  1. May 2, 2018 at 6:52 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Yea it does not want to go, but you can make it.
    I also did the exhaust chop to accommodate this bad boy.
  2. May 2, 2018 at 6:59 AM
    saltlife19
    saltlife19 Member
    Lee
    2006 Double Cab Indigo Ink Tacoma
    3 inch Rough Country suspension lift on 33 inch Nitto Trail Grapplers with 16 inch DC2 rims. Flowmaster 40 series
  3. May 2, 2018 at 7:15 AM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Good thing i didnt order that voltage booster yet!
    Yea next vehicle first mod is a dash cam
    I married my tacoma likes this.
  4. May 2, 2018 at 7:21 AM
    ManBeast
    Zach
    Orange Park FL
    Most my mods are in the audio system, so thats good for me. If it is infact totalled am i allowed to put the factory bumper back on and sell that 1? Never been in this situation before
  5. May 2, 2018 at 7:39 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Thanks lol. Rare part. Took me years into talking a guy into selling it to me.
  6. May 2, 2018 at 7:39 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    In most cases they will allow you to take parts off as long as you replace them with oem. A junk yard will eventually buy your Taco if its totaled and part it out. It doesn't sound like you've got that many mods, but you can also have your insurance company adjust your coverage to cover your mods. If you have a clean record it usually doesn't cost that much more. Everything is case by case though. Good luck! and at the end of the day nobody is going to pay for your time to deal with this mess, and that's always the part that pisses me off.
  7. May 2, 2018 at 7:48 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    White wheels? Where I didn’t see any.
    ChadsPride likes this.
  8. May 2, 2018 at 8:19 AM
    Cash13
    Cash13 Well-Known Member
    Northern Colorado
    2014 Tundra
    Here!
  9. May 2, 2018 at 8:26 AM
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
  10. May 2, 2018 at 8:27 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Shit that looks good
    tn_popo, Kuntrykid, inesshell and 6 others like this.
  11. May 2, 2018 at 8:29 AM
    Cash13
    Northern Colorado
    2014 Tundra
    :thumbsup::cheers:
  12. May 2, 2018 at 8:30 AM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Changing the brake lines really wasn’t bad. I took maybe 2 hours to swap them out and bleed the brakes because I had never done it before and took my my time.
    Tips:
    • put the rear on jack stands and take the rear driver side wheel and the spare off so you have more room to move around
    • Clean everything with wire/nylon brushes and break parts cleaner before to keep the funk from getting in the brake system
    • It’s helpful to take off the brackets holding the brake lines from frame and from the axle. It allows a little play since the hard lines are at odd angles. You need a 12mm end wrench and 12mm socket. I loosened all the hard line brackets at the axle to give it all more play.
    Pic shows upper bracket held to the frame with 12mm bolts and the 10mm nut that you loosen to separate the hard and soft lines.
    Next pic shows the axle brake line bracket
    • Hold the now unattached bracket with a vice grip while you work the 10mm flare wrench to loosen the nut
    • Have extra rags/paper towels, and little rubber caps to cover the open hard line at the frame when the you remove the nut. An easy answer would be to use the rubber cap from your brake bleeder temporarily (I used the rubber caps from my speed bleeders). The lines don’t spew fluid, they just sort of dribble it out. No matter what break fluid will be spilled.
    Pic shows the rubber caps on the hard lines after the nuts were pulled.
    The lower hard lines did not drip at all...
    • Take the top nuts off, cover the hard lines, take the bottom nuts off, swap the lines somewhere more comfortable. There will be fluid in these lines! I used vice grip to pull the metal clips that hold the soft lines to the brackets and a soft blow hammer to pound them back in with the new lines
    • Reattach in reverse order
    • Bleed your brakes. I have a TRD off road with brake system pump and bought speed bleeders. It made the bleeding an easy 30 min process by myself. Your truck may be different.
    Useful links:
    https://www.tacomaworld.com/threads/installing-extended-brake-lines.494840/
    (#13 is particularly helpful also the video about bleeding brakes in that thread)
    https://www.tacomaworld.com/threads...-4x4-trd-off-road-with-speed-bleeders.368080/
    If you have TRD off-road. Speed bleeders help either way. This link and the video on the thread linked above are helpful.
    Oh and beer. Have a beer handy. It always makes things run smoother.
  13. May 2, 2018 at 8:32 AM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    That's definitely totaled, sorry for your accident but thank God you walked away.
    When I rolled my last Taco the tow yard held it a couple days while I stripped:
    - Aftermarket remote start alarm
    - Double DIN head unit, 2 amps, sub, component speakers
    - Optima battery
    - Tons of exterior LED's
    - K&N engine air filter
    - Windshield wiper stalk
    - Weathertechs
    You get the idea. The vehicle is going to a scrap auction, they sell them as-is, who's to say what was or wasn't lost to the accident or tossed aside by EMS responders? **I am not responsible for you not having the same results**
  14. May 2, 2018 at 8:50 AM
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    Alot of times u get the option of buying it back for a ridiculously low price and u get a check, the ins. Would rather u get it back rather than deal with it, when ur done parting it out, scrap what' left
  15. May 2, 2018 at 8:52 AM
    ManBeast
    Zach
    Orange Park FL
    I want my prs 80 head unit and my 3 amps and 2 15s out. And my 8s in the door. And my 2 runs of 0 guage, also the sliders and other small things like that
  16. May 2, 2018 at 9:29 AM
    ManBeast
    Zach
    Orange Park FL
    I know there are usually a few insurance adjusters on here that chime in on accident posts, anyone know 1 to tag?
  17. May 2, 2018 at 9:50 AM
    91Enforcer
    91Enforcer Well-Known Member
    Western CO
    2008 Access Cab TRD Off Road
    With the new wheels and tires not having TPMS sensors, just opened up my gauge cluster to put 2 pieces of black electrical tape over the TPMS dash light
  18. May 2, 2018 at 9:57 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Ever do a compression check?
  19. May 2, 2018 at 10:13 AM
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2017 4x4 Sport long bed
    6112 shocks and dakar springs 2.5 in lift
    no. thats on the long term list of things to do.
  20. May 2, 2018 at 10:48 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Suggest the same do a tw garage sale.or have a dedicated offroad rig.
    Kuntrykid likes this.
