What octane should I use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aces2, Jun 18, 2008.
  1. Jun 18, 2008 at 9:42 AM
    aces2
    aces2 [OP] Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    I have a 4.0 v6, what octane should I be using? From what I'm seeing in the owner's manual it says any... correct or not?
  2. Jun 18, 2008 at 9:47 AM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    Correct.. use what works best for you not only the the wallet but for your driving needs.
    Regular for me proved to knock to much and I went with mid-grade for daily driving. Get the occassional knock on those really really hot days but it's rare.
    I put premium in when I'm pulling my travel trailer (5000#) to get the best performance possible from the engine and reduce the knock completely. Manual recomends premium for best performance as well. Numerous threads out here with explainations for everything.
  3. Jun 18, 2008 at 10:17 AM
    bounrith
    bounrith Well-Known Member
    Long Beach, CA
    07 PreRunner
    Snug Lid F2
    I got customer who works for ARCO and they would only put lowest grade for city street driving but will go mid grade or premium for a long trip.
    Tacos require only 89 octane.
  4. Jun 18, 2008 at 3:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have found that there is nothing wrong with 87, although i got a little spark knock with it, but mid-grade and premium yeild a little better performance, and i cant really tell the 2 apart, so i run mid grade all the time now. mileage is good with the mid or premium too.
  5. Jun 18, 2008 at 3:13 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    When I first bought my truck I used 87 octane, about a couple months ago my mechanic recommended 90 octane (only two available) so I switched. I notice the engine runs smoother and quieter, also you hardly hear that annoying ticking sound the engine makes. I'm sure I read somewhere Toyota recommended 91 octane for the Tacoma.
  6. Jun 18, 2008 at 3:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    gotta agree......they are alot smoother running with higher octane:)!
  7. Jun 18, 2008 at 6:58 PM
    aces2
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Awesome. Yeah, I hear that light knocking sound when I'm going about 20 mph and my passenger window is down. I hear it bouncing off random objects and projecting back into the cab.
    The whole reason for me to ask this question originally was that I'm only getting about 14 miles per gallon at the moment. I was at class this evening and was talking with one of my classmates. He had said that since I only have about 750 miles on my truck, the engine has alot of braking in to be done, but then after that, my gas mileage will go up 3-4 miles per gallon. This sounds legit, but is there any truth in it?
  8. Jun 18, 2008 at 7:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, definitely. as the engine breaks in......you mileage will increase, enough that you can see a good improvement.:)
  9. Jun 18, 2008 at 7:06 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I've run 87 since day 1 - never noticed any problems. If gas wasn't so damn expensive, I'd treat 'er to higher octane. But - I drive to/from work and around town mostly and that's it. Not worth spending $$ for the good stuff.
  10. Jul 10, 2009 at 4:18 AM
    coma09
    coma09 Senior Member. Hey, what's That supposed to mean?
    BC Canada
    2013 taco access cab 4x4
    Drove from Toronto to Ft Lauderdale & back.... Started with 87 for half the trip down. 2 adults, and enough load to make the springs sag 2".
    Truck ran great. Switched to mid-grade, and I thought I noticed a small difference in smoothness. Fuel economy about the same.
    Half-way back I switched to regular.
    Here I noticed the engine was noisier - and you had to really put your foot into it to downshift (auto). Didn't seem to have as much power on the hills. 5 hours of driving later I switched back to mid grade ... noticeable improvement in hills and more 'willing' to go.
    I know this is subjective. For daily driving I doubt I'd ever notice. There was definitely a difference for the positive, running 89 over 87 on highway use.
    The difference was quite noticeable when going from mid to regular. Once you've driven days on 89, then switch - it was very apparent.
    I'll stick to 87 I think (cheaper) for regular driving @ home
  11. Jul 10, 2009 at 4:25 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    i use 87 as 89 is 10 cents more a gallon, but if i see 1 mpg inc. then it would actually cost the exact same... hmmm, will try 89 at next fillup... and premium 93 is way to damn expensive to try
  12. Jul 10, 2009 at 7:32 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    89 here...............like others when you run 87 you get more engine noise and the engine seems to run a little rough.........w/89 I don't get the knocking and get the smoother ride. I don't think my truck has ever had 92 in it............It all boils down to driving conditions and your personal mindset...........:D
    Oh................and god forbid that any of you let your low fuel light pop on thinking its hard on the truck some how :frusty:.............. ...............:rofl::rofl::rofl:
  13. Jul 10, 2009 at 7:36 AM
    Janster
    Jandy
    Lancaster, PA
    Why would you doubt your owners manual?
  14. Aug 2, 2009 at 1:06 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    unless your engines poping, or premature detonation i wouldnt use a higher octaine
  15. Aug 2, 2009 at 3:37 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
  16. Aug 2, 2009 at 4:27 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
  17. Aug 2, 2009 at 5:32 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    I just realized this thread was a month old. Let's euthanize it.
  18. Aug 2, 2009 at 6:01 PM
    Incognito
    VA
