/ PIAA off road lights up top snowboard/ski rack surf board pads fog light mod custom interior cup holder l.e.d. lights Bestop topper custom L.E.D. rear facing lights Maglite mod (2 front seats) 3.25" in the front 2.5" in the rear 6 Hella 500ff's (w/ Silverstar's) Silverstar Ultra's in headlights Silverstar Ultra in fogs (retro-fitted 65w 9005's) Hi-Lift (mounted on side of bestop) Shovel (mounted on side of bestop) custom 1.5" body lift
    Def wheel bearings. Had to recently replace mine. It would get smooth through cornering but then start again when I straightened out.
    I ordered the hub assemby from Oreily's auto parts and I wanna say it was like $90. Make sure you get new gaskets with it, mine didn't come with them so I went to the Toyota dealership and bought them for like $5. I did all the work myself and had to take the old assembly to a machine shop to get the old bearing pressed out and had them put the new one in. From what I found out running around town is that most tire shops don't have a press thats strong enough so I had to take it to a machine shop. That cost me like $50. But I had a mechanic quote me close to $500 to do it so not only did I save a shit ton of money I now know how to do the other one. Its not hard here is a link to a tutorial.
    Hope this helps.
  16. Dec 10, 2009 at 8:18 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
  17. Dec 10, 2009 at 8:41 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    toyota says to replace the hub and bearing. the parts are kinda expensive, but you can do it yourself and save a ton on labor.
    some people here have changed just the bearing and had luck I suppose.
    when it comes time for me, I'll just get the hub too.
    I think Timken?? has a replacement hub/bearing assembly (already pressed in)by now. I mailed them about 6-8 months ago and they said they were close to production.
    What made a big difference in finding where my vibrations were coming from was the front brakes. I think my rotors were warped and the tire shop kept over tightening my lugs. I replaced rotors and it was all better.
    and add that most shops seem to have a problem balancing the stock alloys. Check your torque on your front wheels, 83 ft lbs is it.
    good luck
  18. Dec 10, 2009 at 9:22 AM
    Death_Stalker
    Talha
    Cypress, TX
    2018 4Runner LE
