VSC and Lift interaction - how common is it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bjmoose, Sep 7, 2010.
How did your VSC and Lift interact?
  1. I lifted my VSC truck and had NO problems with VSC.
    86 vote(s)
    60.6%
  2. I lifted my truck and had some problems, but they went away after I did a "zero point calibration."
    8 vote(s)
    5.6%
  3. I lifted my truck and am continuing to have minor problems, but I'm living with them.
    46 vote(s)
    32.4%
  4. After I lifted my truck my VSC rendered my truck unsafe/undrivable/really bad so I removed the lift.
    2 vote(s)
    1.4%
  1. Sep 7, 2010 at 8:53 PM
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I've searched the forums, and I feel like I've probably read every thread that mentions both VSC and Lift. Clearly there are potential problems, some have been solved by re-zeroing the VSC, some have NOT been solved by that, some folks have had problems so severe they undid the lift and went back to factory ride height.
    But how common an issue is it? Let's find out. Participate in this poll if you have a VSC equipped 2nd gen Taco, and have lifted it 2" or more. For purposes of this poll - a Bilstein 1.75" ride height adjustment counts at stock height.
    So, after you lifted, what how did your VSC system react?
  2. Sep 8, 2010 at 12:52 AM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    mine seems to be fine but i will find out for sure this winter
  3. Sep 8, 2010 at 4:02 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    no problems here
  4. Sep 8, 2010 at 4:06 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    3" front and rear...no issues w/ VSC
  5. Sep 8, 2010 at 4:12 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    The only issue I had was after lifting the front 3" the VSC came on but as soon as I installed the AAL it went out.
  6. Sep 8, 2010 at 7:41 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    The service manual is very clear. If you are required to make any changes to your front end alignment due to aftermarket modifications then you must recalibrate the VSC.
    See this thread for more info on that: Recalibrating VSC, why & how?
  7. Sep 8, 2010 at 7:43 AM
    JDMcompliant
    JDMcompliant Professional Amateur
    Joe
    San Diego
    2010 Tacoma 4x4 4.0L V6
    i recalibrated mine, and i still have problems. PITA.
  8. Sep 8, 2010 at 9:48 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Thanks guys! Keep those answers coming.
  9. Sep 8, 2010 at 2:42 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    What kind of problems ? i have a 3.25" front lift on mine and a dakar leaf set on the back and after calibration have had 0 issues
  10. Sep 8, 2010 at 9:46 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    bump.
  11. Sep 14, 2010 at 9:43 AM
    JDMcompliant
    Joe
    San Diego
    i wish i had your luck :(
    Mine is a DCLB, so it may have something to do with the length of the truck. On moderate turns, sometimes VSC kicks in. I can never get it to kick in intentionally when i take corners pretty fast, but when i'm just cruising along, say at a cloverleaf on the highway, it'll kick it at around 25mph. freakin annoying.
  12. Sep 14, 2010 at 10:25 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Purely as a mental exercise, I observe the following:
    When I start up the truck, I can disable VSC by pressing and holding the "car on skidding tires" button for three to five seconds, until the "car on skidding tires OFF" lights up on the dash. (A quicker press results in a different mode, with the "Auto LSD" light lit, and VSC coming on and off with vehcle speed!)
    Access to that button is pretty easy - there's a little micro-glovebox right underneath it that is removed to gain access to some of the fuses.
    It should be possible to make up a little circuit that replaces, or goes in parallel with that switch, that automatically detects when power first comes on, and closes the switch circuit for, say, five seconds simulating a user press of the VSC disable.
    Then, your VSC would automatically be disabled every time you started your truck.
    As I mentioned, I observe this simply as a hypothetical mental exercise. DO NOT ACTUALLY DO THIS. DISABLING VSC REMOVES AN IMPORTANT SAFETY FEATURE THAT WAS DESIGNED AND BUILT BY THE TOYOTA MOTOR COMPANY. DEATH OR SERIOUS INJURY MAY RESULT FROM MODIFYING YOUR TRUCK IN THIS WAY. MODIFICATIONS TO YOUR TRUCKS ELECTRONICS MAY VOID PARTS OF YOUR FACTORY WARRANTY.
  13. Sep 14, 2010 at 10:34 AM
    JDMcompliant
    Joe
    San Diego
    I actually do turn it off manually when I am coming up to a turn that is susceptable to VSC triggering, but I have to wait till I'm under 30mph for it to turn off. When I reach 30mph+, it turns back on by itself.
  14. Sep 14, 2010 at 10:42 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If you press and hold it for five seconds when you start the truck, and it's not moving, it should remain disabled until you turn off the truck.
    The name of the circuit I was mentioning is, I believe, a "Time Delay Relay" which is a term you can google on.
  15. Sep 14, 2010 at 11:27 AM
    JDMcompliant
    Joe
    San Diego
    Ah, I did not know that. I'll give that a shot tonight.
  16. Sep 14, 2010 at 12:12 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    3" in front and dakar leafs in the rear and I have had no issues at all.
  17. Sep 20, 2010 at 5:39 PM
    DaveSmith
    DaveSmith Active Member
    Dave
    Maine
    2010 Tacoma TRD Offroad
    I wonder how many people go into their local dealer to get their VSC reset only to have the dealer NOT actually reset the VSC but tell them that it was reset. If the dealer has no idea what we are talking about and insists that the VCS can not be re-zeroed until proven wrong by papers printed out from TacomaWorld I wonder if they are actually really resetting the VSC properly. I don't trust my dealer to change my oil. Anyone know of a way to verify that the VSC is actually reset? Anyone know of a Northern CA dealership that knows how to work on an aftermarket Tacoma?
    Anyone interested in buying the test equipment to do the recalibration as a group and then passing the gear on to the next person on the list. If 20 guys go in on the purchase we might be able to get all the gear for about $20/each. (I have no idea how much the gear costs, the $20 is just an example)
  18. Sep 20, 2010 at 8:07 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You can do it yourself with a jumper wire
  19. Sep 21, 2010 at 11:39 AM
    DaveSmith
    Dave
    Maine
    Has anyone actually zeroed and rest their VSC with a jumper wire? If so please post. I'm afraid to try it until someone tells me that they themselves have done it and that it worked. I'm afraid that this might be like the "is it safe to shave/grind the front brake calipers to get 16" wheels to fit" question. 100 members say it's safe and that they have heard of someone that did it but in all actuality it is very unsafe and shouldn't be done.
    If you used a jumper wire to zero/reset your VSC please post. If you heard of someone doing it or read about someone doing it please do NOT post.
    Thanks.
  20. Sep 21, 2010 at 11:42 AM
    DaveSmith
    Dave
    Maine
    Maita Toyota of Sacramento, Ca just quoted me $120 to zero and rest the VSC. This was after I had to explain to them how to do it and what it was for.
