  1. Feb 26, 2025 at 9:53 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    most HD will say no, but i used to as a dept lead
  2. Feb 26, 2025 at 10:07 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    This is the one that I used. I'm finding that the unlock button doesnt activate 100% of the time, very odd.
  3. Feb 26, 2025 at 10:24 AM
    Citron
    Citron Well-Known Member
    Oklahoma
    2012 Tacoma TRD Sport
    I almost forgot. I installed a Black Widow muffler a few months ago, as the stock on had a broken baffle. Now I am all caught up.
  4. Feb 26, 2025 at 10:25 AM
    SSX999
    SSX999 Well-Known Member
    2015 Tacoma TRD Off Road 6MT
    Began stalling after running 3 seconds yesterday. Starts fine but dies unless I pump the gas between 2K-3K rpm. Cleaning the MAF and then swapping for a new one didn't help. Don't have a scanner to check if any codes, or smoke machine for vacuum leaks, etc., so she's taking a trip for a checkup...
    TomTwo likes this.
  5. Feb 26, 2025 at 10:53 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    OBD II and phone app. $30. Must have tool in 21st century.
    Me? I washed the dusty washable air filter for about the 50th time. Money saved.
  6. Feb 26, 2025 at 10:57 AM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Sorry to hear….I hope you get the truck fixed up soon and it’s not too expensive.
    TomTwo and lowmower like this.
  7. Feb 26, 2025 at 11:05 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Canadian? NRC is a Canadian company, I do see a good number of NRC rollbacks in the states.
    SSX999[QUOTED] likes this.
  8. Feb 26, 2025 at 11:08 AM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Any of you gents know how to remove these switches/blanks.
  9. Feb 26, 2025 at 11:14 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    If you have no plans to reuse the blanks just carefully put a screw into the blank then pull it out. A couple of them have unused seat heater plugs behind them.
    Otherwise you either have to pull that panel which is a total pain to get out because of it nesting behind other panels, or carefully use a plastic trim tool to pop them out. The plastic surrounding the switch is very malleable and can distort from any pry tool.
    Tatts521[QUOTED] likes this.
  10. Feb 26, 2025 at 11:21 AM
    Tatts521
    Appreciate it. Thank you.
  11. Feb 26, 2025 at 11:28 AM
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    I have had good luck popping out the HVAC control panel then pushing the plugs from the back...
    AStinkyBumb, TomTwo and Tatts521 like this.
  12. Feb 26, 2025 at 11:35 AM
    Tatts521
    Forgot about the part too. Jesus my head must be in my ass today. Lol
  13. Feb 26, 2025 at 1:19 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    You can DIY make a flip key using these instructions but there are some caveats: https://www.tacomaworld.com/threads...-programmed-and-coded-for-2015-tacoma.690027/
    Biggest thing is to make sure you buy the correct flip key fob to match your year/transponder chip. My '15 uses a G chip but your '09 might use the "dot" chip or H chip, not sure which don't have it memorized.
  14. Feb 26, 2025 at 2:06 PM
    jamestcurran
    jamestcurran Active Member
    I've removed these before by first removing the cigarette lighter port (I was replacing the lid anyhow) and reaching a finger in behind to push the blank out.
    You'll need to push back to little tabs to remove the cigarette lighter port, It's tricky, but I was able to do it with a snipe-nose pliers (using them to push outwards, not grip).
    Hope this helps.
  15. Feb 26, 2025 at 2:11 PM
    Tatts521
    Just for my understanding I ended just ripping the whole dash apart. But also had to fix my headunit.. i appreciate the replies
    NmapFE likes this.
  16. Feb 26, 2025 at 2:16 PM
    BigCountry762x39
    TL
    PNW, Oregon!
    that's funny, that first link the key i already have from my F150 its a VW key base, wonder if they are the same ill have to look.
  17. Feb 26, 2025 at 3:09 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    The dildo shifter is a nice touch.
    hinmo24t, Micbt25, scocar and 7 others like this.
  18. Feb 26, 2025 at 3:15 PM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    And a blue one at that.
    reallifedog and lowmower like this.
  19. Feb 26, 2025 at 3:17 PM
    Tatts521
    It's a king shock end.
    ProStar197 and fatfurious2 like this.
  20. Feb 26, 2025 at 3:54 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Spiker Engineering UltraGauge mount.
