  1. Feb 10, 2015 at 6:59 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
  2. Feb 10, 2015 at 7:25 AM
    ScottInOKC
    ScottInOKC Well-Known Member
    Scott
    Oklahoma City
    I can only assume the factory plugs were gapped to ~0.4, but when I pulled them, they were up to ~0.55. I'm not sure what the max effective gap is, but I was surprised to see that big of a change in only 30k miles.
  3. Feb 10, 2015 at 7:27 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    It'll be AH'IGHT
  4. Feb 10, 2015 at 7:32 AM
    Silent1
    Silent1 Well-Known Member
    Clay
    Drexel, North Carolina
    16 DCSB TRD OR
    Thanks, that's good to know.
  5. Feb 10, 2015 at 7:54 AM
    thebestofme
    thebestofme Well-Known Member
    Golden
    2010 TRD OF
    I'll see if I can head down to the parking garage during my break to snap a few. There was some tight parking going on so I may not be able to open my door enough. Ha!
  6. Feb 10, 2015 at 8:23 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    ^ok cool was just curious as to how it looked with the gray interior. kinda want to do the same
  7. Feb 10, 2015 at 9:40 AM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Credit goes to you Brad. I love the clean install and the fit. I couldn't of asked for a better lighting kit and it is def priced right.
    :woot:
  8. Feb 10, 2015 at 9:41 AM
    JohnnyWayne
    JohnnyWayne The Past Through Tomorrow
    Johnny
    Lantana, FL
    '12 DCLB TRD Sport
    Look out for snakes in the grass guerrilla marketing.
    Was getting some rust on my stock skid so rattlecanned it :)
  9. Feb 10, 2015 at 9:54 AM
    TacoBrady
    TacoBrady Well-Known Member
    Brady
    Maryland
    2014 Tacoma TRD Sport
    5100 series Bilsteins set at 2.5", 2" block in the rear, spidertrax 1.25 wheel spacers, factory skid plate, Avid Off Road light bar, Clazzio leather seat covers, led interior lights/tag lights/reverse lights, Go Rhino running boards, Custom one piece driveshaft, TRD exhaust, TRD Pro Grille, Depo Tail lights, Truxedo Bed Cover.
  10. Feb 10, 2015 at 10:16 AM
    la0d0g
    running for the hills
    For crawling not hauling
    I hope you used this method to make it easier.
    https://www.youtube.com/watch?v=vkVLBOnAifc
  11. Feb 10, 2015 at 10:26 AM
    TacoBrady
    Brady
    Maryland
    I got rid of the strut spacers and installed 5100's. I set them at 1.75 but now the front end sits a touch lower then it used to. The ride is 100% better from what it used to be so that's good. I can live with the slight rake for now but I think once summer rolls around Im going to set them at 2.5. Im also going to install a pair of Eibach coils to help ease the stiffness that setting the billys at 2.5 would cause.
  12. Feb 10, 2015 at 10:29 AM
    la0d0g
    If your going to get new springs why not get some that provide the 2.5" of lift instead of loading your 5100s? It'll ride much better.
  13. Feb 10, 2015 at 10:42 AM
    TacoBrady
    Brady
    Maryland
    I never thought about that, Ill do some research. Thanks for the tip!
  14. Feb 10, 2015 at 10:48 AM
    la0d0g
  15. Feb 10, 2015 at 10:53 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    Agreed, get the OME885's and set the Billies to 0. You should be level. At the end of the day I would prefer a slight rake vs. the truck squatting a tiny bit. This ain't a big ole chevy after all lol.
  16. Feb 10, 2015 at 11:00 AM
    TacoBrady
    Brady
    Maryland
    That sounds pretty good to me. Thanks guys! Ill look into those right now! lol.
  17. Feb 10, 2015 at 12:01 PM
    BeaverYota
    BeaverYota Oregon State Edition
    Josh
    Lake St. Louis, MO
    Sold...
    Moved my knife to a better location and easier to grab
  18. Feb 10, 2015 at 12:30 PM
    MTyota
    MTyota Well-Known Member
    Bozeman, MT
    05 Tacoma 2.7 5spd SR5 4x4
    ABS switch, tailgate lock, factory fogs, tonnopro loroll, icharger aux cable, 10mm hex oil plug swaps
    Installed ABS switch for snowy roads and mud. Had to modify the switch insert with a dremel wheel to fit a toggle with a race cover. Had the wire around so only cost $14 cause i needed tape and some splicers.
    Also ordered up some new 10mm hex magnetic plugs (like the ones on the front dif) to replace the 24mm ones on the tranny, rear dif and transfer case. People have done it on older pickups and 1st gens so figured i'd try it out. $2 ea for plugs and $1 for crush washers, $18 for everything.
  19. Feb 10, 2015 at 12:35 PM
    Yota64
    Yota64 Professional Threadjacker
    Didn't know you could switch ABS.
  20. Feb 10, 2015 at 12:36 PM
    BeaverYota
    Josh
    Lake St. Louis, MO
    Sold...
    There's a lot of threads on it
    Considering doing it myself
