  1. Dec 27, 2019 at 8:33 PM
    El_Capitan3
    El_Capitan3 @ElCapitan355
    2013 Tacoma TRD Sport 4x4
    Clean and Simple
    Made it up the mountain!
  2. Dec 27, 2019 at 8:53 PM
    FreshPots
    FreshPots "Spared no expense"
    Dylan
    Cuyahoga Falls, OH
    2015 Tacoma TRD Off Road "Lars"
    Never enough
    I would totally rock that, or Empire symbol on mine. I would buy that in a second if he was selling.
  3. Dec 27, 2019 at 9:15 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Do it. I noticed the biggest difference from sound deadening. I have a full sound system and that's what did it for me at least
    GonzoQuick likes this.
  4. Dec 27, 2019 at 10:54 PM
    wannabemtnbiker
    wannabemtnbiker Well-Known Member
    Derrick
    Georgetown Tx
    2008 White Tacoma Prerunner
    Understand what you mean. Mine gave the other 3 speeds up a good while back.
    My roommate got it from Amazon for $19.99
  5. Dec 28, 2019 at 12:14 AM
    20somethingwidataco
    Will
    Washington State
    I dig the catch can. Something I've wanted to do as well. Just because I'm running out of small things to do to my truck
    dino41[QUOTED] and Matmo215 like this.
  6. Dec 28, 2019 at 12:16 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I just ordered an Ultragauge, pretty inexpensive for what it is and im excited for all the features
  7. Dec 28, 2019 at 1:28 AM
    MasonSTL
    MasonSTL Well-Known Member
    Green Bay, WI
    06 TRDOR AC MT
    This might sound wierd, but deadening the roof would probably be the best. It's just the thin flat sheet metal of the roof behind that thin felt liner.
    GonzoQuick, Fleabag and Trikster like this.
  8. Dec 28, 2019 at 3:57 AM
    DG92071
    DG92071 Well-Known Member
    It'll help but not a whole lot of noise comes from up there as the rest of the vehicle blocks the sound waves.
  9. Dec 28, 2019 at 5:25 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Where did you get the bracket for your catch can?
    TomTwo likes this.
  10. Dec 28, 2019 at 8:05 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    All cleaned up and ready for the dance!
    Also I finished my tranny flush. (Gender neutral gear shifting device) it took about 12qt to get it to pump fresh fluid out of the return line below the radiator. I added a bottle of lube guard and then checked the fluid level using the AT temp/fluid check process. My truck does not flash the AT light when you put it back in park, but it did illuminate after 20 minutes.
    I double checked the fluid temp with my multi meter as it drained out. Overall a very easy process that I highly recommend, given my situation of cooking the old fluid past it’s usable point.
    My transmission is back to 95% health. Reverse is back to normal. I still have a little bit of a hard shift into 3rd from time to time. Just glad I didn’t have to do a full rebuild.
    Just Incase you are wondering this was not due to normal driving conditions. I pushed my truck was past the edge for a lot longer than I should. Maybe one day I will settle down. LoL
    Oh and I must have ripped one of my mud flaps off during my romp in the mud, noticed it was gone after I washed Betty.
  11. Dec 28, 2019 at 8:08 AM
    henrilepuf
    henrilepuf Well-Known Member
    henri
    Northwestern Paraguay
    tacoma 2014 4x4 DCLB
    How often do you empty the oil catch can ?
  12. Dec 28, 2019 at 8:09 AM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    Every oil change is what I do, been running one for 50k miles
    TomTwo and dino41 like this.
  13. Dec 28, 2019 at 8:54 AM
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
    Leather wrapped steering wheel, added custom emblem. Installed Husky mud flaps.
  14. Dec 28, 2019 at 8:57 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    The old steering wheel emblem just pops right off?
    DG92071 likes this.
  15. Dec 28, 2019 at 9:05 AM
    SeanBonham
    Sean
    Derby City
    DG92071 and boogie3478[QUOTED] like this.
  16. Dec 28, 2019 at 9:06 AM
    Hunterdc1
    Hunterdc1 Propane and Propane Accessories
    Brrrrother
    No I will not press 1 for English
    13 8 lug ltz gasser
    I dig the steelie look man. Where are they from abd are they 17's?
    baldridge likes this.
  17. Dec 28, 2019 at 9:10 AM
    SeanBonham
    Sean
    Derby City
  18. Dec 28, 2019 at 9:20 AM
    dino41
    dino41 Well-Known Member
    San Diego, California
    2015 Sky Silver Crew Cab V6 SR5 Prerunner
    Every oil change (4,000 miles). Average about 1/4 full.
    henrilepuf[QUOTED] likes this.
  19. Dec 28, 2019 at 9:31 AM
    dino41
    I'm fortunate that my company has a water-jet, plasma and router machine(s). I designed it and had my tech jet it out. All my badging and some are all custom jetted at work.
    TomTwo and henrilepuf like this.
  20. Dec 28, 2019 at 9:49 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Me likey. I got a PowerTray mounted in the same area though so they would probably conflict with each other.
    dino41[QUOTED] likes this.
