When to service transmission?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lineback, Oct 25, 2016.
  1. Oct 25, 2016 at 11:21 AM
    Lineback
    Lineback [OP] Well-Known Member
    2013 Tacoma DoubleCab TRD
    5 x 285/65/R18 Nitto Trail Grappler mud tires on 18" XD wheels (full sized matching spare) Bilstein 5100s with 3" spacer lift Prinsu roof rack Secondary air filter mod ARB Deluxe Bull bar front bumper + ARB LED fog lights ARB Recovery point Warn 9.5xp winch with steel cable SOS Concepts angled rock sliders with kick-outs 2 x Baja Designs LP9 Pro mounted to ARB bumper AVS window vents Interior knob mods Toyota bed mat Toyota hood deflector Toyota bed cargo divider Steelcraft 33250 Rear tail light cage guards Reverse light LED mod Wet Okole seat covers WeatherTec floor mats Tail gate anti-theft mod COMMS: On-board 2 meter VHF HAM radio (Boafeng F8HP mobile) + Bluetooth integrated mic External antenna: Nagoya UT-72 Super Loading Coil 19-Inch Magnetic Mount spotter radios: 2 x Cobra ACXT1035R FLT Gear: IFAK EMT Trauma wound kit 5lb fire extinguisher
    2013 DCSB V6 4L 1GR-FE. 38,500 miles.
    Took her into the local Toyota dealership today for trans and propeller shaft grease service, figured I would have the trans flushed. The service tech talked me out of the trans service, said the trans was sealed and uses a high-life synthetic fluid that should not need changed or serviced until 100,000 miles. Is this correct? So I opt'd for no trans service today, and they are only greasing up the zerks in the propeller shaft.
  2. Oct 25, 2016 at 11:25 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Had mine done at 60, 80, and ill have another at 100k.
    They didnt offer a flush, but a drain and fill.
  3. Oct 25, 2016 at 11:28 AM
    Lineback
    Correct, drain and fill was recommended at 100k, unless I am towing a lot which I am not. Service tech told me it was an all day job, since I have the two package with trans cooler. They have to let the truck sit for a few hours to cool down, then drain, then fill, then test. I was surprised the dealership was so honest and talked me out of spending $350 for trans service today.
  4. Oct 25, 2016 at 11:30 AM
    inwood customs
    Dave
    Not all day..... few hrs yes.
    I have the tow package also, its not a big deal.... they sound lazy and id second guess taking it to them.
    SOSHeloPilot likes this.
  5. Oct 25, 2016 at 12:04 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    I'd do a drain/fill every 60,000 regardless if your towing or not... just my opinion. From what I've read here the fluid level comes low from the factory on a lot of these trucks with the tow package... just to be on the safe side had my first drain/fill done at 18,000 miles.
  6. Oct 25, 2016 at 12:15 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    The tech may not have meant "all day". If you show up with a hot engine. it's going to take awhile for it to cool down to the correct temp that it needs to be at to open the overfill plug.
  7. Oct 25, 2016 at 12:25 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    My maintence schedule that came with my manual says 60k for transmission.
  8. Oct 25, 2016 at 12:26 PM
    BaconPower
    BaconPower Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    kgarrett11 and SOSHeloPilot like this.
  9. Oct 25, 2016 at 12:40 PM
    Lineback
    now they are calling me back to tell me the U joints on the drive shaft aka propeller shaft are also sealed, and cannot be service. wait now. I thought there were zerk fittings in there on a 2013, am I wrong?? or is the dealer smoking crack ?
  10. Oct 25, 2016 at 12:42 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    Unless you're 4x4, there are no zerks for the drive shaft
  11. Oct 25, 2016 at 12:49 PM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
  12. Oct 25, 2016 at 12:49 PM
    Lineback
    Yes, 4x4 here, which is why I thought I had zerks for grease. This dealer is about to piss me off.
  13. Oct 25, 2016 at 12:55 PM
    DriverSound
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
  14. Oct 25, 2016 at 12:57 PM
    OffroadToy
    Your better off greasing it yourself... at least you'd know if it actually got done. If your not sure you have zerks just peek under there... pretty easy to see most of them without even getting under the truck (total of 5.) I grease them every 5,000 miles (that translates to every 2.75 years in my case.)
    Lineback[QUOTED][OP] likes this.
  15. Oct 25, 2016 at 12:58 PM
    moondeath
    Pa, Gardners
    There are grease fittings on the driveshaft. I grease mine every oil change.
    JimboAnz likes this.
  16. Oct 25, 2016 at 2:23 PM
    gearcruncher
    Canadain bumper technician
  17. Oct 25, 2016 at 3:12 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    I do a drain/top off on my transmission every ~25k miles, the procedure where you drain 3-4 quarts out and then top it back up. Some people do it less, some people do it more, but that's how often I like to do it.
    And I grease the u-joints once a year.
  18. Oct 25, 2016 at 8:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not true. My Prerunner has grease fittings on the drive shaft universal joints.
    The only correct answer is that some do and some don't. Check visually to make sure.
    NAAC3TACO likes this.
  19. Oct 26, 2016 at 3:20 AM
    Lineback
    Thanks for the helpful posts today. I'm going to wait until 60k miles to service the trans. I used the pics in this thread to show the tech at the dealership where to grease, and they hit all the zerks for me,
  20. Oct 26, 2016 at 4:48 AM
    kenstar
    kenstar Get a Lil Mud on the Tares
    Ken
    Wrenching in the garage.
    10 4x4 TRD OR
    Pop 'n' Lock, EGR In-Chan, Bakflip G2, 6112, 5160, Dakar Set. Redline hood struts. WildPeak At3. TRD Pro Wheels. Apex Fab Fog lights; Other shit I can't remember.
    Damn, if it took all that.. I'd be looking for a new place to take it to. Or better yet do it yourself. Greasing the zerk is fairly easy. Only one zerk requires you to remove a small heat shield to access.
