Which front axles can I use?
Discussion in 'Solid Axle Suspension' started by Gibbs 505, Dec 23, 2018.
  1. Dec 23, 2018 at 7:23 PM
    Gibbs 505
    Gibbs 505 [OP] Member
    Been looking around and can’t get a straight answer but I was wondering what all front axles I can use to SAS my 99 2.7 taco
    ToyotaJim likes this.
  2. Dec 23, 2018 at 8:43 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Anything you want, no real formula to an SAS. Since it’s all about cutting and welding you can make anything work.
    Ritchie, tcBob and ryans4x4 like this.
  3. Dec 23, 2018 at 8:48 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    If you wanna stay the same bolt pattern and be a Toyota axel them probably a fj80 axel will be best.
  4. Dec 23, 2018 at 9:27 PM
    02hilux
    Planet: EARTH
    There's plenty of info regarding tacoma SAC on TW, MC, TTORA etc. Just have to look and spent some time searching and reading.
    Your tacoma have a DS tcase, so you'll need a DS SA. Commonly use SA are D44/D60 or you can run custom built housing. Cheaper route will be the TG SA kit. Unless you do a P drop setup then you can run a 80 or mini SA, tho the WMS is narrower.
    You'll have to put into consideration: link or leaf.
    Keep in mind, cheaper route for SA still run ~7k if you're able to do the work and fab some of the parts yourself.
    My advice: if you don't know what you're doing, don't start. Or just have a shop do it all.
    Ritchie likes this.
  5. Dec 23, 2018 at 9:31 PM
    Gibbs 505
    I got an 85 Chevy in the back 40 I could take the axle off of it, can I use the same leaf pack off of that or are they going to be to long you think?
  6. Dec 23, 2018 at 9:33 PM
    02hilux
    Planet: EARTH
    Nothing will bolt on in factory location as far as leaf spring goes. If you fab new mounting point, it will work.
  7. Dec 23, 2018 at 9:37 PM
    Gibbs 505
    I have little knowledge of it but I got buddies that This is all they do that said they would help me all the way if I bought all the parts
  8. Dec 23, 2018 at 10:40 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  9. Dec 25, 2018 at 8:01 AM
    Brokebrute
    Brokebrute Well-Known Member
    Joe
    2004 Tacoma TRD
    Grey wire mod and 2 low mod
    The Chevy axel has the pumkin on the passengers side you will have to get a different transfer case to use it. Jeep Wagoner is the most common used front axel it has the 6 bolt pattern. Ford axels also have the pumpkin on the correct side but the wrong bolt pattern at the wheels, you might be able to use parts off the Chevy to make the wheels work.
  10. Dec 25, 2018 at 9:30 AM
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    I think you need to do a lot more reading before you get into this.
    slander, Wyoming09 and Gibbs 505[OP] like this.
  11. Dec 25, 2018 at 10:56 AM
    Gibbs 505
    Yea for sure this is why I’m on here and I got a rig I can mess around with not like I’m trying to flip em
  12. Dec 25, 2018 at 12:29 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Pretty Much comes down to how big of a budget .
    Good place to work so you can get everything straight and square.
    Over the years I have fixed quite a few that went down the road sideways. Not a big deal if you trailer to and from your adventures.
    Run two cases so 20 mph is fast
    You might even want to look into the kits that might be on the market I have not looked for some time they may no longer be out there
    Gibbs 505[OP] likes this.
  13. Dec 25, 2018 at 4:26 PM
    Broke Okie Ty
    Broke Okie Ty Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
    Do this ^^^^
    Trail Gear has a leaf sprung kit. I think it's 6k msrp. It literally come with everything except wheels and tires. You don't have the knowledge to piece something together. And if you don't got the monies to buy the kit don't start cutting your truck up yet. Take it from me, kits are there to replace the years of experience you don't have.
    Dalandser and Gibbs 505[OP] like this.
  14. Dec 26, 2018 at 7:49 AM
    Gibbs 505
    Awesome. I have a descent sized shop I to put my truck in with all the tools and everything and as far as the budget goes I’ll be able to throw about 2 grand a month at this turd I know it’s not much but over time I’ll be able to get everything I need. And I’m just going to rail on this rig the way it sits until I can afford everything
    Dalandser likes this.
  15. Dec 26, 2018 at 8:12 AM
    Broke Okie Ty
    Ty
    That's the way right there! Where you from?
  16. Dec 26, 2018 at 8:30 AM
    02hilux
    Planet: EARTH
    Built it right the first time and cry once. Dont go forking money out to finish your truck to just change your mind later and end up selling it. Make sure it's something you really want to built and not something you just want to do because you got the truck for cheap.
  17. Dec 26, 2018 at 7:26 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Look for used parts that's where the savings is. Paying 6 grand for a leaf spring SAS kit is nuts. I swapped mine for about as cheap as you can possibly do it, I think it's a little over 3 grand not including tires. 900 of that was the f/r gears. I found a used fj60 axle for $150, got a set of free used leafs off a landcruiser and used those up front, used hi steer kit, I have more in my air bumps than the entire front suspension. I did it as an exparament because everyone assumes it will cost 7-10k+ to SAS one of these, so this was my middle finger to the internet LOL. I drive it to and from the trails so it drives fine up to 85 which is as fast as I will take it. I would not recommend a rookie try it though, not that I'm a master fabricator, I have spent alot of time helping people fab, and had a semi deep bench of friends to call for advice, but I did 95% of the work myself in a 2car garage. Build threads in my signature, check it out and ask questions in there.
    Note:
    I did flip a Toyota axle to drivers side drop, the only reason I did this was because I already had $4k+ tied up in my dual cases/lefty tcase setup over the years. If I was building the truck from scratch I would have swapped in a gear drive early mini truck tcase and dual case setup and keep the axle passenger side drop.
  18. Dec 31, 2018 at 6:13 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    Any picture of your tacoma and built page/more info by chance
  19. Dec 31, 2018 at 6:14 PM
    Broke Okie Ty
    Ty
  20. Dec 31, 2018 at 6:30 PM
    v5ensx
