  1. Dec 17, 2013 at 11:52 AM
    anarion55
    anarion55 Well-Known Member
    Tony
    S. Florida
    2013 PreRunner SR5
    ImMrYo's Mirror Mod, Stereo Upgrade - Power Pro 60x4 Amp/Kicker powered 8" sub/Pioneer component speakers, PassPort 8500 Radar Detector, Locking Bed Storage Cubbies, Onboard air system - Viair 450C compressor/16 gal. PVC tank/15 & 16" horns, quick-d/c air chuck in bed cubby 24" LED light Bar (mounted to skidplate)A Headlights, foglights interior lights and backup lights all converted to LED (HUGE difference)
    Many tires take 80psi or more. Our Silverado takes 80psi, and the toyhauler tires take 95. Both are E-rated.
    When not loaded heavily, we back the Silverado down to 55, and the toyhauler down to 80.
  2. Dec 17, 2013 at 11:57 AM
    BradyT88
    BradyT88 Well-Known Member
    But those are both full size pickups. Mine is a mid-size that will never see that kind of weight. At least, it wouldn't be wise for a midsize to see that kind of weight...
  3. Dec 17, 2013 at 1:27 PM
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Speedway Blue 06 TRD Off-Road
    Leer 100XL Topper OME 885X/Nitrocharger Sport Front Dakar Leafs/Nitrocharger Sport Rear
    Your axle seals will have something to say about it if it does see that kind of weight... :(
    When doing commuter duty I generally run about 35psi front, 32psi rear. When hauling, I air up to 40-50 depending on what I'm pulling.
    Any higher when not hauling, and I see a lot of wear down the center of the tread vs. the outer edges, telling me that the tires are ballooning unnecessarily. I settled on my numbers with the chalk method, and I'm happy with the wear distribution on my Duratracs after about 15000km.
  4. Dec 17, 2013 at 1:56 PM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Running a 285/75 on a mid size truck under 40 psi is too much surface contact to the road and the sidewalls will be too soft. That all means poor mpg. Offroading lower psi towing or hauling higher psi
  5. Dec 17, 2013 at 3:42 PM
    anarion55
    Tony
    S. Florida
    2013 PreRunner SR5
    Actually, a Full-Sized truck (2500HD Duramax/Allison) and an RV - which weighs 6 tons, loaded.
    Tongue weight is never more than1400-1500 lbs; Since it's a 3/4 ton truck, that's within its capabilities. Additionally, we use a weight-distributing hitch, which puts a portion of the load onto the front axles as well as the rear. >30k miles of hard towing with no problems.
  6. Dec 17, 2013 at 3:45 PM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Some folks look down on the chalk method. I did it to mine with 265/75/16 Hankook AT tires and mine was 32 front, 28 rear. It must have worked, I have tread wear evenly across the tires and they are now at around 72K miles on them. They need to be changed, next month I get new ones exactly like these. But I sure beat that 50K mile warranty period with them good. :)
  7. Dec 17, 2013 at 3:51 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Truth? What should a 285/70/17 be at?
  8. Dec 17, 2013 at 4:04 PM
    Eric F
    Eric F Well-Known Member
    AZ
    2014 DC SB TRD-OR 4x4
    Anytime fog lights, U.S. Off Road-Winch Mount Bumper, diff breather, Doug Thorley mid pipe
    It will all come down to tread wear, handling, comfort and safety.
    On my 01' Dodge 2500 I had 285's on a 9x16 wheel at 70-75 front (heavy motor) 50-55 rear, good even tread wear and mileage. Depending on what I needed to haul the rear weight would go up.
    E
  9. Dec 17, 2013 at 6:15 PM
    InTheRough
    InTheRough Well-Known Member
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    Just finished 3M Matte Black hood vinyl to cut down LED bar glare.
  10. Dec 17, 2013 at 7:13 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    And a lower maximum speed before hydroplaning occurs.
  11. Dec 17, 2013 at 7:29 PM
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
  12. Dec 17, 2013 at 7:58 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    This is what I run on my 285/70-17 DuraTracs.
    Higher pressures might give one a little better fuel mileage because of less rolling resistance - i.e. Only running on the centers of the tires, wearing them out before the edges.
    Even tread wear=longevity. For me, higher pressures are also uncomfortable on load range D tires.
  13. Dec 17, 2013 at 8:06 PM
    CVYota
    CVYota Yarrr, me be Captn Andy
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Tracked down the clunking noise to a bad upper ball joint. Toyota wants to replace the whole UCA for 350 plus labor...lol
    O'Reilly's has a Moog replacement ball joint for 40 bucks
  14. Dec 17, 2013 at 8:15 PM
    CanadianMade
    CanadianMade Well-Known Member
    Central BC, Canada
    2005 Tacoma DCLB Sport
    factory hard tonneau cover, side rails, 265/70/17 General Grabber AT2's, Custom Seat Covers, More to come....
    how did you narrow it down to your ball joint? how did you test it?
  15. Dec 17, 2013 at 8:22 PM
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    I can move it up and down by hand. I have to see if the clip came off or needs a total replacement. Weekend project.
  16. Dec 17, 2013 at 8:28 PM
    CanadianMade
    Central BC, Canada
    you could move it when the truck was sitting there under it's own weight or tire drooping?
  17. Dec 18, 2013 at 5:19 AM
    YankeeVol
    YankeeVol This We'll Defend
    Darrell
    Anchorage, AK
    '13 DC XSP-X 4x4
    Bought an ARB recovery strap and a couple shackles
  18. Dec 18, 2013 at 6:08 AM
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Completed ProEFX mirror install and I love them. Driver's side was a real PITA for running an additional wire for the marker/signal light... Already had heated mirrors so didn't need to run anything for that.
  19. Dec 18, 2013 at 6:39 AM
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Cranked the tire as it was parked, the ball joint between the UCA and the knuckle can be moved up and down and grease is coming out, the clunk happens when I turn, I imagine it is the ball joint popping out of place? The other side doesn't do the same.
  20. Dec 18, 2013 at 7:05 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Yup that would be bad
