Which leaf to remove on dakars
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeffrow20111, Feb 7, 2017.
  1. Feb 7, 2017 at 5:56 AM
    Jeffrow20111
    Jeffrow20111 [OP] Well-Known Member
    Jeff
    Murrieta Ca livin, from Vista Ca thou
    2011 Tacoma Pre runner
    Maxtrac spindles, Total chaos upper arms, king 2.5's, flow master exhaust, K&N intake, throttle body spacer, custom front bumper, McNeil fenders, 33"BFG's, 17" Mickey Thompson classic lock wheels.
    ChadsPride likes this.
  2. Feb 7, 2017 at 6:00 AM
    kmoto
    kmoto Well-Known Member
    NoVA
    2012 AC TRD Sport 4x4
    TRD S/C and other doohickeys
    I removed the third one down. Made the truck ride a whole lot better and took out some rake.
    Jeffrow20111 [OP] likes this.
  3. Feb 7, 2017 at 6:00 AM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Toyo M55 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 27F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, Cobra 75WXST cb with rear mounted Wilson 3' antenna on Shmellmopwho mount, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, 5100s with 885 coils and 1/4" spacers, SPC LR UCAs, 2wd low range mod
    If the truck bed will pretty much always be empty, remove the 3rd leaf down. If you carry some weight in the bed most of the time, remove the big overload.
    Full disclosure: I left all of the leaves in mine and added the OME AAL to the pack.
  4. Feb 7, 2017 at 6:00 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    I will be looking to do this at some point
    outlawtacoma likes this.
  5. Feb 7, 2017 at 6:02 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    I have this quote"The OME pack will provide approx. 2.75”-3” of rear lift. If the lift is too much for you or the ride seems too stiff you can remove the 3rd leaf. Doing so will decrease the spring rate by 15% and the overall lift height by 15mm. You can also remove the long overload and that will decrease the lift height by ½” but not affect the spring rate." from Marie at HS OR in my email.
  6. Feb 7, 2017 at 6:09 AM
    Jeffrow20111
    Jeff
    Sweet thanks. Seems like the 3rd one down is the one to remove.
    jpereira2 and ChadsPride like this.
  7. Feb 7, 2017 at 11:58 AM
    Jeffrow20111
    Jeff
    How do they ride with all the leafs on? Just wondering if it will be too stiff or not. I did buy Fox 2.0's for the rear with resis.
  8. Feb 7, 2017 at 12:14 PM
    jpereira2
    Massachusetts
    Mine are paired with bilstein 5160s but it rides great! way better ride than it ever was stock......i do however have the weight of a cap back there.
  9. Feb 7, 2017 at 2:05 PM
    Jeffrow20111
    Jeff
    Did you get extended brake lines?
  10. Feb 7, 2017 at 2:13 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    does anyone know what the spring rate is for the Dakars, as is?
    @HeadStrong Off-Road :boink:
    HeadStrong Off-Road likes this.
  11. Feb 7, 2017 at 2:43 PM
    jpereira2
    Massachusetts
    Nope
  12. Feb 7, 2017 at 5:11 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    In talking to ARB they say that it increases capacity but you should still follow Toyota guidelines as far as payload etc.
    Here is the information taken right from their spec guide:
    Part #: cs047r
    Stack Height (mm): 57
    # of leaves: 5+2
    Eye Diameter F/R : 40/40
    Weight (kg): 32.4
    Primary free camber (mm): 207
    spring rate:
    lbf/in: 182/392
    n/mm: 32/69
  13. Feb 7, 2017 at 5:15 PM
    Jeffrow20111
    Jeff
    I'm assuming taking off the 3rd leaf down from the top where the bushings go?
  14. Feb 7, 2017 at 5:20 PM
    HeadStrong Off-Road
    If the overall rear height is too much for you or the ride seems too stiff you can remove the 3rd leaf. Doing so will decrease the spring rate by 15% and the overall height by 15mm. You can also remove the long overload and that will decrease the lift height by ½” but not affect the spring rate.
  15. Feb 7, 2017 at 5:23 PM
    ramonortiz55
    Ramon
    Texas
    stock
    thanks.
  16. Feb 7, 2017 at 5:25 PM
    HeadStrong Off-Road
    :hattip:
    jross20 likes this.
  17. Feb 7, 2017 at 5:25 PM
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Depends on your build imo. If you're just going to use it light and do some road trips. Would probably recommend taking the overload out. If you're looking for height and basic appearance I guess 3rd leaf? I don't know I've got the full pack plus the AAL.
  18. Feb 7, 2017 at 5:27 PM
    KILLINTIME
    KILLINTIME Forty Six & 2
    SOUTH CAROLINA
    06AC4wd 18T4R4wd
    This is a very helpful thread:thumbsup:
  19. Feb 7, 2017 at 5:31 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Quoted for reference.
    I'm going with 5100s and HS 2" springs in front. I wondered if Dakars would be too much rake. Removing the 3rd leaf sounds like the ticket for my rig.
  20. Feb 7, 2017 at 5:31 PM
    bski22
    Rob
    Toyota
