WeatherTechs with manual trans
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eaglesfn5402, Jan 14, 2014.
  1. Jan 14, 2014 at 11:40 AM
    eaglesfn5402
    eaglesfn5402 [OP] Well-Known Member
    Cory
    Harrisonburg, VA
    '13 Black TRD Access Cab
    3" OME Lift, 885X Coils, AAL in rear., Debadged, Stock rims painted black, Wind Deflectors, 10" kicker solo baric in a custom box from subthump.com, MTX 2000 watt amp, LED Bed light kit, Underhood LED light kit, CB Radio, Grillcraft BG series, Pop & Lock PL5400, rear sliding window security bar. more to come when time and $ permit
    Was searching for weathertechs for my truck and came across a place selling them that stated they do not fit manual transmission trucks. Does it just take some cutting to make them fit or do they make a specific type for manual transmissions? Seems like a downside to them to pay that much for them then have to cut it.
    Also noticed the back is all one piece for the access cab, I have a sub box in the back between the two jump seats from subthump.com. Would it be easier to buy these http://www.amazon.com/WeatherTech-Custom-FloorLiner-Toyota-Tacoma/dp/B000KL71FG/ref=pd_sbs_auto_7 (if someone thinks they'd fit in the access cab). Or just buy the one that is all one piece and attempt to lift the sub box up while someone else slides it under the sub box?
    Suggestions on which color would look better as well, black or grey?
  2. Jan 14, 2014 at 11:44 AM
    eaglesfn5402
    Cory
    Harrisonburg, VA
    any suggestions on a place to pick them up at a reasonable price would be appreciated as well. saw a thread mentioning tapautos, typed weathertech in the search bar and nothing came up. Also tried Amazon for front and rear it comes to a total of $202.90 without shipping. Weathertech has them for $179.90 (tried to click checkout to see what shipping would add to total, says error occurred on the page.)
  3. Jan 14, 2014 at 11:44 AM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    I had the ones you cut to fit and liners custom fit in my mt, for the liners you will have to trim one piece around the clutch, like about 2-3" sq there the clutch bottoms out to the floor. The cut to fit did ok, but once I had to opportunity to buy the liners I did so and liked the fit an finish better, along with the protection. You can try the one piece, but I didn't have the rear piece in my access cab. And get black, Greys and tans get marked up and look dingy after a few thousand miles.
  4. Jan 14, 2014 at 11:47 AM
    eaglesfn5402
    Cory
    Harrisonburg, VA
    Thanks for the quick input.
  5. Jan 14, 2014 at 12:10 PM
    mick478
    Bott
    Stockton, CACA
    I am SUPER bored at work... No problem good luck, I just remembered that I bought them at cabelas, 99 for a front set on sale
  6. Jan 14, 2014 at 12:39 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    Mine fit my manual just fine. I went with black FYI.
  7. Jan 14, 2014 at 2:02 PM
    high voltage taco
    high voltage taco Well-Known Member
    Monticello, Ky
    05 TRD 6 speed 4x4
    so far, URD throwout bearing kit(sleeve), weathertechs, 285/70/17's on Ion 17x9 and OME 885s and Dakars and nitro sports. BHLM
    try truckaddons.com. I had to cut mine to keep the clutch from hanging on it but they work great after that.
  8. Jan 14, 2014 at 2:05 PM
    Manwithoutaplan
    ID
    Same here i cut mine little but you can not tell at all.
  9. Jan 14, 2014 at 2:06 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I bought Weathertechs and just had to trim it a little bit to clear the clutch pedal. Easiest mod ever.
  10. Jan 14, 2014 at 2:12 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
  11. Jan 14, 2014 at 2:18 PM
    MQQSE
    MQQSE Bannable Galloot
    Rob III
    Monkey Mountain
    "Stitch" Still Stock Concept Truck
    DV8 frnt bpr w/ winch/BD lt bar-dtch lts/Blstn5100s
    Yep, had to trim mine a little. And a second small adjustment first time they cold soaked in the truck at sub zero temps because they stiffened up in the extreme cold. No problems since, 3 yrs plus now. I got black and no complaints.
  12. Jan 14, 2014 at 2:22 PM
    TacoTrooper
    TacoTrooper Well-Known Member
    James
    Vancouver, Canada
    2013 TRD Double Cab 6-spd manual
    2013 TRD Sport DCSB 6-spd manual
    No problems for a manual trans...clutch goes to the floor, mat stays in place.
  13. Jan 14, 2014 at 2:24 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Mine fit no problems with the clutch, in fact I kinda wish they went up behind the clutch a little higher.
  14. Jan 14, 2014 at 2:26 PM
    zimmmtaco
    zimmmtaco Better than it was before it got like it is
    Northwestern PA
    15 DCSB Blue Ribbon Met 4x4 OR, 6MT
    TRD Pro susp kit 265/75R16 BFG K02's Husky Floormats Vent visors Hella 500 on custom mount
    Bought weathertechs from Chas/TAP autoparts for 2011 DCSB 6 spd...... Had to cut out small square to clear the clutch pedal at full extension. simple to do... install mat, depress clutch, mark the floor mat, remove mat and cut out notch for clutch pedal, re-install and check clearance. Weathertechs definitely worth the money and the modification. TAP autoparts is excellent to deal with - great price and quick delivery time :D:D
  15. Jan 16, 2014 at 12:21 AM
    osubeav818
    osubeav818 Well-Known Member
    Los Angeles, CA
    13 Regular Cab, SuperWhite, Debadged
    Viper 350hv, Bakflip Fibermax, Pop n lock
    bought mine off of ebay from weathertech. in black. haven't had to cut them, clutch seems to clear just fine. best investment i've put into my taco
  16. Jan 16, 2014 at 6:49 AM
    eaglesfn5402
    Cory
    Harrisonburg, VA
    Cabela's won't ship to Germany, pm sent to the TAP rep waiting on a reply to see how much they would be shipped. Saw the ones on ebay $197.90 front and rear without shipping. So I'll see what TAP rep says.
  17. Jan 16, 2014 at 6:58 AM
    eaglesfn5402
    Cory
    Harrisonburg, VA
    askwed weathertech.com for a military discount and with the military discount it would be $170.91 with free shipping. That's if they ship to APO AE. So that's the cheapest quote I've found so far for front and rear.
  18. Jan 16, 2014 at 7:20 AM
    IsmellBacon
    IsmellBacon Well-Known Member
    Denver, Colorado
    TRD offroad double cab
    None yet, need to finish the HEEP first
    I trimmed the WeatherTech floor mat so the clutch peddle and arm would not bind/catch. Simple and easy fix.
    Bacon
  19. Jan 16, 2014 at 7:25 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Lives: Yelm WA/Home: Leesburg, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    they will, i ordered mine direct from weathertech when i ws in germany
  20. Jan 16, 2014 at 7:37 AM
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    Yes mine required some trim no big deal. If you dont trim clutch will hang up on it when pushed down not a good thing.
