  1. Nov 18, 2016 at 7:12 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    This happened this morning. Gas light came on at 283 miles, I pushed it to just over 300 to get to the gas station (Kroger for discounted gas). Haven't done the actual math but obviously with bigger tires it's actually more than that. Let's say I was a little nervous about running out.
  2. Nov 18, 2016 at 7:22 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Remember bigger tires will make your odomitor read incorrectly, so you might have gotten a little better mileage than you thought. I've got 265/75/16's which makes mine is off by 3%, and I know some guys with 35's say there is off by 12%.
    ChadsPride likes this.
  3. Nov 18, 2016 at 7:24 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    Yeah if I remember correctly mine is off by 9%, that's why I said the miles would actually be more since I have bigger tires. Doing the math I put just over 18 gallons in so I got 16.6 (uncorrected) mpg.
  4. Nov 18, 2016 at 7:28 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Ended up keeping the amber fogs. Since last year, I have switched out the G2's for Bridgestone Revo II. Turns out the noise was not the tires but rather my wheel bearings. Once that was fixed, the tires are quiet as can be. Replaced my tonneau vinyl a few weeks ago as the old one was starting to show it's age (7 years).
    Also recently decided to finally install my LED back up lights (flush mount in the bumper). Put it off for over a year as I was apprehensive about cutting up my bumper. They do not sit 100% flush due to the curve of the bumper but I knew that going in and was part of the reason for waiting so long. I'm going to fill the top gap with black RTV sealant for appearances. I covered the bumper cut areas with painters tape, marked my cuts, used a 3/8 drill to mark the corners and then an angle grinder cut off wheel to make the straight cuts.
    Also relocated my trailer wire harness as long as I was cutting up the bumper anyway. I used the OEM plug but since it only has the 2 bolts on one side, it did feel firmly attached when disconnecting the trailer wiring. So I added 2 #4-40 bolts under the cap in the two little triangular areas to snug it up. I used a 2-1/4" metal hole saw to make the cuts. As you can see below, the saw jumped and I scratched the paint a little (even trhough the painters tape which was very little security anyway) below the outlet but used some touch up paint to cover it.
    Lastly, I removed my custom TRD beach cruiser bedside decals since they were not good quality to begin with and were starting to bubble and flake and replaced with 2016 model TRD 4x4 Sport decals. Pics in next post.
  5. Nov 18, 2016 at 8:28 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Sweet! Mine should be arriving any day now! I was hoping to get them done before it gets cold (well, Texas cold) as I've heard the heat make the install easier.
  6. Nov 18, 2016 at 8:30 AM
    Mitch76
    Mitch
    San Angelo, TX
    Really dig those back up lights. Did you wire them into the back up lights or are they switched?
    Kuntrykid and ChadsPride like this.
  7. Nov 18, 2016 at 8:35 AM
    KeithB
    Keith
    Cheshire, CT
    They are on a switch. I had backup lights mounted under the bumper but wanted to move things up out of the way and cleaner looking. So I alraedy had the wires there.
  8. Nov 18, 2016 at 8:38 AM
    KeithB
    Keith
    Cheshire, CT
    You can go at least 50 miles after the light comes on
  9. Nov 18, 2016 at 8:43 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I think that may be accurate....if you're stock..
    la0d0g, Kuntrykid and ChadsPride like this.
  10. Nov 18, 2016 at 8:45 AM
    trdsport6
    trdsport6 Well-Known Member
    West NC
    2015 Super White access cab TRD
    bilstein 5100 @2.5 front and rear Method NV BFG KO2 275/70/17
    Fixing to buy some new headlights if everything goes through with the seller! :cheers:00F0F_kz6lQqWAvz0_600x450.jpg
    Kuntrykid, Soul Surfer and ChadsPride like this.
  11. Nov 18, 2016 at 8:46 AM
    Celphdesigns
    Celphdesigns Member
    Texas
    2012 TRD Sport AC
    I'm sure it would have been a little easier in the heat but it still wasn't too bad. Just took some extra force.
    Mitch76[QUOTED] and ChadsPride like this.
  12. Nov 18, 2016 at 8:47 AM
    LastShot457
    LastShot457 Well-Known Member
    Aaron
    Ohio
    2012 Magnetic Gun Metallic V6 TRD 4x4
    Window Tint (35% front, 15% Rear), K&N Short Ram Intake, Bushwacker Fender Flares, Fab Four Vengeance Front Bumper, 20" BlackOak Light Bar
    70° in Ohio? Perfect time to rotate some tires before the snow hits.
    If you are curious on the rotation pattern that I chose, here is a picture.
  13. Nov 18, 2016 at 8:49 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    did the same pattern for mine a few weeks ago.
    That's pretty standard for 4wd vehicles.
  14. Nov 18, 2016 at 9:25 AM
    BeasleyNC
    BeasleyNC Well-Known Member
    Brad
    06 Tacoma Access Cab 4x4
    5100's on 884's , Wheelers Progressive AAL, GTA Carkit Bluetooth Adapter, WeatherTechs, Extang Solid Fold 2.0
    Picked my truck up from the frame replacement yesterday. Had them install 5100 Billies all around with 884 OME coils with LR UCA's. Drives like a brand new truck! Kudo's to toyota for standing behind their product and spending insane amounts of money on these frame replacements. I was told the invoice to Toyota was around 15k!
  15. Nov 18, 2016 at 9:29 AM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
  16. Nov 18, 2016 at 9:44 AM
    TacoRph
    TacoRph How 'bout them Dawgs
    2015 MGM TRD OR 4WD
    Ordered, received and installed the bed net. I think it'll come in handy for camping trips!
  17. Nov 18, 2016 at 9:46 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I just wanna lay on it..
    you should test it.. bed hammock
  18. Nov 18, 2016 at 9:50 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    7.5% for 255/85's which are microscopically taller than 285's so that should work close enough
    this
    usually have burned right at 17.5 when my light comes on so you should have nearly 4 gallons left, so as long as you are getting better than 12.5 you should be good for 50 miles
  19. Nov 18, 2016 at 9:51 AM
    TacoRph
    2015 MGM TRD OR 4WD
    Heck yeah man! I guess I don't need this air mattress any more that I just bought...
  20. Nov 18, 2016 at 10:10 AM
    Caprizzy
    Caprizzy Well-Known Member
    David
    Lake Stevens,WA
    2013 Silver Streak Mica, DCLB TRD Sport 4x4
    GO HAWKS!!
    Nice, where did you get that switch?
    scottalot likes this.
