  1. Apr 20, 2020 at 6:12 AM
    wmg
    wmg Well-Known Member
    bill
    2009 FJ
    BP-51 OEM LIFT..33;s...full skids....dual Batteries
    I have used that cap for a couple of years with no issue's..it also is drilled and tapped for the by pass filter return...the cap turns like normal with the fitting installed..
  2. Apr 20, 2020 at 6:22 AM
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    Thanks man I got the idea from another member on here so I can’t take all the credit.
  3. Apr 20, 2020 at 6:24 AM
    wmg
    bill
    2009 FJ
    on my 2015 it was attached thru the wheel covering with little plastic (soft) arms I just sniped em off..but I wasnt gonna reuse the emblem...
    irayfz6 likes this.
  4. Apr 20, 2020 at 6:25 AM
    TheBlueBeast15
    Kevin
    H-Town
    I used black rtv to fill the gap.
    yeah iv seen members do that one before. It’s another great option. I just wanted to use Meso’s turn signal and puddle pods.
  5. Apr 20, 2020 at 6:27 AM
    wmg
    bill
    2009 FJ
    if you have the oil cooler I believe its the same temp as ur coolant
  6. Apr 20, 2020 at 7:22 AM
    61FunGun
    61FunGun Member
    Sean
    2013 TRD off road
    Attempting to fix my seat heater cable harness (ECU in picture). Looked to buy a new one but way too expensive for my taste, would rather try and replace the pins and see what happens. My shop has the tools for the job, I'm just lacking the experience.
    Anybody able to point me in the right direction here?
    20200419_134520.jpg 20200419_134520.jpg 20200420_081451.jpg 20200420_081525.jpg
    tacomakid96 and irayfz6 like this.
  7. Apr 20, 2020 at 7:36 AM
    DG92071
    DG92071 Well-Known Member
    The right direction is to replace it all.
    You could cut the pin at the board, desolder it, solder in a wire into the board, drill a hole in the housing for the wire to come out, and hardwire the new wire into the harness with a butt connector or more solder.
  8. Apr 20, 2020 at 8:07 AM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    The silver ones?
    I got them from Davez Offroad.
    Then I ground the logos off, chamfered the tops, and gave them this textured effect.
    They look rough but they're smooth to the touch.
    Dex__43, la0d0g[QUOTED] and Rick_Taco like this.
  9. Apr 20, 2020 at 8:27 AM
    wmg
    bill
    2009 FJ
    check ur in box
  10. Apr 20, 2020 at 8:44 AM
    DG92071
    "Inquiring minds want to know..." lol.
    wmg[QUOTED] likes this.
  11. Apr 20, 2020 at 8:56 AM
    Toytoa4life
    Toytoa4life Well-Known Member
    Koro
    New Brunswick, Canada
    2012 Tacoma SR5
    Thanks, I like your emblem and all, but I’m going to go a different route, haha. Just want to paint mine and put it back on. Thanks
  12. Apr 20, 2020 at 9:00 AM
    wmg
    bill
    2009 FJ
    yupper just wanted to let ya know on mine there didnt seem to be a way to remove it and re install
    Toytoa4life[QUOTED] likes this.
  13. Apr 20, 2020 at 9:27 AM
    NavyDiver72
    NavyDiver72 I DO ALL MY OWN STUNTS
    Rick
    Millington, TN
    2006 DCLB TRD Sport PreRunner
    Any Mods? One. Maybe two, tops...
    Nothing special, did what so many members have done. Upgraded from OEM horns to 2 Hella Supertones and 2 Hella Sharptones.
    Pretty happy wit the results.
    Label maker is R.I.P. dog ate it. Need to get a new one to properly label the fuse slot and the relay with the proper ID.
    Cheers!
    Rick.
  14. Apr 20, 2020 at 9:28 AM
    blitzkrieg69
    blitzkrieg69 Well-Known Member
    Bryan
    Maricopa, AZ
    07 DCLB
    Been a while since I updated, but got a couple things done...
    https://i.imgur.com/W4pUf4k.jpg
    Toytec coilovers to replace the 3” spacers I had up front. Got a good deal on them used.
    https://i.imgur.com/XYHLLOt.jpg
    https://i.imgur.com/bqLkPYa.jpg
    Shortened the shifter shaft and added 8-ball shift knob. Don’t know how much I like it, but keeping for now. The factory shift knob also looks pretty sweet with the shaft shortened.
    https://i.imgur.com/WoyKzYO.jpg
    Added a USB port connected to the back of the new head unit. Now I can easily swap between my phone being connected for the benefits of CarPlay, or my 1tb portable hard drive full of music, mounted in the center console with cable run to just below this receptacle.
    https://i.imgur.com/akcJvhb.jpg
    New head unit. The first Kenwood I tried wouldn’t work with a storage device of more than 64gb. This one will handle my 1tb drive, and also has the benefit of CarPlay. I wish it had wireless CarPlay, but to me it wasn’t worth a few hundred extra dollars to get.
    Xx Ares xX and lynyrd3 like this.
  15. Apr 20, 2020 at 9:45 AM
    blitzkrieg69
    Bryan
    Maricopa, AZ
    07 DCLB
    Update: It arrived, I installed it, and couldn’t be happier. Took about 40 min for me and got a super clean install.
    The only “quirk” I’ve discovered has to do with my habits more than the product. I used to leave my parking lights on and use them as DRLs (I already wired the second element of the turn signal bulb to come on with parking lights) and rely on the feature of the truck that shuts them off when you open the door after switching off ignition. I’ve noticed that if you remote start the truck, the parking lights turn on, however if you then turn the truck off, those parking lights stay on until you open a door. Once this covid lockdown is gone, I will contact 12v Solutions tech support and see if they have a fix. Until then, I’ll just ditch my bad habits, or maybe wire up DRLs as they are supposed to work lol.
    Graphixman likes this.
  16. Apr 20, 2020 at 10:02 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Looks awesome! My electrical game is getting better and better, but this is next-level. Where did you source the relay box? Thanks!
  17. Apr 20, 2020 at 10:10 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Thanks for the info!
    hoverlover[QUOTED] likes this.
  18. Apr 20, 2020 at 10:12 AM
    FishTacoJon
    FishTacoJon Well-Known Member
    Jon
    AZ
    2012 Tacoma TRD Sport DCSB
    Put on some 285/75/17s :muscleflexing:
    trdtacojef, Fixxxer, 96couv and 29 others like this.
  19. Apr 20, 2020 at 10:12 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    New to witness protection and dont want to forget your new name? :rofl:
    EricOutside, wmg[QUOTED] and stbear like this.
  20. Apr 20, 2020 at 10:18 AM
    freddy2923
    freddy2923 Well-Known Member
    Freddy
    Phoenix, Arizona
    2015 Barcelona red Tacoma trd or
    Pretty much stock, just a light bar and a avid off road bumper guard
    Doing this once my methods arrive:headbang:
    FishTacoJon[QUOTED] likes this.
