Want to run bf goodrich a/t 285/75/R16
Discussion in 'Wheels & Tires' started by rawfltrevor, May 6, 2013.
  1. May 6, 2013 at 10:50 PM
    rawfltrevor
    rawfltrevor [OP] Member
    Trevor
    Los Gatos
    07 White PreRunner V6 SR5
    aftermarket deck, rockford fosgate sub and amp with custom box, derped valence, derped roof, derped rear bumper, satoshi grill with TOYOTA emblem, black badges, 3/2 Coil spacer/block lift kit, angry eyelid headlight covers, BHLM, colormatched grill
    Hey guys, so it's come time for me to get new tires since putting the 3"/2" coil spacer and block lift on my truck. Its a 2nd gen prerunner access cab. I want to run bf goodrich all terrain tires at size 285/75/R16 which is about 33" I believe. Because I am on a budget (broke college kid), I can't afford fancy wheels so I want something nice and simple like pro comp series 97,98 etc. I have googled and lurked this forum thoroughly and have not found a straight answer to my question: What backspacing/offset do I need the wheels to be to run those tires without rubbing?
  2. May 7, 2013 at 9:28 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Get 4.5 backspace and you are going to have to trim a little.
  3. May 7, 2013 at 11:56 AM
    rawfltrevor
    Trevor
    Los Gatos
    I want to get some steel pro comps and it seems most of them are at a 4.25" or 2.5" backspace. Would 4.25 bs work? I'm fine with trimming plastic but I really want to avoid chopping the cab mounts or any other metal. the wheels are 16x8 by the way.
  4. May 7, 2013 at 2:15 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    For steelies, the only one that I'm aware of that will not interfere with your calipers are the Wheeler steelies. Look into those if you're set on steel wheels. You can keep your stock wheels and add adapters as well.
  5. May 7, 2013 at 5:28 PM
    rawfltrevor
    Trevor
    Los Gatos
    Cool thanks, I think I'm thinking I'd go with the type b (4" bs). You think that those wheels alone with no spacers and no cab mount chop will allow the 285s to fit?
    In this thread (http://www.tacomaworld.com/forum/wheelers-off-road/207591-wheelers-steelies.html) one guy is saying to go with type a because 4.5 bs is plenty for 285s to clear the UCA and that type Bs will rub the cab mount with the 285s. Yet, another guy is saying to go with the type B's. I'm lost haha.
  6. May 7, 2013 at 6:56 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    You will have enough clearance with 4.5" BS and 285s on your 2nd gen. If you are considering some larger and wider than 4.0" BS might be a better option. More than likely, with 285s, you'll need to do the CMC mod.
  7. May 9, 2013 at 12:27 AM
    Greytacoma1
    Greytacoma1 Senior Member
    dave
    Sacramento ca
    Tacoma dc lb
    Satoshi grill, Plasti derp, Ready lift kit, Wheelers 2 inch aal, Hella 700, Wheather tech floor mats, Blueinstinct armrest cover, sockmonkey bed decal, BHLM, debadge, 35% tint front windows, OEM roof rack, OEM step bar, TRD skid plate, tacomaworld.com decal, stock antenna trimed, gorilla extended lug nuts,diff breather mod, cab mount chop, AVS window visor, spidertrax 1.25 wheel spacers, toytec sway bar relocate, extra d ring mod
    Since you said your on a budget, just run your stocks with spider trax.
