  1. Jan 3, 2018 at 6:52 AM
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
    I'm so tempted by this, but it looks like a ton of work. How hard was the wiring?
  2. Jan 3, 2018 at 6:52 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Bunch of info here. In the first post there is the spring heights and ratings
    https://www.tacomaworld.com/threads/old-man-emu-questions-answers-pictures.258245/
    Your spring lbs are wrong and you can run 887s for 3" without a 3/4" spacer without armor.
    kiahb12[QUOTED] likes this.
  3. Jan 3, 2018 at 6:54 AM
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    True. That is always a possibility. I'd say my chances are pretty slim. What do you suggest otherwise?
  4. Jan 3, 2018 at 7:04 AM
    DC-USAF
    DC-USAF Well-Known Member
    Dale
    WNC
    2015 SR5 Access Cab 4x4 V6
    TRD PRO Grill, mobtown offroad recovery bar, SCS Ray 10's
    I would hope not. I don't trust to many people though.
    If a Tacoma owner wouldn't steal a cooler, why do you need a lockable storage box with a security cable inside of a lockable compartment (truck cab)? :notsure: Just my observation. Locks, cables, and chains are used to keep honest people honest, if someone wants what you have bad enough they are going to take it no matter what you do.
    freddy2923 and toysrgood like this.
  5. Jan 3, 2018 at 7:08 AM
    toysrgood
    SC
    2011 4x4 Reg Cab
    You're absolutely correct. If someone comes up and has a cutoff wheel, tool bag, or BFH they'll have anything they want off our trucks.
    I figure with this chain and lock I'll deter a majority of snatch and grabs. If they can't get it in a minute or two they'll move on. I feel like I've made a pretty secure setup that will stop all but the most determined. I'd bet a simple cable lock would prevent quite a few if they aren't determined enougb. But we'll never know someone walks away unless there's evidence.
    Also, some states require firearms to be locked in some way, shape, or form.
  6. Jan 3, 2018 at 7:10 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I think you missed the part where it was suggested a Tacoma owner would likely have the tools readily available to remove the bolt used to secure the cooler. No such intimation was made regarding the lock box.
    DC-USAF[QUOTED] likes this.
  7. Jan 3, 2018 at 7:15 AM
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
    I've been wanting to do this and curious if the turn signals will work. The necessary wiring is there so it's baffling as to what else is missing. Anxious to figure this out.
  8. Jan 3, 2018 at 7:16 AM
    DC-USAF
    Dale
    WNC
    For the bolt, I'd get a longer bolt and use a lock nut on it. I don't know about the D-rings, I removed mine to install bed stiffeners. Maybe install bed stiffeners and use a second lock?
  9. Jan 3, 2018 at 7:17 AM
    toysrgood
    SC
    2011 4x4 Reg Cab
    Not a bad idea. I've thought about the bed stiffeners before, that would be pretty secure and I think they usually have an area that can be used as a tie down.
  10. Jan 3, 2018 at 7:19 AM
    sask.taco91
    sask.taco91 Member
    going to cut out around the holes and use bondo glass, its bondo with fiberglass fibers in it, then paint match and hope it works, have duct tape on it for now. bought the truck just before Christmas and the guy said one bolt was loose, not every. Atleast I got a good deal on the truck. I am really surprized the head liner has no stain or signs of water leaking on it at all tho.
    Casper66 likes this.
  11. Jan 3, 2018 at 7:23 AM
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    I not telling you what to do with your truck, but if you have any intension of keeping it for any period of time. please let a professional weld patch's the proper way & you'll be very happy you did!
    the bondo will look like crap & probably crack.
  12. Jan 3, 2018 at 7:27 AM
    toysrgood
    SC
    2011 4x4 Reg Cab
    I
    I filled my bolt holes from the previous owners lightbar with some clear silicon. They've held up great so far. I still haven't come up with a permanent solution yet, or should I say I can't afford one.
    I intend to keep the truck after it's paid off and buy a double cab for the family, my reg cab will be my hunting truck.
  13. Jan 3, 2018 at 7:29 AM
    DC-USAF
    Dale
    WNC
    I would at least stop drill where the torn metal ends. As the metal expands and contracts it could get worse over time. Good luck with however you repair this.
    Doogz likes this.
  14. Jan 3, 2018 at 8:10 AM
    Jhammerson93
    Jhammerson93 Well-Known Member
    Justin
    05 tacoma SR5 4x4
    2.5" leveling kit, aftermarket 16" rims, 2" hub centric wheel spacers
    Went to bleed my brakes after changing out the pads and this happened.... I've never had a bleeder break off, but this puppy was seized up pretty damn tight and she gave way. So a 5 min bleed turned into a full caliper replacement lol. At least it looks shiny!!IMG_0730.jpgIMG_0729.jpg
    Kuntrykid and gabbo2112 like this.
  15. Jan 3, 2018 at 8:19 AM
    Trey5150
    Trey5150 Well-Known Member
    2015 Black Taco DCSB TRD
    Leveling kit, Flowmaster exhaust, Warrior Front Bumper, Warrior Roof Rack, Ram Mount A-Pillar, Weather Tech mats, Pro grill, Rigid ditch lights, Rigid backup lights, Spod
    Sarcasm! I lock down my cabela’s cooler as well
  16. Jan 3, 2018 at 8:24 AM
    tacozord
    tacozord Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    This past Saturday I replaced my front brake pads with EBC Green Stuff 7000 and flushed my fluid with ATE TYP 200. This was my first time doing brakes and it was really easy.
    Currently, I'm having my front Icon shocks rebuilt at DC Shock Services in San Dimas, CA. It'll take them four hours to rebuild my front shocks. I could have shipped them here, but it's about a 4-5 day turnaround, and I'd have to pay for shipping and deal with removing and reinstalling them as well as solve parking at my house around street cleaning days. So this is a easier for only a little more money.
    https://www.dcshockservices.com/
    Crom, jmich2001 and sseaman like this.
  17. Jan 3, 2018 at 8:24 AM
    JayRayger
    JayRayger Wide n’ silver
    Portland, Oregon
    2010 DCSB OR
    Installed some pods and @CaliRaisedLed ditch light brackets the other day.
    Much more to come..
  18. Jan 3, 2018 at 8:42 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    I've heard it's hit and miss. On my '15 SR5 I added the Pro-EFX towing mirrors and the signals just worked.
    jpereira2[QUOTED] likes this.
  19. Jan 3, 2018 at 8:51 AM
    fshams
    Columbus, OH
    I'll have to pull off the door panels and test the leads with the voltmeter to confirm if there is any current for the signal indicators.
  20. Jan 3, 2018 at 9:08 AM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    That sucks! Just curious why you had to bleed the brakes just for a pad change though? There's no reason to have to bleed them unless you're changing a caliper.
    ChadsPride likes this.
