  1. Aug 29, 2013 at 7:30 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    Anyone make a bolt on hydro kit? Have some mixed feelings on the IFS box...?
  2. Aug 29, 2013 at 7:44 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hydro Kit? Like hydro bumps??
  3. Aug 29, 2013 at 7:47 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    He just bought tons. He's talking about steering
  4. Aug 29, 2013 at 7:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ah. Never mind then.
  5. Aug 29, 2013 at 8:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  6. Aug 29, 2013 at 8:52 PM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
  7. Aug 29, 2013 at 8:56 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    trying to track down a wobble at ~45-48mph and 59~mph.
    carrier barring possibly? [​IMG]
    grease is all over down there, i think i overloaded it and its coming out. could I be short on the drive line I wonder or too much in there still? wobble came aparent after installnig spacers, most previous mods before that are BPV relocate and just a rotate of tires. removed spacers and still wobblee
  8. Aug 29, 2013 at 9:12 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I'm thinking about re gearing, i had been figuring 4.88s but when i was researching i cab across a few people saying with an e locker they are weak, anyone have any opinions?
    i planon eventually going to 35s or 33s.
  9. Aug 29, 2013 at 9:19 PM
    yote
    Mark
    Tacoma, WA
    Thank you good sir! :thumbsup:
  10. Aug 29, 2013 at 9:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Usually 45ish is front..do you have a diff drop?
    Check the play of the bearing too. Should be a little..but not a ton. Also check the U joint at the rear diff. Thats what mine was. ended up with a 1.5'' BEEFED drop bracket for the CB and axle shims. Have a straight drive shaft all the way now.
    the lower the gear ratio you go(higher number) the weaker the rig gets as the there are more teeth thus smaller space for them and blah blah blah.
    Really though..4.88s aren't considered that weak. The 8'' ring in the Elocker is considered slightly more weak then the 8.4 diffs 8'' ring but thats due to other reasons.
    All in all..4.88s aren't that weak. They work great for 33s and and auto tranny and with 35s and a manual its suppose to be just like stock and 31s.
    If your and auto and want 35s i strongly suggest the 5.29 gears which are considered weaker..but the way i see it..if Silas hasn't busted his with 37s..you'll be fine. Most diff injuries are due to incorrect back lash setup.
  11. Aug 29, 2013 at 9:32 PM
    Bennett707
    Oregon
    No diff drop is installed. I didnt' think it would be anything to do with my angles etc considering ive been running the lift etc for 1yo+ now without issue. I really am not looking forward to my camping trip with these vibes...
  12. Aug 29, 2013 at 9:32 PM
    Jr Stuart33
    Jr Stuart33 Member
    Jr
    Virginia
    98 Tacoma TRD Limited 3.4
    ARB front.rock bars.Yaesu 2900r. Uniden 510 peaked-Wilson 1000
    left rear seal, carrier barring, universal join , oil change, tires ... Yeah im broke!
  13. Aug 29, 2013 at 9:33 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    awesome, thanks.
  14. Aug 29, 2013 at 9:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Diff drops lower the front two mounts of the diff. While a small by prodoct is the cvs get lowered a bit..what really happens is it tips the diff forward. This helps straighten out the front drive shaft a bit from what i understand and helps the vibes from the CVs to the drive shaft.
    But for now, id check your CB play and the U joint play.
  15. Aug 29, 2013 at 9:37 PM
    MRBOND101
    MRBOND101 TTE
    Dylan
    Frisco, Texas
    16 TRD-OR AC
    Late post but got new tires last weekend. Went cruising.
  16. Aug 29, 2013 at 9:44 PM
    aldoraine
    aldoraine Well-Known Member
    evan
    vallecito ca
    99 Tacoma 4WD TRD
    Put my Bilstein 5100's on today, installed a Koyo 2-core radiator, and received / painted my chilkat e-racer kit. E-racer kit going in tomorrow!
  17. Aug 29, 2013 at 9:51 PM
    MRBOND101
    MRBOND101 TTE
    Dylan
    Frisco, Texas
    16 TRD-OR AC
    Lookin good man! :cheers:
  18. Aug 29, 2013 at 11:07 PM
    aldoraine
    evan
    vallecito ca
    99 Tacoma 4WD TRD
    Thanks! I have to give some props to Alex at Chilkat, his craftsman ship is next to none on this stuff! It's expensive, but I can totally see why once I got the kit in person. Top notch materials and fabrication. All hand made.
  19. Aug 30, 2013 at 1:58 AM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Forgive me if I sound dumb, but what the hell is an e-racer kit?
  20. Aug 30, 2013 at 6:03 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Got my Magnaflow in the mail, chopped the old exhaust and tried to clamp the new one one in. I kinda dropped the ball on ID vs OD when ordering, long story short a clamp isn't gonna work. So now I drive 4 hours home this evening with open cats.
    I drove it down the highway a little ways last night just to test the drone. This will not be an enjoyable trip haha
