  1. Mar 9, 2020 at 7:24 AM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    Thank you for choosing us!:thumbsup:
  2. Mar 9, 2020 at 7:47 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    Is it me, or am I missing something here? LoL
  3. Mar 9, 2020 at 7:55 AM
    Rick_Taco
    Rick
    Indiana
    TacoJoeBro[QUOTED] likes this.
  4. Mar 9, 2020 at 7:59 AM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Why is '09 the most desirable year? :confused:
    I have a 2010... just asking lol
  5. Mar 9, 2020 at 8:41 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    That's an easy fix. Remove supercharger and all associated parts/accessories and ship it to me!
  6. Mar 9, 2020 at 8:47 AM
    jgwilson88
    jgwilson88 Well-Known Member
    Josh
    1999 Tacoma Single Cab, 2009 Tacoma TRD Sport DCSB
    1999 Rear lowered 2 inches 2009 2" Leveling kit
    Where did you get replacement headlights from? I have my stock ones that have already been replaced by Toyota due to a recall but they KEEP getting moisture in them. I have dried them out a few times and it just keeps coming back so im ready just to but some aftermarket but wanting to keep the stock look. Just up in the air on which ones to get bc a lot of reviews I have read said they have gotten moisture with aftermarkets.
  7. Mar 9, 2020 at 9:04 AM
    Rick_Taco
    Rick
    Indiana
    So I got my frame recall notice a few months ago and I am going back and forth on if I should take it in. Do I take it now and have them clean it up and put rust protectant on it? Or do I wait until close to the end to ensure I will get a new frame? I am afraid the sealer they put on it will only make my frame last long enough that they do not have to replace it in the long run. Anyone care to share an opinion?
    Went and checked out my brothers new property. 1/2 mile drive way that I think he should leave rutted up to keep people out. LoL
  8. Mar 9, 2020 at 9:13 AM
    Toysareus
    Toysareus Member Passed Away—2021
    USA
    My opinion on your brothers property. I agree with you and leave it rutted up like you say 2000%
    Rick_Taco[QUOTED] likes this.
  9. Mar 9, 2020 at 10:04 AM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    Need more info on the condition of your frame, is it close to failing, visible holes rusted through? My Brother-in-law just go screwed on a frame replacement because the dealership under coated everything about a year ago, making it impossible to tell how bad the frame really is. He has an area where the leaf spring mount is that is rusted through, still failed for replacement. Now he has to get it welded. I wouldn't let them under coat it, if you can.
  10. Mar 9, 2020 at 10:29 AM
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Sierra Vista, AZ
    Brian422[QUOTED] likes this.
  11. Mar 9, 2020 at 10:32 AM
    JohnT43
    JohnT43 Well-Known Member
    2007 Tacoma
    Radio
    Got new paint on my 2007.
  12. Mar 9, 2020 at 10:37 AM
    Hunter_Bick12
    Hunter_Bick12 Just a Yota guy
    Hunter
    Alabama
    2011 Black DCSB TX TRD Prerunner, 1986 Gray SR5 4x4
    Stubby antenna. Was skeptical, but I actually really like this look and all my favorite radio stations pick up just as good as before.
  13. Mar 9, 2020 at 10:43 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    They apparently aren’t using the black garbage they were for the 05-11 frames. They are mostly hitting the sandwiched sections of frame with a white/yellow wax-like petroleum based product.
    But I’m not sure how your buddies frame didn’t get replaced unless the hole wasn’t bigger than a dime.
  14. Mar 9, 2020 at 11:20 AM
    Rick_Taco
    Rick
    Indiana
    It's not bad at all right now. Just surface/flash rust in areas. I haven't been to a dealer since the day I brought my Taco home, so they have no history to go off of. What happened to your brother is exactly what I am trying to avoid. Thanks for the feedback!
  15. Mar 9, 2020 at 11:30 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    @TRDguyKC
    Thanks man!
    Not bad at all. I watched my buddy mainly do it but i could have easily done it. Bolt that holds the mounts on slides right out and you just need to jack up the body so you can fit the new mounts in. The driver side is a good bit harder for some reason than the passenger. Took us like 15 min for the driver and like 7 for the passenger side. pretty simple.
  16. Mar 9, 2020 at 11:40 AM
    TRDguyKC
    Kris
    Sierra Vista, AZ
    Well that sounds do-able..... did you do just the front or did you do all of them?
  17. Mar 9, 2020 at 11:42 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Yea just the fronts for now, but i will do all of them eventually lol.
  18. Mar 9, 2020 at 11:47 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Oh hell. Whenever I cant get something right or something doesnt work my girl never understands.... usually just adds to my stress.
  19. Mar 9, 2020 at 11:50 AM
    TRDguyKC
    Kris
    Sierra Vista, AZ
    I like it. Ill likely buy all of them and only install the fronts for the time since I can see that they're bad. I cant see the other ones, so they MUST be in perfect shape.... That's logical.
  20. Mar 9, 2020 at 11:56 AM
    Xx Ares xX
    Xx Ares xX Well-Known Member
    South Carolina
    2009 Silver Tacoma TRD SPORT, PRERUNNER, SR5, DC
    That sucks man. I'd recommend running a bead of this stuff around the seam. I had a similar issue with my tail lights this stuff worked like a charm.
    Good Luck
    https://www.amazon.com/gp/product/B000BKEBO0/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
    jgwilson88[QUOTED] likes this.
