What direction with new suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpeedoJosh, May 24, 2013.
  1. May 24, 2013 at 5:58 PM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    I'm still rolling around on stock suspension with well over 100k miles. I've been holding out on spending too much on the truck with thoughts of moving to a 2nd gen, but I'm thinking I might keep it and make it a good expedition type vehicle that sees mostly DD'ing with the occasional trip through some off road terrain.
    I'd like a suspension that'll ride nice and smooth on the road, but also work well off road when the time comes. Not really looking for a big lift. I assume my truck is sitting lower then stock with the older suspension, so I'd like to get something that'd at max give 2" of lift. Just bought new 31's and don't really want to go bigger, plus I like my mpg's. Would like a kit that is going to last a good bit of time without tons of maintenance.
    Truck is a 98, access, 4x4, manual hubs with the 2.7.
    With that whole essay said, would something like an OME with 880s or 881s be best? What about a King coil over? I know the King is a much better system, but thinking it would it be overkill for my application?
    For the back I'm thinking an AAL would be best, unless someone can point me towards a leaf pack that doesn't lift the rear some ridiculous amount.
    Thoughts?
  2. May 24, 2013 at 6:03 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    For what you want the OME kit sounds good... I would get a new leaf pack or make your own OMD leafs. The aal won't help to much with 100k+ mile leaf pack...
  3. May 25, 2013 at 1:00 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    OME 881s with wheelers Alcan 5 packs would be great. Nitro charger shocks all around.
  4. May 25, 2013 at 1:26 PM
    SpeedoJosh
    Florida
  5. May 25, 2013 at 4:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No 881s are perfect for the wheelers 5 pack. Look up MTgirls truck or Socars truck. They have it and 31s look perfect. Only about 1" lift.
  6. May 25, 2013 at 5:02 PM
    cdj1
    cdj1 Well-Known Member
    Clint
    Vidalia, GA
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    Here is a picture of my 97 with the ome 883s. e4u2a2e9_7ddd2591b7a992a739ed52817200505e64def3f4.jpg
  7. May 25, 2013 at 5:05 PM
    Madjik_Man
    Colorado Front Range
    No way really? I thought on Toytec's website it said 2-2.5" of lift for the 881s
    And I also thought the wheelers 5 pack and Dakars give the same height, no?
    Fack Monte... you're mindfuhking me with all of this... thought I had it dialed in with the full OME suspension (881s)
  8. May 25, 2013 at 5:05 PM
    Madjik_Man
    What size tires?
  9. May 25, 2013 at 5:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Think they start at like 2.5 settle down a bit to I guess 1.75-2..but the rear is 1"ish. But since you have to lift the front more then the rear to make it sit level that's what I was referring to to keep it simple...haha
    881s and 5packs are damn near perfect for each other.
    Dakars are supposed to give 2-2.5" rear lift. The Alcan 5 packs only give about 1.5"
  10. May 25, 2013 at 5:12 PM
    Madjik_Man
    Why would OME design a lift that would give that much rake? and not sit level.
  11. May 25, 2013 at 5:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    OP white truck is on 881s and 5 pack alcans from wheelers. 31x10.5r15s
  12. May 25, 2013 at 5:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Factory has rake man
  13. May 25, 2013 at 5:17 PM
    cdj1
    Clint
    Vidalia, GA
    97 Tacoma
    255/85/16 and I put the AAL in the rear. Gonna wait to see how much it settles after o get my elite bumper and sliders on to see if I need blocks in the rear
  14. May 25, 2013 at 5:18 PM
    cdj1
    Clint
    Vidalia, GA
    97 Tacoma
    Sportin a bro lean right now
  15. May 25, 2013 at 5:24 PM
    Madjik_Man
    That much?
    I thought it was like 1/2" or so
  16. May 25, 2013 at 5:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Usually 1" I think. Which isn't that much. That like the amount to really start to notice it. I have over 2" rake now..and it doesn't look that bad.
  17. May 25, 2013 at 7:59 PM
    SpeedoJosh
    Florida
    That looks pretty good. Really like those fenders too. Might have to look into a set b/c my truck has none, and the GY Authorities tend to grab rocks
  18. May 25, 2013 at 9:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    They are jungle flares if your interested.
