  1. Oct 5, 2020 at 1:21 PM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    I went with Spider-Trax. They have held up well for a few years. Just make sure you get something that is Hub Centric and anti seize the surfaces between the rotor and spacer when you install them. Since the spacer is Aluminum and the rotor is steal, the dissimilar metals will cause Galvanic Corrosion. Or in layman's terms, you won't be able to get your spacer back off.
    GrubesBaja[QUOTED] likes this.
  2. Oct 5, 2020 at 1:23 PM
    trdtacojef
    trdtacojef Well-Known Member
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    OME Dakar Medium duty rear leafs Total Choas UCAs Elka 2.5” Extended Travel CO and Rear Shocks w/ RR and DC FN FX Pro 17” Silver Rims Nitto Ridge Grapplers 285/70R17
    You should be pretty proud of how clean that frame looks. I have a southern lived truck and mine doesn't look that good. Amazing job.
    jkauf and dpele[QUOTED] like this.
  3. Oct 5, 2020 at 1:54 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Replaced the ORIGINAL 2010 battery with 185K on it...
    Picked up a DieHard Gold from Advance Auto Parts OE Exact Fit; OE Spec: OE Group 24F; OE CCA 585; Battery Spec: 750 CCA; 935 CA; 130 Minute Reserve Capacity; 3 Year Free Replacement
    10% discount...
    No core charge because they installed it right there for me :)
  4. Oct 5, 2020 at 2:03 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Gawddamn that’s the longest I’ve seen a battery last!
    Rick_Taco and DG92071 like this.
  5. Oct 5, 2020 at 2:06 PM
    TreeFortRichard
    Brian
  6. Oct 5, 2020 at 2:07 PM
    Island Cruiser
    Kauai
    Baja
  7. Oct 5, 2020 at 2:07 PM
    Truckdogipa2
    Truckdogipa2 Well-Known Member
    Mark
    2011 Tacoma trd sport long bed
    New frame, Upper control arms, roof rack , method wheels fallen tires duel battery
    Added new lights
  8. Oct 5, 2020 at 2:13 PM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    No argument. My last system I had separate four channel and sub amps, manual time alignment and EQ and a full crossover network. I was one step away from going to a full DSP, and after some work I got it sounding quite impressive.
    What the Key amp’s auto DSP is able to produce is frankly really impressive, especially when you compare to the cost and complexity of tuning a real deal traditional DSP. That’s why I recommend them.
    dpele and kidsmoke[QUOTED] like this.
  9. Oct 5, 2020 at 2:18 PM
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
  10. Oct 5, 2020 at 2:23 PM
    anonymouse
    anonymouse Member
    I had the same battery. Lasted me 7 years. Needless to say. I replaced it with the same. Great battery!
  11. Oct 5, 2020 at 2:46 PM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    My last battery was swapped out at a little over four years. It definitely doesn’t help that the truck is parked at the airport roughly 3 weeks out of every four.
    4x4cajun and JimIowa like this.
  12. Oct 5, 2020 at 2:58 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    Just a small mod....I know it's been done before and I'm sure there's a better way but my OCD kicked in today. Tired of the light gray door handles getting dirty and not coming clean! Plus a productive way to carry extra paracord!
    4x4cajun, Duffer, Rick_Taco and 12 others like this.
  13. Oct 5, 2020 at 3:15 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    After two weeks of being on stands I finally received my third member from ecgs. I had mailed mine in to switch my locker for an air locker and FedEx lost mine En route. I went with crown performance stainless steel air lines because I never want to worry about them being a point of failure. Plus they have the cool factor
    12ED09A0-3633-4558-B4AE-631463DDC885.jpg 61BB1646-FB06-40D0-9A93-CEBF2BDE4BA7.jpg AC4D4B27-B570-413A-9A09-C3A7541AD6B4.jpg 14C5C610-1255-4167-B777-8887B6AF02A7.jpg
    Jpiskura, drainsbe, 13txtaco and 25 others like this.
  14. Oct 5, 2020 at 3:49 PM
    Hunter_Bick12
    Hunter_Bick12 Just a Yota guy
    Hunter
    Alabama
    2011 Black DCSB TX TRD Prerunner, 1986 Gray SR5 4x4
    Changed my brake pads. First time doing this on any vehicle. Nice to save a little money, no telling how much it costs at the dealer. Pretty straight forward and easy. Took me about an hour but I’m extremely meticulous. Could easily be done way faster.
  15. Oct 5, 2020 at 3:52 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Those are seriously cool headlights! What are they?
  16. Oct 5, 2020 at 4:06 PM
    TreeFortRichard
    Brian
    One suggestion put some lithium grease or brake pad grease on the pins and rotate them/twirl them every oil change. It keeps them from seizing up...But I guess you're in 'Bama so you're not dealing with the rust...Unless your a Gulf Shore taco.
    Great way to save money, swapping your own pads!
  17. Oct 5, 2020 at 4:08 PM
    TreeFortRichard
    Brian
    Splash guards would also help save the manifold from getting wet when hot...IDK if it's been addressed in that thread..I just know mine is cracked and it's most likely from this.
    dpele[QUOTED] likes this.
  18. Oct 5, 2020 at 4:46 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Lol, just taking care of my babies. She's paying for it, I just wanted to make sure she got the truck she wanted. A couple of weeks ago, we could only find three in all of the U.S. in that exact configuration and one was in Hawaii. The other two were spoken for.
    Hawaii to southern Indiana would be a long damned drive......
    You should see it in person, it really looks sharp. I was starting to wonder what my truck is worth!
    Rick_Taco[QUOTED] likes this.
  19. Oct 5, 2020 at 5:23 PM
    Hunter_Bick12
    Hunter
    Alabama
    I don’t have too much of a rust issue where I live. I was going to do like you said with the pins, but considering the truck is a 2011, I got it 3 years ago, and the pins were still free and not seized, I decided not to. I only had a small amount of lubricant that came with the kit so I didn’t want to waste any on the pins just to be sure I got to both sets of pads first. Nevertheless, I still sprayed them with some wd40 and wiped them clean. Really wasn’t even a sign of rust, just tons of brake dust lol
  20. Oct 5, 2020 at 5:28 PM
    TreeFortRichard
    Brian
    So your pins didn't look like this?
    Vice spreader couldn't even get them out...I had to replace the entire calipers...
