  1. May 3, 2014 at 7:55 PM
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    The OneBob is all over it!
  2. May 3, 2014 at 9:17 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Headed to El Mirage with BeeRadd to do a little photoshoot.
    Also got into a little stick situation...was trying to read a trail sign and didn't notice the 5 foot washout on the passenger side...fell into it at under 10mph, but it bent the HELL out of my Method Double Standard, popped the bead, and left me dangling my jimmies for the world to see! Oddly enough, the truck rolled out of that in reverse without lockers :confused:
    We got the spare switched out no problem and were back on the trail in 30 min...after a beer. My hi-lift was having issues so I left it at home. 2 bottle jacks did the job.
  3. May 3, 2014 at 9:21 PM
    CorpsmanUp
    CorpsmanUp Well-Known Member
    Gibby
    Suffolk, VA
    2013 Taco DCLWB 6in lift 35s 4.56s, air lockers AP F&R bmpers warn 10k winch Rigid fogs & floods custom pro top shell
    6in procomp stage 2 lift with PC Coilovers, 35x12.50 Nitto MTs, Moto metal 18x10 with -44 offset HID and LED's everywhere, ladder bars, rear disk brake conversion, hood struts, K&N cold air intake, Flowmaster 40 series, pro comp skid plates, train horn, pa system, all silver trim inside painted black all pro apex front bumper with full hoops warn 10k winch, all pro high clearance rear bumper with custom door hinge tag holder, pro top custom windowless camper shell. ARB onboard air compressor, rear ARB air locker, 4.56 gears front and rear, waterport pressurized water system, pop and lock tailgate.
    Awesome looking Taco. And that rut definitely looks like one SOB as well as the bottle jack tire change
  4. May 3, 2014 at 9:31 PM
    LilRob
    LilRob Member
    Rob
    Oregon
    14 TRD Sport Double Cab
    Revtek level kit, AFE Intake. HID headlights and fogs, electric running boards, tri-fold bed cover
    Had Revtek level kit and Hercules MT's installed today
  5. May 3, 2014 at 9:34 PM
    pasotaco
    pasotaco Well-Known Member
    Central Coast, CA
    2013 4x4 Access Cab
    LCE headers, King 2.5 Coilovers w/ res, TC UCA's, King resi's in rear, Geared to 4.88, rear locker, Timbren Bump stops, All Pro Leafs, Carrier bearing drop kit, ARB onboard air,
    This is by far my best ever what have you done to your Tacoma Day!
    Started like this:20140429_165055_resized_1_c8ba658b80d8924439fbb542bea40773a4b602d0.jpg
    Then I put on Coilovers and a new UCA:20140503_122430_resized_c16054813d185df3a96e3389280f50784b176047.jpg
    Then I had to do a little grinding:
    To get these to fit:
    Then I added a 2" Block in the rear (forgot to take a picture) and got new tires put on:
    Then took the wife wheeling:
    And drove over some beaver ponds with a bud:
    And drank some beer!
    RickTRDSport likes this.
  6. May 3, 2014 at 11:58 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    I must have missed the post lol
    Sorry. To get to the fogs either pop the button out or remove the upper dash piece
  7. May 4, 2014 at 12:06 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    What did you have to cut/grind to fit your shocks?
  8. May 4, 2014 at 12:26 AM
    pasotaco
    Central Coast, CA
    2013 4x4 Access Cab
    The bracket where the lower mount of the shock sits and is bolted on. The king shock has a wider lower mount body than the original and the bolt would not line up. I had to take not quiet an 1/8" off the inside of that bracket to get the new shock to line up and get the lower mounting bolt through.
  9. May 4, 2014 at 12:32 AM
    bullaculla
    Da big big island!
    The lower shock mount. Most aftermarket shocks wont drop in. Too late now, but take a bolt with two nuts and use it as a jacking bolt to open it up a bit. Preferably fine thread, and use anti seize. You have to hold the head to keep it from spinning. If you open it up too much, it'll close back down when you tighten up the shock bolt.
    Congrats on the kings tho! :)
  10. May 4, 2014 at 12:42 AM
    pasotaco
    Central Coast, CA
    2013 4x4 Access Cab
    I didn't have to widen the bracket, I had to grind where the arrows are pointing...This was making the lower mount stick out and not line up. Thanks for the picture!
  11. May 4, 2014 at 1:06 AM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    That shot is the money shot!!!:cool:
  12. May 4, 2014 at 1:06 AM
    bullaculla
    Da big big island!
    Ahh... Got it. My fox shocks were pretty close as well as the icons I helped install, but not touching. I guess kings are beefier :D
  13. May 4, 2014 at 1:12 AM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Used your photo for my computer screensaver!!...
  14. May 4, 2014 at 4:59 AM
    vanillion
    vanillion Well-Known Member
    Canadia
    09 trd offroad
    superduty axles swap, custom 3 link front, chevy 63's rear
    made a new lopro sub box for my access cab.
    3/4" mdf covered in a $5 door mat i got from canadian tire
    sounds just as good as the original JL sub box!
    fits nicely between the seats
  15. May 4, 2014 at 9:50 AM
    TacoBrady
    TacoBrady Well-Known Member
    Brady
    Maryland
    2014 Tacoma TRD Sport
    5100 series Bilsteins set at 2.5", 2" block in the rear, spidertrax 1.25 wheel spacers, factory skid plate, Avid Off Road light bar, Clazzio leather seat covers, led interior lights/tag lights/reverse lights, Go Rhino running boards, Custom one piece driveshaft, TRD exhaust, TRD Pro Grille, Depo Tail lights, Truxedo Bed Cover.
    Gave her a bath!
  16. May 4, 2014 at 10:20 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Took off the All-Pro light hoop for repaint. Sanded it down to remove loose powdercoat and sprayed it with Rust-Oleum Hammered black paint.
  17. May 4, 2014 at 11:20 AM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Hey...what are those shaded things on your headlights? I like that!
  18. May 4, 2014 at 11:23 AM
    bullaculla
    Da big big island!
  19. May 4, 2014 at 11:30 AM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
  20. May 4, 2014 at 11:42 AM
    ponchosportal
    ponchosportal Well-Known Member
    Kansas City
    2014 DC TRD TOW
    Tailgate reinforcement, mud-flap removal, weathertech floormats, Pop-N-Lock, ARK Power Pak, Bed-rail shovel mount, Hose-clamp tailgate, equalizer WD hitch, Firestone Ride Rite Air Bags w/Daystar cups,
