  1. Feb 22, 2021 at 8:03 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    Yes, they were headstrong provided bolts. I think it may have to do with your aftermarket bumps.
  2. Feb 22, 2021 at 8:05 PM
    18Tacos
    18Tacos Well-Known Member
    New Port Richey, Florida
    18’ Tacoma SR5 DCSB Silver Sky
    3” lift, 265/70/16 Wildpeak ATs on stock dipped SR5 wheels (for now). Meso stuff (puddle pods, Gasshole, stage 1 taillights) Pro grille, 5% tint, some other stuff
    Put on some new UCAs today, hopefully an alignment tomorrow. Would’ve been under an hour but Toyota obviously never intended for the control arms to come out. The bolt comes out right where the body is so you have to take vice grips and bend it out of the way. Added about 45 minutes and one beer to each side. All and all it was a four beer job.
  3. Feb 22, 2021 at 8:06 PM
    18Tacos
    Oh man. Have fun with the top UCA bolt.
    gabbo2112 and rgljr831 like this.
  4. Feb 22, 2021 at 8:08 PM
    Gtboosted
    Gtboosted Well-Known Member
    Beto
    2019 DCSB SR5
    What adapter?
    BlackRig likes this.
  5. Feb 22, 2021 at 8:08 PM
    not_tacomike
    not_tacomike Well-Known Member
    CA
    2020 Tacoma
    Have the caps from Amazon. Turned color after about a month. They are bronze now. Still like them but don't bother with the amazon ones if you want them to stay black.
  6. Feb 22, 2021 at 8:08 PM
    DAVO0621
    DAVO0621 Well-Known Member
    Davis
    Oregon
    2021 Cement TRD Off Road DCLB
    What camera and what adapter?
  7. Feb 22, 2021 at 8:17 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Shayne and Gtboosted[QUOTED] like this.
  8. Feb 22, 2021 at 8:22 PM
    Gtboosted
    Beto
    2019 DCSB SR5
  9. Feb 22, 2021 at 8:24 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
  10. Feb 22, 2021 at 8:27 PM
    Goatfrog
    Goatfrog Well-Known Member
    Bill
    Pittsburgh, PA
    2020 Red DCLB TRD Off Road
  11. Feb 22, 2021 at 8:31 PM
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
    Paint your Stock Ones. They are aluminum. Save 56 Bucks
    honey and boston23 like this.
  12. Feb 22, 2021 at 8:35 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    well yes the sumo bumps had a gap with the ome53a bolts (3/8”-1/2”) and the stock bolts (1/8”-1/4”)
    the ome53a had gaps (1/8”-1/4”) on Stock bumps which obviously were flat with stock bolts so that takes the sumos out of the equation (in this instance) and leads to ome bolts as an issue straight out the gate.
    Sumos are its own issue I haven’t addressed yet. In fact if you look at any sumos for sale and the pictures provided by seller you’ll notice paint flaked on the edges of the brackets (where the bolts rest) because that’s where the bolts rest/make contact and they don’t actually sit completely flat (my strong hypothesis). I’d image the bracket is the same as 2nd gen (if not universal) which would have the same issue. Now if it’s a big deal, I don’t know- the only info I could find was specifically stating bolts need to be flat on leafs or completely wrap the axle. Then sumos “engineer” gives ok to notch the brackets. Well, question, why wouldn’t you engineer the bracket a factory fit. Despite, I still plan on installing the sumos but 1st need to find bolts (which I do have on the way but the storm changed delivery from fri. To maybe tomorrow). I’d had hoped to install prior to a 6 hr dr to Orlando Thursday
    rgljr831[QUOTED] likes this.
  13. Feb 22, 2021 at 8:46 PM
    cyked
    cyked Well-Known Member
    I did mine at 30k. I wouldn't say the front diff fluid was black, but it was def dark. Rear was very clear.
    JDPNW and rgljr831 like this.
  14. Feb 22, 2021 at 8:47 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Not looking forward to it. Coworker cut his and put them in reversed when he did his. Sounds like we have a tech off on Friday so I may go in early and use his lift to do the arms and play around with preload on the 5100’s and get rid of the big spacers up top.
    Rottencotton, honey, JDPNW and 2 others like this.
  15. Feb 22, 2021 at 8:50 PM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Following Nitori's OEM SR Foglight Mod (pre-wired) to get the truck ready for a shop to install/aim SS3 Sport fogs and Morimoto XB Gen2 later this week. No shop was willing to take out the airbag and remove the wheel to swap the switch, so I took care of that tonight. Made a short post to add some more info to Nitori's instructions if anyone is interested or thinking of doing it themselves. The install was actually really simple, the "hardest" part for me was being sure the airbag was safely removed/handled since it's my first time doing that.
    Comparison of factory switch from the SX trim vs. the part specified in the instructions:
    Pic of the installed switch:
    Snaeper, Shayne, TnTHicks and 10 others like this.
  16. Feb 22, 2021 at 8:51 PM
    playdixie
    playdixie Miss'ippi fella
    Mississippi
    2019 Cavalry Blue TRD Sport 4WD
    :rofl::rofl::rofl:
    rgljr831 likes this.
  17. Feb 22, 2021 at 9:01 PM
    playdixie
    Mississippi
    Is it a bigger or smaller one?
  18. Feb 22, 2021 at 9:21 PM
    18Tacos
    It will be a little easier with a lift for sure. I did mine in my garage with the truck on Jack stands. I ended up putting a long punch through the other side of the control arm and forced the bolt past the body. It was tight even though I had manipulated the sheet metal. I thought about reversing it but I muscled through putting it back the hard way.
    rgljr831 and boston23 like this.
  19. Feb 22, 2021 at 9:49 PM
    rgljr831
    Ron
    Yes, you would think if it were an application specific part it would work with the factory u-bolts or even the Headstrong u-bolts which pair perfect with the factory bumps. Hope your order arrives in time for your trip. Let me know how it works out. Wish you the best! :cheers:
  20. Feb 22, 2021 at 9:54 PM
    Onetime27
    Onetime27 Well-Known Member
    Joe
    Columbia Gorge, OR
    ‘20 OR DC
    275/70/16 AT3Ws
    I also have this setup. Literally set (10 min?) and forget. The great thing about the Garmin Mini is it’ll recognize when you change your speed abruptly and save those files. The rest auto-write over each other. Downloading video through the app takes a bit however hopefully you don’t have to use that feature much.
