VIMTY-05 and front/rear cameras
Discussion in '3rd Gen. Tacomas (2016+)' started by KENNY, Jan 5, 2017.
  1. Jan 5, 2017 at 11:43 AM
    KENNY
    KENNY [OP] Non pro grille edition
    Austin, TX
    '20 Tundra, '19 4R
    Was curious if anyone was succesful in running switches with the vimty harness? My goal would be to bypass the screen audio, av buttons/steering controls and just have seperate front and rear rocker switches for the cameras, to function with the oem screen. I've also read about the 3rd gen rear camera anytime mod with the diode, but wasn't sure to do this with the harness.. Anyone with first hand experience with any of this have any input, would be appreciated :thumbsup:
    Also does everyone else get the ebrake alarm when pressing the 5 button pad while driving?
  2. Jan 8, 2017 at 8:08 PM
    yub
    yub Well-Known Member
  3. Jan 16, 2017 at 7:52 AM
    KENNY
    Austin, TX
    '20 Tundra, '19 4R
    Bump.
    I went head and did the rear anytime mod with a switch, but still curious how to do a front anytime on switch mod. Anyone?
  4. Mar 10, 2018 at 11:49 AM
    muchostacos
    muchostacos Member
    Houston, TX
    2016 White DCLB TRD Off road
    I used the VIMTY-05 and the Inewcow logo camera.
    iNewcow Car Front View Logo Embeded Camera For Toyota with CCD Waterproof IP67 Wide Degree (Middle) https://www.amazon.com/dp/B00P2EN5J2/ref=cm_sw_r_cp_tai_CidPAbHENAJGN
    The little bracelet that holds it to the logo is cheap so I just did a hand tighten it.
    The first cable from the camera almost got to the cabin.
    I ran it through the firewall where the main wiring was.
    I ran the power and ground to the VIMTY-05. The 10 pin connector has accessory power and a ground. No need to power it when the truck is off. I connected the RCAs on the driver’s side because it was easier to reach.
    The results were pretty good. The VIMTY-05 adds an A/V source. To activate the camera in motion, you select the A/V source and just hold the Seek Up button on the steering wheel for 5 seconds.
    I am probably going to add an A/V switch and hook up the backup camera so I can switch between the two.
    doublethebass likes this.
  5. Mar 10, 2018 at 1:47 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
  6. Mar 13, 2018 at 11:58 AM
    KENNY
    Austin, TX
    '20 Tundra, '19 4R
    How did you override for the front camera/what did you have to tap into?
    I did the diode for the rear, but not sure what do do for the front that is connected to the VIMTY for a switch?
  7. Mar 21, 2018 at 10:16 PM
    UplandExplorer
    UplandExplorer Level of crazy: Chukar Hunter
    Turbine Tommy aka Mr.Pickles
    Nor Cal
    2017 White TRD OR DCSB
    mud, bugs, feathers, and dog hairs.
    Mind reposting your schematic? The image doesnt seam to work for me...(iphone problem maybe?)
  8. Mar 22, 2018 at 10:05 AM
    BigWhiteTRD
    Ted
    Don't know, but I will try posting it again.
    UplandExplorer likes this.
  9. Mar 22, 2018 at 10:08 AM
    UplandExplorer
    Nor Cal
    Sweet thanks!
  10. Mar 22, 2018 at 10:11 AM
    BigWhiteTRD
    Ted
  11. Mar 22, 2018 at 10:41 AM
    UplandExplorer
    Nor Cal
    Totally understand....ive been compiling all the data i can find. Appreciate it.
