Weird Short Shifter Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rlotti, Apr 21, 2011.
  1. Apr 21, 2011 at 3:52 PM
    rlotti
    rlotti [OP] Well-Known Member
    Bay Area
    05 prerunner trd
    Jardine exhaust, Fujita intake
    Bought a URD short shifter and installed it 2 months ago, has been shifting great, but yesterday it started shifting at the stock throw again. I took it apart today to see if something was wrong with the parts. Parts were still intact, but the shaft above the shifter boot has loosened.
    I wanted to know if anyone else has had this problem after installing URD's short shifter.
    Alex
  2. Apr 21, 2011 at 7:39 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    My guess is the shifter internal bushings are worn out. If you grab the shifter knob, with the truck in gear, does the shifter "wiggle"?
  3. Apr 21, 2011 at 8:02 PM
    reiss91
    reiss91 Well-Known Member
    Mark
    Mass
    2011 Tacoma Gray
    My 2011 6 speed with only 2500 miles has terrible wiggle when its in gear. but no short shifter. that normal?
  4. Apr 21, 2011 at 8:50 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    It will have a little wobble. I have never actually measured it. As the shifter gets older, it will wobble more.
  5. Apr 21, 2011 at 8:56 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    There are several things that cause a shifter to wobble but it's not s big deal but as for the throw being lengthened enough to notice, that is strange
  6. Apr 22, 2011 at 10:15 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Stock shifter is a telescopic design with rubber injected between. Acts as a vibration isolator. It can wear out faster with short throw shifter as more force is exerted on the part. Shifter is like $173 for entire unit.
    http://www.tacomaworld.com/forum/te...-stick-shift-after-urd-shift-kit-install.html
    X-runner guys modify shifter to remove the rubber and make solid..cool ideas
    http://www.tacomaworld.com/forum/x-runners/55433-modified-trd-shifter.html
