  1. Jan 27, 2021 at 7:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Moog
    whatstcp likes this.
  2. Jan 27, 2021 at 7:25 AM
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    Yeah, Moog. You’ll be glad you took care of this sooner than later. Have who ever does the work add anti seize to the bolts. Don’t know how many miles you have but new ball joints will come with them too.
  3. Jan 27, 2021 at 7:28 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Huh they're only $174 each, not bad. Thanks.
  4. Jan 27, 2021 at 7:31 AM
    Voltron4x4
    Denver, Colorado
    This and that...
    Also check the tabs to make sure they are not bent. A couple of mine were slightly bent so they added a little metal behind it.
  5. Jan 27, 2021 at 7:51 AM
    Minny Taco
    Minnesota
    Actually now I see the Moogs are $131 each.. ok final question, will I need any parts other than the 2 LCAs?
  6. Jan 27, 2021 at 8:04 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Which ones are you looking at? The ones in my Amazon cart are $103 and $107.
  7. Jan 27, 2021 at 8:07 AM
    Minny Taco
    Minnesota
  8. Jan 27, 2021 at 8:09 AM
    Minny Taco
    Minnesota
    Crazy, same part even cheaper.
  9. Jan 27, 2021 at 8:23 AM
    skimballc
    skimballc Active Member
    Shane
    ABQ, NM
    '07 Tacoma TRD OR DCSB
    whatstcp and Minny Taco[QUOTED] like this.
  10. Jan 27, 2021 at 8:44 AM
    SoCalTbird
    SoCalTbird Well-Known Member
    South OC
    06 PreRunner DCSB 05 AC 4X4
  11. Jan 27, 2021 at 8:49 AM
    Minny Taco
    Minnesota
    Nice, I'm anxious to get these on, get new wheels/tires, have it aligned, and get on with my life.
    SoCalTbird[QUOTED] likes this.
  12. Jan 27, 2021 at 9:10 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    I just went through this with mine. Bolts were seized to the inside of the bushing. Had to cut 3 out of the 4 with a sawzall to remove them. I went the new complete LCA route. MOOG makes some nice ones with bushings and lower ball joints already installed. Those are the ones I went with, rock auto had them in stock ready to ship and I cant complain so far.
    cutting them out took longer than installing the new arms with the rest of the suspension with my lift
    Minny Taco[QUOTED] likes this.
  13. Jan 27, 2021 at 9:14 AM
    Voltron4x4
    Denver, Colorado
    This and that...
    Looks like those come with the bushings installed so should be good.
  14. Jan 27, 2021 at 9:15 AM
    Voltron4x4
    Denver, Colorado
    This and that...
    You get the ones pictured? Dont look the same as factory...
    geekhouse23 and y=mx+b like this.
  15. Jan 27, 2021 at 9:17 AM
    Voltron4x4
    Denver, Colorado
    This and that...
    I found it easiest to just have the person at the dealership desk grab all new cam bolts and parts. Went back and returned what they didn't use. They were able to reuse a couple.
    AStinkyBumb likes this.
  16. Jan 27, 2021 at 9:23 AM
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    I second this, OEM alignment bolts are much better than aftermarket. I went with SPC alignment bolts cause I was in a pinch. They are a bit more sloppy than the OEM ones I pulled off but still work and got me a good alignment. I will have to see how they hold up over time.
    winkel and Voltron4x4[QUOTED] like this.
  17. Jan 27, 2021 at 9:39 AM
    SoCalTbird
    South OC
    picture is wrong, but the ones i got appear to be correct replacements. I read some reviews that the cheap ones are that great, figured i could take my time and install whiteline bushings in the factory ones
    Edit-when i posted it, i didn't pay attention to the pic, just grabbed the link
    Voltron4x4[QUOTED] likes this.
  18. Jan 27, 2021 at 9:40 AM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    Here is how I refinished my wheels;
    https://www.tacomaworld.com/threads/a-little-restoration.521020/page-2
    For me, I was able to paint the wheels with the tires off, that way I could paint inside & out for a better finish.
  19. Jan 27, 2021 at 10:27 AM
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    So.... I replaced my passenger brake caliper yesterday that was sticking and compared the basically brand new brake pads to the drivers side. Theres about an 1/8th of an inch difference... Wondering if I should replace again or just let them even out? It is pulling to the left when braking however I did not bleed the system yet.
  20. Jan 27, 2021 at 11:02 AM
    texvet61
    texvet61 Well-Known Member
    Ocala, FL
    09 Tacoma TRD Sport
    Lighting: Phillips LED headlights, BD's S2pro fog lights, LP4 pro and LP9Pro Racing LED's, Black OaK IR cubes. COMMS: Cobra WSX75 CB, Icom 7000 Ham Radio, antenna; Alpha MotoSS HF 80m-40m, CA-2x4SR tri-band 2m/70cm/ - AUDIO: ALPINE ILX-W650, KTA-450 Amp, S-A60M 300Wt mono amp, F/R door speakers, JL Audio C2-650X, JLAudio Micor 8" sub. C4 Fab Hybrid Bumper, Warn VF12000S, Locking Rear seat Gun Vault. Locking Console Gun Vault, FPV winch Camera,
    Just picked her back up from Frame Recall, 209K miles, New Frame along with new steering, thought I might as well get a new suspension since the install was free.6075817880258116151.jpg 8971481770545946058.jpg
