  1. Jul 3, 2021 at 6:19 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Freshened up the rear :pumpkin: tonight.
    Took about a half an hour ......
    Put some new Toyota crush washers in......part number 12157-10010. This number is for first and second GENS both drain and fill plugs....3rd gen probably the same. The same part number is also used on the front differential fill plug. Torque for both plugs in the rear is 36 foot lbs.
    Only a tiny little bit of metallic dust on the magnet which was a good sign.
    I learned how to do all the gearboxes in this thread… It’s a good one…
    https://www.tacomaworld.com/threads/front-diff-and-transfer-case-oil-change-howto.147631/
  2. Jul 3, 2021 at 6:23 PM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    That looks really good and will give you some protection. I’ve had mine on since 2017 after I sucked a deer through my radiator. I just put some deer/ditch lights on last weekend.I bet you’re happy to have it out of storage and mounted.
    ARB has done a wonderful job with the powder coat on the bumper mine has held up fantastic
    SwampYota and 01x4[QUOTED] like this.
  3. Jul 3, 2021 at 6:27 PM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Thanks. I'm pumped to get it on. Fox is the worst I've hit here, fingers crossed, but I'm happy to have it on now, just need to choose a winch. The weather was good and I wasn't going anywhere since there are so many tourists in town, so it was a nice wrenching day. Now I need some lights for it. Ditch lights are a good call too.
  4. Jul 3, 2021 at 8:21 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Spindles soaked in rust remover most of the day. We wire brushed them to remove everything loose. We brought the mating surfaces back to bare metal. They are all prepped and ready to weld gussets tomorrow.
    Then we'll tape em up and paint em.
    Hubs soaked all day too. I'd say they came out nicely.
    And then we have the pile of parts:
    Bearings
    Retainer clips
    Inner dust seals
    Outer dust seals
    01x4, unstpible, Winkle99 and 2 others like this.
  5. Jul 3, 2021 at 8:58 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    more progress pics please!!
    unstpible likes this.
  6. Jul 3, 2021 at 9:08 PM
    eon_blue
    Azusa, CA
    Picked up a bin of spare parts that came off a 3rd gen T4R today, one axle needs a reboot but otherwise it'll all shine up nicely and go to good use.
    Need to replace my driver's side LCA, swap out a cheap parts store axle on the driver's side and keep the intake manifold on hand for when I send the supercharger out for rebuild.
    01x4, unstpible, jubei and 1 other person like this.
  7. Jul 3, 2021 at 9:40 PM
    SiberianTacos
    SiberianTacos Well-Known Member
    02 Tacoma Dbl Auto 4wd
    What do you do when you get racing seats for your tacoma? Well you cover them with sheep fur ofcause
  8. Jul 3, 2021 at 9:45 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    I’ve got a bumper in the storage unit myself, hoping to have a similar post at some point soon. Looks great.
    Rust in California? I thought you guys didn’t have to deal with that BS.
    unstpible and 01x4[QUOTED] like this.
  9. Jul 3, 2021 at 10:18 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    I did my T-stat today and changed the small hoses under the throttle body while I was at it. I meant to replace the thermostat today but ended up putting the old one back in, it didn't look bad and wasn't stuck open or closed and was working fine before I changed the coolant.
    I was going to change it out because my truck was running around 200 degrees on the highway but would run cooler around town. Sure enough the jiggle valve was in the wrong position. When I put in the new t-stat and was tightening the housing the t-stat moved and I crushed the jiggle valve and ruined the rubber gasket. Put the old one back in and fixed the position of the jiggle valve and the truck hasn't gone above 188 yet, waiting for a hot day to really test it out and keeping an eye on the old t-stat. So far so good.
    unstpible and nagorb like this.
  10. Jul 4, 2021 at 4:21 AM
    01x4
    Yeah it feels good finally getting the parts pile down and checking some stuff off the list.
    unstpible and Rhodes like this.
  11. Jul 4, 2021 at 7:45 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    did you notice a difference on how the new thermostat didn't fit tight while the old one did. I did the same thing, crushed the rubber gasket because it slipped out of place. I also reused my old thermostat and it "snapped" into the hole and fit tight with no movement.
  12. Jul 4, 2021 at 9:11 AM
    eon_blue
    Azusa, CA
    Until you pick up a literal used parts pile and the list grows exponentially
    unstpible, 01x4[QUOTED] and Tour991 like this.
  13. Jul 4, 2021 at 9:41 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    I’ve done it, and it’s even easier than the 2.7 because it doesn’t have a bearing.
    6 Cyl 3.4 5VZ rebuild kit:https://www.toyotapartsdeal.com/oem/toyota~gasket~kit~power~steering~pump~04446-04010.html
    Burro[QUOTED] likes this.
  14. Jul 4, 2021 at 10:34 AM
    01x4
    Yeah but for $100 how could you not?
    eon_blue[QUOTED] likes this.
  15. Jul 4, 2021 at 10:39 AM
    homegrown_xt
    Sonoma County
    That is exactly what happened to me!
    I put the new t-stat in and the little bracket that holds the sensor wire kept getting in the way, so when I got it out the way, the housing shifted and the t-stat moved. I started d to tighten it down and it didn't feel right and then I looked at the housing and saw that the gasket was pinched. It was so frustrating, I put new studs and nuts in but had to reuse the old
    t-stat and gasket. I had no choice, the dealer is closed this weekend for the 4th. It isn't leaking and the temperature is lower, I will keep an eye on it.
  16. Jul 4, 2021 at 11:26 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  17. Jul 4, 2021 at 12:03 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    That’s essentially all plastics except for the door handles, Raptor Lined.
  18. Jul 4, 2021 at 12:51 PM
    dc welding
    dc welding Well-Known Member
    Dan
    Swansea Mass
    15 DCSB TRD Sport BRM / 2002 AC SR5
    ARB bumper looks awesome on a first Gen IMO. I’ve been on the fence about getting one for mine. I think it’s time……. Where did you guys order yours from?
  19. Jul 4, 2021 at 12:57 PM
    01x4
    Got mine from OK4WD. ARB part #3423020 (The #3423040 is another option some carry, it has an "integrit" finish, basically like a matte textured powdercoat versus the plain, glossier powder mine has)
    https://ok4wd.com/arb-front-winch-bar-for-1995-2004-toyota-tacoma
    OK4WD is great to work with, but I'd call to check stock, most dealers are backordered right now waiting on boats.
  20. Jul 4, 2021 at 1:10 PM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    unstpible and dc welding[QUOTED] like this.
