Wheel Bearings/Hubs 4x4 & 4x2 PreRunner for sale *complete* save $$ CUSTOM BUILT AVAILABLE
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by nj636, Jul 25, 2013.
Thread Status:
Not open for further replies.
  1. Apr 21, 2014 at 5:29 AM
    #761
    EDoubleu20
    EDoubleu20 New Member
    I was away on vacation most of last week. Tonight I will be able work on the truck and I'll let you know how goes after.
  2. Apr 21, 2014 at 5:32 AM
    #762
    nj636
    nj636 [OP] Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    You have to loosen the 4 hub bolts and then work the assembly off of the spindle until you can back the 4 bolts completely out of the spindle and remove the assembly. It's not as difficult as it seems.
  3. Apr 21, 2014 at 6:17 AM
    #763
    Mccabedoug
    Mccabedoug Member
    Central Mass
    2017 Quicksand Tacoma Limited
    I backed out all four hub bolts all the way and then went around the outside of the hub and tapped on it from the back with a hammer. Then you back out the bolts a little more, rap on it all the way around trying to get it to move out, and repeat. Not hard.
    Torch wise I just used my propane torch. It was enough heat (just took a couple minutes). Heat and PB Blaster were imperative to get the caliper bolts off. Other bolts were easy.
  4. Apr 21, 2014 at 1:19 PM
    #764
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    This all good info. I'm sure many will benefit beside me. Thanks.
  5. Apr 21, 2014 at 6:54 PM
    #765
    nj636
    Kev
    Jersey
    Definitely great info, thank you guys.
    Following the write up below along with everyone's suggestions will get the job done.
    DIY Hub & CV axle replacement
  6. Apr 21, 2014 at 7:03 PM
    #766
    nj636
    Kev
    Jersey
    Here are a pair of hubs I built for a customer that wanted more thread engagement using acorn style lugs. I installed 1/4" longer studs which worked out great for their requirement :cool:
  7. Apr 21, 2014 at 7:24 PM
    #767
    Bonomonster
    Bonomonster Well-Known Member
    Albany NY
    2007 FJ Cruiser
    3" lift, Skids, Sliders, 33" tires
    So does that change the hub from being hub-centric to lug-centric?
  8. Apr 21, 2014 at 7:48 PM
    #768
    nj636
    Kev
    Jersey
    it is still hub centric. the wheel sits the same on the hub it just allows for more thread engagement. people with wheel spacers opt for the longer studs for the same reason.
  9. Apr 22, 2014 at 5:38 AM
    #769
    EDoubleu20
    Kevin,
    I swapped out my front driver side hub assembly (189k) last night and everything went perfect. Your assembly arrived on time last week and it took me less than an hour to swap, and that was taking my time. Put my first 50 miles on it this morning going to work. It's nice not hearing that bearing any more! I'll be back again if I need another and will definitely recommend you.
    Communication and payment transaction with Kevin was exactly what you would want...easy!
  10. Apr 22, 2014 at 6:53 AM
    #770
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    :gossip: he just called you easy! :eek:
  11. Apr 22, 2014 at 12:39 PM
    #771
    EDoubleu20
    AND highly recommendable! :thumbsup:
  12. Apr 22, 2014 at 2:50 PM
    #772
    nj636
    Kev
    Jersey
    Thank you for the feedback :thumbsup: glad it went smooth. Even with 189k on that assembly it took you less than an hour! Good to hear.
    I'll be here when your ready to do the other side.
  13. Apr 22, 2014 at 2:50 PM
    #773
    nj636
    Kev
    Jersey
    who doesn't like easy :D
  14. Apr 22, 2014 at 2:58 PM
    #774
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    NJ636, did you get my arp studs to build my hubs with? I sent everything out a week ago or so.
  15. Apr 22, 2014 at 5:16 PM
    #775
    nj636
    Kev
    Jersey
    Just showed up today in the snail mail and I'll just leave this here :D
  16. Apr 22, 2014 at 5:59 PM
    #776
    nj636
    Kev
    Jersey
    ARP stud compared to a stock one, it is 1" longer :eek:
    compared to stock
  17. Apr 22, 2014 at 6:35 PM
    #777
    blackyota
    blackyota Member
    Corey
    Lugoff, South Carolina
    05 tacoma, ext cab
    brush guard, billiet grill, 33s nitto trail mudders, leveling kit, 3in body lift
    Replaced my assembly yesterday afternoon... Everything went great! NJ636 got the parts to me fast,!! Thanks again ill get another one when the passenger side gives out.
  18. Apr 22, 2014 at 7:18 PM
    #778
    Bonomonster
    Albany NY
    2007 FJ Cruiser
    What type of spacer would you use with those long studs?.... I thought companies like Spidertrax and such only made spacers that were offset for use with factory studs.
  19. Apr 23, 2014 at 4:38 AM
    #779
    nj636
    Kev
    Jersey
    Thank you for the feedback, I'll have one ready for you :thumbsup:
  20. Apr 23, 2014 at 4:41 AM
    #780
    nj636
    Kev
    Jersey
    I was asked to install the supplied studs, I'm not sure what the plan is with them. He said he wanted to use the ARP's for their strength & durability. They could always be cut to the proper length if they are too long.
Thread Status:
