What Locking Tailgate Solution?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WalkeJ, May 22, 2015.
Which Locking Tailgate?
  1. Pop-&-Lock 54XX (Manual, Bolt Codeable)
    31.3%
  2. Pop-&-Lock 55XX (Manual, Non Bolt Codeable)
    18.8%
  3. Pop-&-Lock 854X (Power-Manual, Bolt Codeable)
    25.0%
  4. Pop-&-Lock 855X (Power-Manual, Non Bolt Codeable)
    0 vote(s)
    0.0%
  5. Other Pop-&-Lock
    0 vote(s)
    0.0%
  6. Other
    6.3%
  7. Pop-&-Lock 8521 (Power to OEM, NA Bolt Codeable)
    18.8%
  1. May 22, 2015 at 4:16 AM
    WalkeJ
    WalkeJ [OP] Well-Known Member
    Central California
    2015 DCSB TRD Off Road Tacoma
    I know that there is a lot of info and discussions about various tailgate locking solutions here on TW, but I am trying to get some of this info all in one thread. Pro's, Con's, failures, works well with or without camera, installs easy, etc.
    Please vote on which tailgate locking solution you think is best and then post why.
    If I get a lot of responses for a particular "Other" solution, I will try and update the poll choices.
  2. May 22, 2015 at 4:28 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    PL 8540
    Pros
    - wired to passenger door harness
    - easy install
    - camera lines up with grid lines
    - a noticeable solenoid clunk to let you know it's working
    - works with ignition key
    - and locks your tailgate! Are you listening, Toyota?
    Cons
    - handle is a little small
    - handle feels flimsy
    I haven't used it in freezing temps yet.
  3. May 22, 2015 at 4:59 AM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    PL5400 for me.
    Pros
    - Uses your ignition key.
    - Easy install(you don't need to deal with running wires).
    - Looks like stock.
    - Doesn't change the location of the camera.
    - No loud clunk every time you lock your truck.
    Cons
    - You need to flip one of the latch rods(maybe the same for the other series. Not sure).
    - Feels like you need to pull up harder on the handle to open the tailgate.
    - Others have said it looks flimsy.
    Other then that, I haven't encountered any problems with mine since I installed it. Advice that I recommend is applying powdered graphite lubricant inside the bolt, and white lithium grease on the moving parts of the handle.
  4. May 22, 2015 at 5:09 AM
    andyzx6r
    andyzx6r Well-Known Member
    Atlanta
    Super White TRD Sport
    PL 8521 FTW! Keeps your stock handle and backup camera. Just adds a power locking solenoid to your handle.
  5. May 22, 2015 at 5:13 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    Sub'd! I still need to do this.
  6. May 22, 2015 at 5:18 AM
    WalkeJ
    Central California
    Thanks for your inputs so far... Keep them coming.
    I added the PL 8521 to the poll (andyzx6r, you may want to change your vote).
    Seems like there could be an issue with having the 8521 and your FOB dies. No key entry as backup.
  7. May 22, 2015 at 5:47 AM
    andyzx6r
    Atlanta
    This could be true. I talked to POP&LOCK on this and they told me that they have a way of getting you in if your fob is lost or the solenoid dies. Not sure how they do this but it still is the best choice for me.
  8. May 22, 2015 at 5:48 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    This. :thumbsup:
  9. May 22, 2015 at 6:15 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    More PL5400 cons:
    https://www.tacomaworld.com/threads/pl5400-problem-already.311031
    https://www.tacomaworld.com/threads/pop-and-lock-pl5400-problem.336397
    https://www.tacomaworld.com/threads/pop-and-lock-pl5400-question-for-owners.366276/#post-9980417
    https://www.tacomaworld.com/threads/pop-lock-pl5400.307480/#post-8680770
    https://www.tacomaworld.com/threads...s-pl5400-opinions-please.323556/#post-8473000
  10. May 22, 2015 at 6:28 AM
    adio
    HI
  11. May 22, 2015 at 6:31 AM
    WalkeJ
    Central California
  12. May 22, 2015 at 7:12 AM
    Frobozz
    Frobozz Well-Known Member
    North of Ordinary
    15 TRD/OR Access Blue Ribbon Metallic
    Tonneau, Canoe Rack
    I have installed P&Ls on several vehicles. Most recently on my last Taco. I have heard of too many times that the bolt codeable model has stopped working, so I voted for the non codeable manual option. I view it as pretty simple to attach a separate key to my loop, and I can keep one in the glove compartment for emergency use.
    The last one I installed did feel a bit flimsy, and I have not yet installed one on my newest Taco, but I may yet. I am sort of hoping P&L will market a stronger version. I'd be willing to pay a bit extra for a tougher lock. On my last truck I felt like I needed to apply some forward (closing) pressure on the top of the tail gate when opening it.
  13. May 22, 2015 at 7:23 AM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Yes, although the PL5500 shares a similar problem with the PL5400, in that it may not stay locked.
    The problem is a little plastic tab that gets weak and breaks, which prevents the P&L to stay locked:
    The solution was to add a helper spring, so that the mechanism stays locked:
  14. May 22, 2015 at 7:34 AM
    alvinfromhawaii
    alvinfromhawaii Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    I have the 8521. Keeps everything stock. All you are doing is adding a power lock feature to your existing handle. Easy to install as well. Hardest thing is running the wire to the cab. There is also a video online showing this specific install on a Tacoma. Even shows where to wire it up to. I'll try to find the video and post it to this thread.
  15. May 22, 2015 at 7:48 AM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
  16. May 22, 2015 at 10:35 AM
    WalkeJ
    Central California
    Thanks for all the inputs... Keep' m coming.
