Wiring assistance.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OdiN1701, Jun 5, 2017.
  1. Jun 6, 2017 at 4:39 AM
    #61
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Interesting.
  2. Jun 6, 2017 at 5:30 AM
    #62
    freeriderchad108
    freeriderchad108 Well-Known Member
    Boston
    2016 Tacoma TRD Sport Silver
    A few minor things...
    run an add-a-circuit into an ignition switched circuit in your in-dash fuse panel. Run that 12V (Switched) to the N/O contact on your switch. Find the circuit for your dash lights and add-a-circuit to power the LED on your switch.
    Ground to something under the dash.
    Run the signal wire through the firewall grommet right by the drivers feet.
    Run the signal anywhere you want to put a relay and your compressor. Hook it up to the coil, ground the coil, and put the positive power from your compressor on the N/O contact on the relay.
    Using an add-a-circuit will provide you with the ~10mA for the LED and ~30mA for the coil. It won't effect anything and you can use a .5a fuse.
    Depending on your compressor you'll need a fuse inline with that rated appropriately. I'd even suggest getting a blue-sea-systems waterproof circuit breaker so if it trips due to heat you can reset it and not get stuck somewhere.
  3. Jun 6, 2017 at 6:09 AM
    #63
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I think you missed a big part of the thread where the OP doesn't want to use add-a-circuit fuse taps.
  4. Jun 6, 2017 at 6:31 AM
    #64
    freeriderchad108
    Boston
    I read through the first 7 comments and shit was salty so I ignored the next 3 pages.
    Oh well.
    Do whatever you want OP!
    over60 and desertjunkie760 like this.
  5. Jun 6, 2017 at 6:36 AM
    #65
    Dragons Taco
    Derek
    Cary/Raleigh NC
    It did get salty but we threw some sugar around.
    uhplifted likes this.
  6. Jun 6, 2017 at 8:13 AM
    #66
    OdiN1701
    OdiN1701 [OP] Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Thanks, but I'm pretty good with wiring stuff up. I just need one little wire to tap into :) Don't care about circuit breaker. I'll have spare fuses. And I wouldn't really be stuck. If need be I'd just drive on low PSI to the nearest gas station.
  7. Jun 6, 2017 at 8:17 AM
    #67
    Dragons Taco
    Derek
    Cary/Raleigh NC
  8. Jun 6, 2017 at 8:17 AM
    #68
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    FFS just get a bicycle pump
    takes mere minutes to pump up a truck tire
    holy sheet simulpost ^
    over60, Benzdriver81 and Dragons Taco like this.
  9. Jun 6, 2017 at 10:40 AM
    #69
    airborndad
    airborndad Well-Known Member
    Keith
    Montclair, CA
    2017 Black DCLB TRD Off Road 4X4 JBL
    Front Runner Slimline Roof Rack
  10. Jun 6, 2017 at 10:42 AM
    #70
    OdiN1701
    Colorado
  11. Jun 6, 2017 at 11:02 AM
    #71
    airborndad
    Keith
    Montclair, CA
    LOL
    I got the ARB single
    Haven't had time to install it yet
    Watching a few threads along with this one collecting valuable info until I manage to get the time to install
    Slime pump actually works great, use it for my dual sport rides, tops off front and rear on 4 to 6 motorcycles when we get back to pavement with no issues
    I'm sure it would take a while to fill even 1 truck tire and may melt or even burst into flames before you get to the 4th truck tire lol
    But I threw it into my truck anyways just in case I might need it before I finish the ARB hook up
    Anyways seems to be a slightly better temporary backup option for an old guy like me than a hand bicycle pump
    Spare Parts and Arlaghan like this.
  12. Jun 6, 2017 at 11:11 AM
    #72
    ramirez810
    ramirez810 Active Member
    Alex
    2016 White Tacoma Trd sport
    Why not just tap into the ignition wire from the back of the radio? I've used it for my light bar and amps. Plus the radio is easy to remove.
  13. Jun 6, 2017 at 11:12 AM
    #73
    OdiN1701
    Colorado
    Doesn't seem very easy to get to. There must be a wire nearby the switches that will work.
  14. Feb 25, 2018 at 9:02 PM
    #74
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    @OdiN1701 how did you end up? which wire did you utilize?
  15. Feb 25, 2018 at 9:05 PM
    #75
    OdiN1701
    Colorado
  16. Feb 25, 2018 at 10:00 PM
    #76
    Beerpayzdabillz
    Nor Cal
    2016 DCSB 4x4 sport
    great write up. Thank you!
  17. Jun 20, 2020 at 7:05 AM
    #77
    warforgotten
    warforgotten Well-Known Member
    Man, this thread is old, but it is also cancer.
    over60 likes this.
  18. Jul 1, 2020 at 11:53 AM
    #78
    Brando2017
    Brando2017 Well-Known Member
    2016 Tacoma TRD off-road
    Anyone know where a accessory power source is to the left of the steering wheel?
    I’m trying to install a double USB port for a phone charger on the left side.
    TACOZAC likes this.
  19. Oct 12, 2020 at 2:38 PM
    #79
    TACOZAC
    TACOZAC Well-Known Member
    2018 OR 4x4
    On that RED wire could I also connect my amp’s “remote” wire to it for power on supply? If so would the Amp remain on when the truck is off ? I similarly need a simple power on source when car is in accessory mode and with ignition on.
