What's the best oil or oil additive?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tcBob, Jan 2, 2023.
  1. Jan 3, 2023 at 4:35 AM
    #41
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    Walmart Supertech every 5k.
    cammerv8, Gen2 Man and AM6217 like this.
  2. Jan 3, 2023 at 5:00 AM
    #42
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    I concur, Im doing 3750 on my taco.
  3. Jan 3, 2023 at 5:11 AM
    #43
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I started using mobil 1 synthetic about 25 years ago. Its the only i'll ever use in my newer tacoma truck...zero on additives, their not needed. Can't argue the success with this oil. My old tundra is still going strong with over 300k miles.
    davidstacoma and Gen2 Man like this.
  4. Jan 3, 2023 at 5:12 AM
    #44
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    rzathagza and Horseshoez like this.
  5. Jan 3, 2023 at 5:15 AM
    #45
    Gen2 Man
    Midwest
    07 Sport DCLB
    Lol
  6. Jan 3, 2023 at 5:44 AM
    #46
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    Toyota brand lubricants and filter, no additives needed. :mudding:
    kahanabob likes this.
  7. Jan 3, 2023 at 6:16 AM
    #47
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You can have whatever beer you want, as long as it's a Corona
  8. Jan 3, 2023 at 7:17 AM
    #48
    eurowner
    eurowner Duke Sky
    Scoty
    Mobil 1 and I have had great results with BG MOA for my 80s VW and Audi hydraulic cylinder heads.
    Big tall dave likes this.
  9. Jan 3, 2023 at 9:14 AM
    #49
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    The best oils according to Project Farm testing are Amsoil and Pennzoil Ultra Platinum. The data shows those are “best” and it’s not really up for debate imo. Best heat resistance, best wear protection, best cold flow - go with those if cost permits.
    That’s not to say that other synthetic oils are bad or even that far behind the “best.” Some engines might prefer one over others. There are many great oils. Supertech Advanced, Mobil 1 EP, Amazon Basics, LiquiMoly, etc. As long as you use a quality GF6 full synthetic, you’ll be fine.
    I personally try to use Pennzoil Ultra Platinum when I can, but also use Supertech Advanced, Rotella Gas Truck (sadly discontinued), and Mobil 1.
    OldSaltyDog likes this.
  10. Jan 3, 2023 at 9:17 AM
    #50
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    As Elon might say, "the best additive is no additive"
    zoo truck likes this.
  11. Jan 3, 2023 at 9:22 AM
    #51
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Instead of Castrol oil, try Castoreum oil. I heard it keeps tailgaters away.
    ancient11 likes this.
  12. Jan 3, 2023 at 11:04 AM
    #52
    xf800spro
    xf800spro Member
    Harrison,Me.
    2019 SR5
    Mobil 1 every 5k.
  13. Jan 3, 2023 at 11:16 AM
    #53
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Oil enthusiasts on Bob the Oil Guy pick the Project Farm guys testing apart, so it’s certainly up for debate there lol.
    If you’ve ever seen the extensive tests oils undergo for the certification testing you would understand why.
    I think his testing is “good enough” for me even though it doesn’t simulate actual engine temperature conditions and have the Pennzoil Ultra Platinum and OEM filter on hand for my next oil change. Recently had the dealer change mine and they use bulk Pennzoil synthetic and don’t even have Toyota oil on hand. They did have Mobile 1 by the quart which was overpriced.
  14. Jan 3, 2023 at 11:29 AM
    #54
    zoo truck
    None
    I noticed barrels of mobil1 at the toyota dealer here. Its funny cause they have one of those mobil 1 oil express dealers next door to. If you want valvoline, just go across the street.
  15. Jan 3, 2023 at 11:37 AM
    #55
    2019 TRD Off Road
    Yeah, true. There’s theory, which they tend to discuss a lot, and then there’s empirical data. I’m personally an empiricist. If there are empirical tests that show another oil outperforming PUP or Amsoil, I’d definitely pay attention.
    Like I said, though, at that level of quality I would bet a lot depends on the particular engine’s preference. Also beyond a certain point of increasing oil quality, there’s probably effectively little difference in many oil types.
  16. Jan 3, 2023 at 11:39 AM
    #56
    Sungod
    Sungod Well-Known Member
    St Augustine
    Is that Vegan oil?
  17. Jan 3, 2023 at 11:50 AM
    #57
    rzathagza
    rzathagza Active Member
    Simon
    2017 Tacoma TRD
    shiiittt
    cheapest oil, change every 5k, done.
  18. Jan 3, 2023 at 12:16 PM
    #58
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
  19. Jan 3, 2023 at 12:29 PM
    #59
    BillyE
    BillyE Well-Known Member
    I don’t want to spend a ton of money on boutique oils. I got Mobil 1 EP for ~$26/5qts on Amazon so I bought them out. That’s going to be my fill for the next few years.
    FishaRnekEd likes this.
  20. Jan 3, 2023 at 2:35 PM
    #60
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    This is $29 at Walmart, it’s a 6 quart box (no bottles, it’s bagged) and seems to have all the certifications all the other synthetics have. After one year and 6k, it still looks good.
    J0hnny, BillyE and Big tall dave like this.
