Want to install long travel but...
Discussion in 'Long Travel Suspension' started by rondog, Jan 19, 2011.
  1. Jan 19, 2011 at 2:23 PM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    I have a procomp 6" stage II kit on my truck right now and want better performance off road. Is having that kit on my truck current going to bring up any issues?
  2. Jan 19, 2011 at 2:34 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
  3. Jan 19, 2011 at 2:39 PM
    rondog
    Ronnie
    Escondido/San Diego
    oh sorry I meant to say I was going to remove the procomp kit
  4. Jan 19, 2011 at 2:40 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    are you a prerunner or 4x4? if your a prerunner, and didnt cut anything you "should" be able to. if your a 4x4 and did cut, your gonna have to weld a piece back into the crossmember. at least i would think so
  5. Jan 19, 2011 at 2:41 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    are you 2wd or 4wd? if your 4x4r you will have to get a cross member welded back in place
  6. Jan 19, 2011 at 2:42 PM
    98_Mud_bug
    lucedale Ms.
    damn beat me to it ha ha
  7. Jan 19, 2011 at 2:47 PM
    rondog
    Ronnie
    Escondido/San Diego
    I do have 4wd and I remember something about cutting the cross member with the procomp kit. Do you guys have any info on that?
  8. Jan 19, 2011 at 2:49 PM
    ktmrider
    Junk
    yeah you have to cut the cross member to get the front differential to drop. A plate will have to be welded back in but im sure theres some good shops that can do it in san diego
  9. Jan 19, 2011 at 2:50 PM
    jandrews
    '09 FourDubDee TRD OR
    Yeah, you cut the crossmember when installing the procomp kit. Which means if you're going to a non-dropbracket suspension set up, you need to uncut that sucker so you have something to mount the front diff on.
  10. Jan 19, 2011 at 2:51 PM
    jr114
    Jon
    SoCal
    Truck
    i would think that by removing the drop bracket, welding in a plate, and removing the blocks from the rear..youd be pretty much close to stock, and could work on lt from there
  11. Jan 19, 2011 at 2:54 PM
    rondog
    Ronnie
    Escondido/San Diego
    I have a buddy who can weld so I'll see what he says. I guess I'd wana see what differential looks like sitting at stock. If anyone reads this and are willing to, that'd be awesome :D
  12. Jan 21, 2011 at 4:17 PM
    rondog
    Ronnie
    Escondido/San Diego
  13. Jan 21, 2011 at 4:19 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    yes it does. you can upgrade to their lift spindle if your 2WD
  14. Jan 21, 2011 at 4:27 PM
    rondog
    Ronnie
    Escondido/San Diego
    I am 4wd. How come the spindles only apply to 2wd? If I do stick with the stock spindles, TC makes a Weld on Spindle Gusset that I could put on to reinforce them
  15. Jan 21, 2011 at 4:36 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    has to do with the 4WD hub.
    yes, use the gussets
  16. Jan 21, 2011 at 6:07 PM
    helocat
    helocat Well-Known Member Vendor
    x2
    And they are easy to install when you have the front torn down.
    Mark
  17. Jan 23, 2011 at 3:37 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    spindle gussets are over-rated :anonymous:
  18. Jan 23, 2011 at 12:16 PM
    ktmrider
    Junk
    I bet you get pretty good tread wear with your spindle modification
  19. Jan 24, 2011 at 4:32 PM
    rondog
    Ronnie
    Escondido/San Diego
    What happened to your truck in your sig? spindle issues?
  20. Jan 24, 2011 at 4:57 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Thats one way to put it.
