  1. Dec 29, 2014 at 8:59 AM
    skygear
    skygear                    
    last thing I will leave you with is this. IF you are going to put your relays in the engine bay. Get the weatherproof relays and harness. DO not use the ones they give you. You will have to cut the harness up anyways to make it work in the config you want. Just do it the right way from the start.
    http://www.amazon.com/HELLA-0077943...d=1419872059&sr=8-1&keywords=waterproof+relay
    http://www.amazon.com/HELLA-H847090...onnector/dp/B000VU9D0C/ref=pd_bxgy_auto_img_y
  2. Dec 29, 2014 at 9:06 AM
    MAUL747
    MAUL747 Well-Known Member
    Michael
    Hartsville, SC
    14 DCSB SR5 4x4 6SPEED
    Husky liner floor mats, Scanguage II with blendmount, Panavise-ram mount for Garmin, 27% on fronts, Crystalline70 on windshield
    Thanks man ill do that. i thnk what im gng to do is run two relays one to convert the negative switch to positve then run that positive into the harness that comes with the kit(which is weatherproof) so i dnt have to modify the harness that comes with the bar and so i have power for my lighted override switch that is in the cab. does that sound like a decent set up or is that a mess waitin to happen?
  3. Dec 29, 2014 at 9:19 AM
    skygear
    skygear                    
    nope. tjhat will work too. just mind the rats nest of wires.
  4. Dec 29, 2014 at 9:23 AM
    MAUL747
    Michael
    Hartsville, SC
    Thanks alot for the help.
  5. Dec 29, 2014 at 9:44 AM
    fxbrry
    fxbrry Well-Known Member
    I removed all the badges and TRD sticker. Plasti dipped the front Toyota emblem. Now just waiting for my black wheels and Nitto tires to come in to finish the no chrome / shinny look.
  6. Dec 29, 2014 at 10:13 AM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I just called him to hopefully get one. Will it hold a 34?
  7. Dec 29, 2014 at 11:35 AM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Thank you brother!
  8. Dec 29, 2014 at 2:41 PM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
  9. Dec 29, 2014 at 2:45 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    :woot:I wish we got snow like that around here. This is all we usually get --->:rain:
    I just drove my truck in the rain today...boring. :pout:
  10. Dec 29, 2014 at 2:46 PM
    xtyfighterx
    Ty
    Ya I'm hoping for more it dumped a bunch a couple days ago
  11. Dec 29, 2014 at 3:44 PM
    CC7242
    CC7242 Well-Known Member
    Lakeland,FL
    14 Pre Runner SR5
    HAM Radio and Glass Mount Antenna, Plasti Dipped badges
    Plasti Dipped the front grille and emblem and relocated the horns, waiting for my BAMF mount to come in.
  12. Dec 29, 2014 at 4:05 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Where did you put your horns?
  13. Dec 29, 2014 at 4:30 PM
    CC7242
    Lakeland,FL
    14 Pre Runner SR5
    Used the radiator support to mount the horns and the temp sensor. There are already holes there. You will need some hardware to mount the horns again. But there is a slot that the temp sensor will fit into perfectly. I will say, it was a bit of a PITA haha. Its pretty stright forward, just a bit time consuming if you've never done it before.
    I used this method
    http://www.tacomaworld.com/forum/2n...atoshi-grill-horn-relocation-w-lots-pics.html
  14. Dec 29, 2014 at 4:45 PM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    Drove mine 150 mile on 37k used big fails in a blizzard in the dark at 3am. Only used 4wd high for about 20 miles.
  15. Dec 29, 2014 at 4:52 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    You've got balls my friend, although depends how cold it was and how much snow was on the road
  16. Dec 29, 2014 at 5:20 PM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    Installed Sylvania led license plate bulbs, Philips gy6.35 35 watt reverse light bulbs, and painted my badges satin black. That's fresh paint right there.
  17. Dec 29, 2014 at 5:35 PM
    CamoNBlaze
    CamoNBlaze Well-Known Member
    Zach
    '09 V6, 6 speed
    I threw an Innovated 55w HID conversion kit in today. Unfortunately one of the lights is slightly bluer and flickers when turning on, so I'm getting a replacement ballast.
    On the bright side (pun intended) they really light up the road. Further the bulbs are shrouded on the bottom and so they can be used in stock housing with blinding others (just have to make sure to aim headlights properly).
    Anyway, I was pretty excited. I'll post pictures once I get the new ballast in!
  18. Dec 29, 2014 at 5:40 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Picked up a slightly used (less than 1 year old) TRD cat back exhaust off of Craigslist for 200$. Super pumped over this deal.
  19. Dec 29, 2014 at 5:50 PM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Great pic!:p
  20. Dec 29, 2014 at 5:57 PM
    darkfader
    darkfader Will this fit without rubbing?
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    X 100000000000000000000
    Love that pic tyfighter! Can't wait to get some snow around here.
