What do I need for a 2" lift???? With the 5100's
Discussion in 'Suspension' started by psle1000, Dec 16, 2012.
  1. Dec 16, 2012 at 9:13 AM
    psle1000
    psle1000 [OP] Well-Known Member
    DAT
    ORANGE CA
    2012 TRD OFF ROAD
    I have a 2012 TRD 4 door off road.
    I have the 5100 front and rear and 1" spacers for the rear. I'm trying to just lift by just adding the 5100". I've hard that if I just lift it 1" I'll be good. But now I have these rear spacers I want to use. If I use it my rear will be hirer then my front. Here is the math
    Front stock hight 34.5 + .85 from the 5100 =35.35 in
    The rear stock is 35". Right now if I just lift the front it will be level.
    If I add the 1" spacer ill be at 36" and the rear will be hirer.
    So I did the math if I want to use the spacer ill have to lift the front to the 2nd level and its 1.75 in. here's the math
    Front 34.5 + 1.75=36.25
    My front will be a 1/4 in hirer. I don't this a 1/4 in is that notes able. So my question is if I lift the front 1.75" will it rub. As of now I'm running stock tires. When I need to replaces it ill go bigger. For example size 265/75/16 or can I go bigger w/o anything rubbing?
  2. Dec 16, 2012 at 7:42 PM
    psle1000
    DAT
    ORANGE CA
    2012 TRD OFF ROAD
    Bump any help
  3. Dec 16, 2012 at 7:46 PM
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    What's your ultimate goal? If it's to fit 285s, there's gonna be some serious rubbing unless you go with a full 3 inches, and even then there's still probably gonna be a little rubbing.
  4. Dec 16, 2012 at 7:48 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    :notsure:
  5. Dec 16, 2012 at 8:06 PM
    dlooney
    Dennis
    Wilmington NC
    I think he's saying he doesn't know if the 1/4 inch height difference will be noticeable...
  6. Dec 17, 2012 at 1:35 AM
    psle1000
    DAT
    ORANGE CA
    2012 TRD OFF ROAD
    What he said.
    I want to lift the rear with the 1" spacer and level out the front with just the 5100,s. hoping that is all I need when I use this size tire 265/75/16 and nothing will rub.
  7. Dec 17, 2012 at 2:46 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    You can run that size tire with stock suspension with no major rubbing, might need to remove front mudflaps. You will be fine with that size, 285/75/16 you will have rubbing, you might be able to get away with 275/75/16
  8. Dec 17, 2012 at 9:01 AM
    psle1000
    DAT
    ORANGE CA
    2012 TRD OFF ROAD
    Do u know anyone here that is running the 275/75/16?
  9. Dec 17, 2012 at 9:32 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    I believe kpt and oz-t both have 275s and there is plenty others. I have heard of at least one person that had rubbing on the UCAs with stock wheels and 275s, i think most people can get away without needing spacers though.
  10. Dec 17, 2012 at 9:37 AM
    evanmb31
    evan
    connecticut
    09 trd off road
