Wheel & Tire Combo?
Discussion in 'Wheels & Tires' started by Hdeuce22, Jun 15, 2012.
  1. Jun 15, 2012 at 5:36 AM
    Hdeuce22
    Hdeuce22 [OP] Well-Known Member
    Alabama
    2013 4x4 DC Sport TRD
    Hi everyone! I'm new here and this is my first post. Forgive me if this isn't the correct place to pose my question. I have an 07 Prerunner DC TRD and I'm wanting to go with a new set of tires and wheels without a lift or mods. Would I be able to go with a 285/60/18 and a 18x9 wheel without any rub? Thanks in advance!
  2. Jun 15, 2012 at 6:23 AM
    Large
    Large Red
    31.5" x 11.25" .. I think I see some rubbage in your future.
  3. Jun 15, 2012 at 6:33 AM
    Hdeuce22
    Alabama
    I thought I remembered seeing a mod say something about this setup being ok since this tire was under the 32" mark but I could be imagining things too. :)
  4. Jun 15, 2012 at 6:48 AM
    Large
    Large Red
    I ran 32x12 for a whole and it rubbed pretty good, if you have around 4.5" bs it won't rub too much though.
  5. Jun 15, 2012 at 7:48 AM
    Yeti75
    Yeti75 Well-Known Member
    NE TX
    09 PreRunner DC SB
    There have been several threads on this topic. Some people have run this combo with absolutely no rub on a stock setup, and others have rubbed like crazy. Do a search on the tire size and you should get quite a few threads to run through. This is the setup I am purchasing and will soon be able to tell you, but it will be a more couple weeks. I am expecting to rub some, but hopefully a little trimming will take care of it. We shall see.
  6. Jun 15, 2012 at 11:02 AM
    Hdeuce22
    Alabama
    Yeti,post pics when you do please.
  7. Jun 15, 2012 at 11:04 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Do you have a lift on your Tacoma?
  8. Jun 15, 2012 at 11:12 AM
    Hdeuce22
    Alabama
    Krimson,I don't have any lift on it at all. It just seems like I read somewhere that KPT was saying that a few here were running the 285/60/18 , 18x9 with a 4.5 BS and they would fit with no lift but I could be mistaken.
  9. Jun 15, 2012 at 12:14 PM
    Yeti75
    NE TX
    09 PreRunner DC SB
  10. Jun 15, 2012 at 12:31 PM
    Hdeuce22
    Alabama
    Thanks for the links Yeti. I will take a look at those. I've been reading a little more and I think to be on the safe side,installing the 5100's to get the front end up 1.75" might be the best bet.
  11. Jun 26, 2012 at 12:58 PM
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    Good idea on installing the 5100s.
    I had 285/60R18 tires with 18x9" 0mm offset (5" backspacing) on my Tacoma when it was stock. The tires rubbed slightly at full lock, and it rubbed when turning in reverse.
    The amount of rubbing will probably vary depending upon the style of tires too. In the same size a highway (H/T) tire will probably rub less than an all-terrain (A/T), which will rub less than a maximum/ mud terrain (M/T).
